Question about American DJ Dyno-Fog-II Fog Machine W/ Remote System
American dj fog storm 1200hd, NO FOG!
Won't respond to remote inputs, it heats up as it should and it does put out small whiffs of fog, but 'no stream of fog' on demand.
Was told on phone by ADJ it was the "low level sensor" gone bad.( based on: pushing down on fog tank, green shut-off light on unit stays on.)
Went to ADJ, and while waiting in line for repairs, talked to a guy who said he had multiple units and had talked to someone at ADJ and was told you can bypass the sensor, just connect the sensor wires back on themselves completing the circuit ( bypassing the sensor).
Tried that, it made NO difference. Green Light stays on, still no fog!
ANY ideas?
I really don't wont to have to replace it, it's just, out of warranty, 1 year old.
Also, "is this unsafe", assuming you don't run it low on fog juice?
(I would rather replace it, if this a potential fire hazard!
Ed
2 Suggested Answers
SOURCE: American DJ Vaporizer Fog hog
Sounds like the pump either is not working or can't inject the fog fluid ( solution of distilled water & glycerin ). My unit clogged up, so I took it apart and cleaned out the lines. Be sure to run pure distilled water through unit, after each use.
Posted on Oct 01, 2008
  • 4 Answers
SOURCE: Shoots out liquid instead of fog...
that thing(the heater) just doesn't work well,
bring it to someone to repair it
Posted on Apr 23, 2009
Roku remote will not work roku on screen but remote not responding. Green lite flashes on but voes right off but only sometimes.
I presume you have a box and not a stream stick.Try unplugging ROKU box.Many units have a button you have to push on remote after plugging in ROKU box,this connect Remote to ROKU box.If this doesn't work take out batteries in remote and put back in,this has to be done after you plug in ROKU box.Are batteries weak,try some new ones?
Feb 06, 2016 | Roku Televison & Video
My Roko is frozen my remote is not working on the screen it say let's get started I push the button and nothing happens we have changed the batteries we do not know what to do can you help please
Roku Remotes Information & Troubleshooting - Roku Support
https://support.roku.com/.../208755708-Roku-Remotes-Infor...
Roku, Inc.Roku Remotes Information & Troubleshooting. Button functions & universal remoteinfo ... My remote is not responding - Troubleshooting steps .... ROKU POWERED, the ROKU READY logo, "Streaming Stick," "HAPPY STREAMING" and "NOW ...
Roku How To: Roku Remote Stopped Working - Easy Solution
rokuhowto.blogspot.com/2013/.../roku-remote-stopped-working-easy.ht...
Mar 10, 2013 - Remote working again AND I have the remote app on my phone. .....I've come to the conclusion that the Roku Streaming Stick is just a pile of ...
Roku Streaming Stick Remote Control Issues.... - General ...
emby.media > Emby Community > General > General Discussion
Jan 17, 2016 | Roku Streaming Stick
Went to settings and accidently turned off blue tooth wi fi now my fire stic remote will not respond air won'' scroll up or down and I can't get back to settings
straight from amazon,reset firestick,
Please unplug the Fire TV stick from power source and then plug it again after 5 seconds.
Once the Fire TV stick is back on, please take batteries out of the remote and re-insert
Apr 03, 2015 | Amazon Fire TV Stick
Sylvania 32 inch LC320ssx
It seems that the set itself changes inputs. Place it remote control away from the vicinity of the tV. and check. If it does the same, do a hard reset next. To make it a hard reset, unplug the TV from AC mains wall socket, and replug it back after 10 minutes or so. If these do not help you, be sure that the main system control memory IC to it is faulty and should be replaced.
Jun 05, 2013 | Televison & Video
GOODMAN AIR HANDLER, FAN AND HEAT STRIP COME ONLINE WITHOUT DEMAND. WON'T TURN OFF BY TSTAT
the w wire off thermosta controls heat. eithe bad board or thermostat.
Feb 01, 2013 | Goodman Heating & Cooling
Cub Cadet SRC 621, won't start. New spark plug, cleaned carburetor and air filter, Whiffs of smoke occasionally
Sounds like a sheer flywheel key. Common on the SRC 621. Kawasaki motor, correct. The flywheel key is under the recoil. Pull the flywheel and check the key. A very small key is there. Breaks and puts the engine out of time
Oct 16, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Recommended replacement remote for 32c11ou
i would make sure you have good batteries in remote and if you have a cell phone with a camera you can point the camera at the remote control where the bulb is that you point at the tv and push a button on the remote control and the light will show up in the camera as a blue light the camera will pick up the ultra violet light that your ***** eye won't see if still bad almost all universal remotes will work but usually problem is battery or corroded battery connectors good luck
Aug 05, 2012 | Toshiba Televison & Video
My tv won't respond to remote controll input
You have to change the batteries or call your tv people.If you can't than go to the tv and press input.
Oct 19, 2011 | LG 42PG20 42 in. Plasma HDTV
I have a chauvet hurricane 1800 flex and it won't heat up. Red light comes on won't go to blue.
take off the front panel where the nozzle comes out... to do this, unscrew 2 screws on top, 2 on bottom and 4 on each side, then carefully remove the covering for the nozzle.. if your facing it, to the right of it, is a black little nipple button thats tripped.. press that in and it should click... if it does, run the fog machine with the panel off to make sure you fixed it... if it works, put it back on, if not, try again, and if still not go to chauvetlighting.com and contact them... i had this same problem for a couple months... they called me yesterday and told me to do this.. but make sure it has a full tank of fluid.. i didnt have a whole lot in and i think i messed it up more....);
Jun 27, 2011 | Chauvet Hurricane 1800 H1800 Flex Fog...
Apr 23, 2009 | American DJ Dyno-Fog-II Fog Machine W/...
American DJ Dyno-Fog-II Fog Machine W/ Remote System Logo
253 people viewed this question
Top American DJ Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an American DJ Audio Player and Recorder Expert? Answer questions, earn points and help others
