Is your TV now Working?
Hello, I am having the same that you are/were having with your TV. Seven blinking standby lights. Did you do the repair yourself or did you have a tech come out to your house. My TV just went out last week and a tech said it will cost around $300 to fix the issue. Thank you for your time. Brandon
I have this same problem, but I found this below solutions:
SEVEN Blinks---High voltage shutdown. The high voltage
has exceeded 33k
and the unit goes immediately into safety shutdown.
Check power supply
regulation and horizontal circuits.
Posted on Jan 02, 2009
  • Pappu from Q Jan 02, 2009
    In my case, My sony tv is huge..and heavy. In addition , i have two small kids, so it will be little risky for me to open and work on it. I am thinking to have a tech to fix it for me. Currently i am shopping for a bergain for a tv repair tech.
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
Panasonic seven blinking lights
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Jul 28, 2015 | Panasonic Televison & Video
My tv whe I turn it on will only stay on for 4 seconds and then turns off, and the stand by light is on and blinking.
Have you when set turns off and standby or power light flash to count here the blinks if in a sequence like seven blinks, pause etc? This se should have the error buffer.
Dec 09, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron, KV-36XBR400 standby blinking light cannot power on. test it three times. first time, blinking 7 times, second and third time, blinking 5 times. bought it second hand two weeks ago...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33kV and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Feb 23, 2018 | Televison & Video
My standby light comes on and blinks seven times repeatedly but no picture.
Seven blinks of standby light in Sony tv denotes that there is a high voltage problem. It is otherwise called as high voltage shutdown.
Normally 32" tvs has an anode voltage of 27,000Vdc approximately. If it rise beyond its limit, the microcontroler in your set will detect the high voltage, and will prevent it from working further, to protect you fro X-Ray emisson as well as to protect the TVs other components inside the ciircut board from further damages, and will inform you about this fault, by seven continous blinkings of standby light. Now you are seeing this.
The final anode voltage depends very much on the input DC voltage to LOT [Line Output Transformer]. Usually this supply rail will have a voltage level of 135 to 140VDC. If it rises above this level, extra high tension voltage generated by the above said LOT will also rise proportionaly to high, which will goes to the final anode of the picture tube. If this voltage goes very high, there is a chance to radiate X-Rays from the picture tube which will harm you. This high voltage protection also known as X-Ray protection.
The main reason for this fault is related to the regulated power supply section inside the circuit board of your tv. To repair this, you have to open the back cover of your TV. Take every precautions before doing anything to your TV as it is an electrical equipment, which generates high voltages inside it while it is working, and there are voltage points as high as 30KVDC [30,000VDC], wich is very dangerous.
Just open your tv, and locate the power supply section. It is very easy to locate, as the main supply wire goes into it. There will be a regulator Ic, normally Sony sets have STR numbered ICs are used in that section. This regulator will heat up to 75degreeC, and there is a chance to get loose the solderings on its leg points, as continous heating and cooling process. Just look for any loose solderings on the solder side of your TVs power supply section. In practice, I found this in too many Sony sets, during my 36 years in this service field. It is very difficult to detect the exact loose point, so I always do is, just resolder most of the suspected points on the pcb, by applying a little more solder, and will retify the problem. Moreover, just replace small electrolytic capacitors fitted on that board, because some of them may cause this voltage rise. The DC supply voltage rail, will be between 135VDC or so. Any fault in the components fitted around the above said STR will cause this problem. So check every components, and replace if needed. If this does not help replace the STR with same type and number.
Go further with confidence. You can and you will. Wish you sucess. Take care. OK.
Nov 18, 2010 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Triniton tv no longer working standby light blinks seven times. why is it on standby?
Could be a fault in the powersupplym could be a flyback issue it will need to be evauluated to see what is the cause now most shops will tell you what it is without charge that way you can decide to repair it or replace it I am telling you it could be a power supply issue or flyback I will need to look to rule it out but at least you know what the problem could be and determine the cost of repair. please do click the end session to your right,
Nov 19, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony trinitron wega 36 inch
If you are not a professional Electronics guy,it is beyond you to tackle this problem. otherwise log on to service and see the SONY Blink codes and also download the service of luck
Aug 25, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
TV won't stay on, Standby blinks 10 times
Its sort of silly, but my father got behind the tv and smacked it. The error message went away, and the tv is working fine now.
It wasn't easy for him to get behind it though, it's rather tall and weighs 234lbs.
I did manage to find a pdf file of the repair manual for this model at
Mar 06, 2008 | Televison & Video
Sony blinks seven time intervals.........
I have just found this problem have you had set fixed yet if not replace relay and 47uf capacitor next to it.
Dec 08, 2007 | Sony KP-65WS500 65" Rear Projection...
Televison & Video Logo
202 people viewed this question
Top Televison & Video Experts
