Question about Toshiba 50H82 50" Rear Projection Television
Toshiba 50H82 with wavy lines at the top when in HD mode
I see your knowledgeable posts on the hyperboard and the 10uF caps that often need to be replaced. I just have an old soldering iron and I don't think I'm ready to take on surface mount soldiering on a board that I want to work again.
Do you think my symptoms would be fixed by replacing the board or even just the caps? My specific symptoms are that when the TV first comes on the picture is wavy and jittery. In regular definition, after a few minutes of warm up, the picture becomes perfect. But using the HD inputs the top of the screen has horizontal wavy lines that decrease as the set warms but never go completely away. The top three inches of the screen, or so, have persisitant horizontal wavy lines no matter for how long the set has been on.
Do you service the boards? Could I remove the board and send it to you for repair? Is it better to just replace the hyperboard? Do you think I should sack-up, get a descent solderiing iron, and do it myself?
Your counsel would be apprciated.
Thanks!
Rick Bentley
(fixya at thebentleys dot com)
  • Anonymous Feb 05, 2009
    I have the same problem with my 50H82. bewebster, have you sent your hyperboard the guy on Ebay?
    Phil
Found this person on eBay who repairs the hyperboard for $75 quickly with very positive feedback.
http://myworld.ebay.com/kcarrigan/
I have the same problem and will probably send mine after the holidays.
Posted on Dec 08, 2008
I have a few horizontal wavy lines at the top of the screen when I first turn on the TV. They eventually fade after a few minutes. What's going on? Is this serious?
yes it is, your hyper board has bad caps and they will just get worse and worse. you can run it on an HD signal to keep it going longer but eventually even the HD will have the wavy lines too.. basically the hyper board needs new 10uf 16v surface mount capacitors, replace all those and your golden, but its a difficult repair, even for a educated and seasoned electronics tech, estimate from repair shop will run you $250-$550
if you can solder surface mount, you can fix it yourself for like $20
let me know if I can provide further assistance
Sep 09, 2010 | Toshiba 42H82 42" Rear Projection...
Will a REBUILT PTS PART number pd0637 toshiba hyper, number on part MVPU14 2L20DD work as a hyperboard in a 2002 50h82
Most of these hyperboard are inter changeable.But must Check the 2 STK convergence ICS munbers on the ICS parts have the same printed #---?
Apr 01, 2010 | Toshiba 50H82 50" Rear Projection...
Toshiba 57hx81 tv has a bow at bottom of screen and blue in color tried using toush focus & got error then tried to focus manually & couldn't get the bottom lines to focus all the way down
noted in the owners manual, if auto focus returns message "error" , it suggests to use manual convergence setting..failing that, is it resonable to suspect that the STK-392-110 (convergence (2)chips)are beginning to fail, bendt horizonital lines is the effect. you can check all the resistors and pico fuses (power board)near the chips for shorts, chances are they are ok. seeing that there is somewhat of a picture (kinda like 3-d). i would repaired it!.. while your there do the hyperboard repair as well by replacing the 10 caps with 16v@10uf. (causing a wavy vertical distortion effect).
Jan 12, 2010 | Toshiba 57HX81 57" Rear Projection...
Toshiba 57hx81, has a slight squikgly line near the top of screen, colors seemed faded, not bright. i did the convergence adjustment and adjust the colors/focus with front lower right screws..Is there a...
jhinsincity: you dont need to be here, do you? the problem are the caps on the hyperboard, 10 -16v@ 10uf, rear access right hand green board, model 57hx81, the hyperboard must desoldered from main board. read the post on wavy lines,,
Dec 30, 2009 | Toshiba 57HX81 57" Rear Projection...
Wavy Lines which clear up after being on for 10 minutes - Toshiba 50H82
It will cost about $300 to fix. The Hyperboard has to be replaced. I had it repaired over 2 years ago and it works great.
Sep 06, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba 50H82 hyperboard caps
Service manual won't help much in the hyper board and that's likely the problem.. Simply remove the hyper board and open the can. Inside you'll see a number of smd caps. There are 11 10mf/16v that need to be replaced...
Bill
Jul 26, 2008 | Toshiba 57H82 57" Rear Projection...
Wavy lines when i turn on the tv
this is a typical hyper module replacement job let a tech do it.
not for the do-it-yourself type.
May 26, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba 50hd82 Hyperboard
By your question alone the best place to start would be a good repair shop. The hyper module needs to be removed from the main chassis. After removing the two outer covers locate Cx261, Cx230, Cx270, Cz52, Cx178, Cx221, C514, Cx250, Cx670, Cx241 and Cx541. These are all 16v/10uf caps SMT but most techs simply replace them with the sub mini radial caps.
Bill
Mar 13, 2008 | Toshiba 50H72 50" Rear Projection...
Toshiba 42h81
Hello, one of possible solutions is to replace capacitors (10uF/50V) on HYPER (PD0246) module. Please ask the tech to check/replace them. If you need more info please advice.
Apr 27, 2007 | Toshiba 42H81 42" Rear Projection...
Toshiba 50H82 50" Rear Projection Television Logo
468 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
