Question about HP OfficeJet G85 All-In-One InkJet Printer
I just installed the software for my printer officejet g85. I tried to scan my first picture and it says scanning error... scanner cannot connect with pc. What does that mean?
  • kaken Dec 04, 2008
    I get the same message and it doesn't matter which port I have the G85 plugged into on my PC. What is the problem?
    Scholar:
  • 118 Answers
Means scanner is not connected to the PC in the proper way.
check the port you are useing to plug the cable in the PC...
or try it by changing the cabl...
regards,
Posted on Dec 03, 2008
Scanning from printer can't see any computers. says it needs the software. pc is able to print docs to the printer. when scanning says connection error - been trying for 3 days now uploaded all drivers to...
for normal scanning you can go to control panel and choose the option of scanner and camera wizard and do the scanning but it is good if you install the driver of printer which is contain the scanner software and give you more option of scanning.
have a nice day and dont forget to give rate please...
Feb 12, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Scanner not working
Have you installed the scanning software for the printer? If the software was installed what is the error message. if it says "scanner error" try to scan and check the scanner glass if there is a light if there is no light then the scanning mechanism is not working properly.
Oct 27, 2009 | HP Officejet 5610 All-In-One InkJet...
How do i scan a document and then email it
If you haven't done so, install the cd that comes with the HP Officejet package. Once correctly install, you should go to "All Programs" and locate "HP Solution Center" Click on HP Solution Center, click "Settings", click "Scan settings and preferences", choose either "scan document" or "scan picture" If word document then under File type: locate "PDF(*.pdf) If document is a picture then under File type: locate "JPEG image(*.jpg), click ok. Step 2 Choose between Scan Picture or Scan Document, click accept Step 3 your file is locate under "My scan" Hope that helps
Jul 10, 2009 | HP Officejet 5610 All-In-One InkJet...
Software downloaded and still will not scan
have you installed the TWAIN drivers? the easiest way to get the printer to scan is to use the software that came with the printer, if you have the CD put it in your computer and follow the instructions to load the scanner software, this will automatically install the TWAIN drivers for you.
Jul 02, 2009 | HP Officejet J5780 All-In-One InkJet...
Scanning
Try using the scan program provided by Hp already installed in your computer.
Double click on "My PC" select the OfficeJet scanner icon and do a the right click, and then order to a scan.
Oct 27, 2008 | HP OfficeJet 6110 All-In-One InkJet...
SCANNING PROBLEMS
Do you have HP Software install sucessfully..?
If yes then you should have HP Director or HP Solution center software installed in your computer try scanning from there.
Jul 30, 2008 | HP Officejet 5610 All-In-One InkJet...
G85 printer making horizontal strips
Check the scanner cable and the status of the LED's in the scanning head. Unluckily, you printer is disposable, to HP that problem will mean to discard the entire printer and replace it for a new one if it's still under warranty.
Apr 11, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP Officejet G85 All-in-one
might need a software to upgrade check this out
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu03082&cc=us&lc=en&dlc=en&product=60399&dlc=en&lang=en
Jan 10, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Scanning editable text to microsoft word
You need to install an OCR application that translates the "picture" that the scanner takes into editable text (something like OmniPage).
I would think such a program was bundled with your G85, if that is not the case you should try to figure out what program was in use and doing that earlier, install it if you still have it.
Dec 25, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
HP OfficeJet G85 All-In-One InkJet Printer Logo
166 people viewed this question
Ben Johnson
