Heaters
Problem for Heaters
Generic problem for all Heaters
Blowing out smoke
By speterson428 on Dec 03, 2008
When plugging in the heater the egniter will come on, the fuel will start to spray and the the fan will kick on. ( normal ) Then it will start smoking and keep trying to kick on, Then shut off due to the smoke. If I take the top cover off it will work fine. Just will not blow out as much heat from the front.
Same Problem
Dec 04, 2008
-   Mine will run for awhile when left unused for a few days and start running and quit. I have cleaned and checked the fuel filter, adjusted the fuel pressure to 5#, checked for air leaks, cleaned lens on photo cell. It has nice strong ignition spark. Why when I put top on will only run for a few minuets??? -   aalimoman
Popular Solutions for Heaters
Questions and Unsolved Problems for Heaters
Answer
best heater for a 5,000 square foot monolithic dome
Answer
What is the best portable heater for a 700 sq ft area
Answer
How do I reset the Amana 153-7758 Thermostat to the temperatures I want thru out the day and night?... (More)
Answer
I have a Remington 60 kerosene heater. When I plug it in, it runs loudly and the flame burns... (More)
Answer
The lp conversion kit says to remove all metal screens from heat exchanger tubes when using propane.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Heaters:
Top Heater Experts
Rank: Guru Guru
Solutions: 1220
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Heater Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
