Question about Goodmans W280NS Television
The tv has no power going to it - Goodmans W280NS Television
  • Anonymous Jan 22, 2009
    if you open the television there's no
    power
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Disconnet your power moudle from the tv, cheak for any physically burnt componets or any swollen or burst electrolytic capacitors & replace such if any. power on your power unit & check the outputs for the correct output voltages . if no output ,troubleshoot more to restore your outputs. if outputs are ok & no power, unplug your power unit output to the backlight inverter & power on again. if no power ,order for new analog/digital converter board
Posted on Dec 18, 2008
How to repair my samsung plasma 64" tv
TV Parts Universal TV Stands DLP Chips ShopJimmy for parts. Check the power supply for the presence of the different voltages. Electrolytic capacitors will swell and dome the tops of the metal can. If you don't have the voltages on the power supply board, replace it.
Dec 12, 2016 | Samsung Televison & Video
Why does plasma TV have no picture?
What brand and model # is the tv? This is very important as far as researching your problem. You probably aren't the first or the only person with this problem. There are typically four to 5 boards including an x main, a y main, power board and others. Sometimes easy stuff like capacitors or fet's go bad and you can fix it yourself pending your soldering abilities. Sometimes whole processors go bad or entire boards and these need to be replaced. Sometimes people want to fix sometimes they want brand new
Jul 07, 2015 | Televison & Video
I asked this question previously about a power supply on a Panasonic TCP50C2 TV . Ihave no power coming out of the 5 volt standby terminal . The tv took a power surge ,but the board doesn't show any d
Your Panasonic TV is a plasma TV? If yes is a knows issue with Panasonic plasma TV's , the power supply board might have went bad, it is a complicated issue as V boards go bad also , you will need to take the TV to a repair center.
Dec 29, 2014 | Panasonic Televison & Video
LG TV Goes Into Hibernation (I Think)
This could be two things 1- a power saving mode in the TV... go into settings on the TV, look for either "power save settings" or "energy star settings" go in and turn that off. 2- it could be a screen saving mode because the TV has lost signal...some HDDVR receivers such as Direct TV DVR etc...have their own power saving mode, after a couple our of inactivity, they turn off, which kills the signal to the TV...so the TV shuts down because it has no signal coming to it.... if that is the case, you need to go into the settings on your cable/satellite settings and also look for a "power save mode" or "energy star saving", and turn that off.
Mar 21, 2014 | Televison & Video
The power light does NOT go off and the TV will not turn on. I know the TV works because every once in a while I will plug it in and hit the switch and it turns on. I tried programing a remote and then...
As far i can tell,u said the tv u unpluging,repluging the tv back awhile later the tv will function and work is that correct?Yes,this problems,alway related to the tv power supply board,that the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.U said u tried programing the remote,is the remote u have and using is a universal remote,u don't have the tv original remote?Yes,try website like Remotes.com to buy the tv original remote too.
Jun 20, 2011 | Akai LCT2060 Television
Need codes for Go.Video remote control
Go video remote for dvd/vcr recorder combo; you program TV by 2 digit codes. press TV power down when TV is powered on; and input 11 for JVC TV, or 03 for GE TV. You can experiment any two digit codes until TV shut down, then you have just finished programing n150b remote. This also work for all LG dvd/vcr combo recorder remote such as 6711RN203A..
Mar 08, 2010 | GoVideo Go Video DVD/VCR Combo
Tv won't power on, stand-by light blinks 6 times continously
just unplug tv 5 minutes. and plug it again. power on again. if not reset tv.
May 25, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
TV WILL NOT GO ON. HAS POWER.
power supply is the heart of every thing in a tv, plse try the following, open your tv, power the tv,hear if you have whisling sound, if not. get your tv to a w/shop, and let them check the following
rectifier diodes, power transistor, fusible resistors and zener diodes.
Apr 29, 2009 | RCA Televison & Video
My kid power off tv by power button on tv, next time i could not
switch tv on the switch can not contribute to that. unless the following goes fault
i switch getting fixed on one position(holding)
ii check power on a input of tv and input fuse
iii power supply, i have said that because if a power supply is ok, sound was going to be there.
Nov 22, 2008 | Samsung TXG2547 25" TV
Televison & Video Logo
100 people viewed this question
Top Goodmans Televison & Video Experts
Kolbrun...
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
