My Coanon MP700 printer will not print at all. Nothing. Just goes through the motions and gives me a white sheet of paper.
  • Anonymous Apr 06, 2009
    I have the same problem and i tried your solution and nothing improve
    President:
  • 8,637 Answers
I suggest you Uninstall the printer, disconnect it from the computer and reinstall the software with the printer disconnected. When the installation of the software asks for you to connect the printer, only then do so. It then should work properly again. Hope this helps. Bud
Posted on Jan 06, 2009
My Canon Pixma MX882 is not printing though lots of ink. Paper goes through when I press print on my PC but nothing is printed
Print a test sheet to see if the printer is OK. If tthe sheet prints fine has this printer worked on this computer before? Did you change anything or update anything? You may have the wrong driver installed or the cable could be defective if it has worked before.
Feb 02, 2015 | Canon PIXMA Office Equipment & Supplies
On my MultiPass MP700 I'm getting vertical lines on eveything I print. I've run cleaning, deep cleaning, alingment and nozle checks. On the checks L & M the lines (stripes are horizontal alternating...
  1. Lift the document cover to expose the platen glass.
  2. Wipe the platen glass (A), white areas (B), and transparent sheet (C) with a clean, soft, lint-free cloth moistened with water. The MP700 has one even platen glass and does not have an area like the one referenced in area (C).
  3. Then wipe with a clean, soft, dry, lint-free cloth making sure there are no residues left, especially on the platen glass.
  4. Close the document cover and make a copy of a text document to confirm the black line has disappeared.
Apr 07, 2008 | Office Equipment & Supplies
HP designjet 130NR won't pick up paper from the tray.
paper tray lift clutch failure is likely the cause - common for this machine - repair with new feeder assy ordered whole from HP/ or Partsurfer
Jan 28, 2014 | HP DesignJet 130NR InkJet Printer
I have an HP Photosmart Premiem printer, and it is not printing. I send items to printer and it goes through the motions but nothing is on the paper. I have the cartriges that came with unit. I have...
Try checking the print queue and see if any print jobs is preventing you to print. This is usually a printer icon in the lower right corner of the desktop, next to the Date and Time. You can also run a Print Test to test your printer hardware.
May 19, 2011 | HP Office Equipment & Supplies
HP d7160 won't print black, New cartridge. Goes through the motions - but nothing hits the paper. Colors print fine. What gives?
1. Turn printer off and disconnect the USB cable from the PC to printer
2. Uninstall the printer driver and software-->here's how.
Navigate here for printer driver and software .(Select your Operating System and click next)
Install the printer driver and software -->here's how
Feb 23, 2011 | HP Photosmart D7160 InkJet Printer
Acts like it's printing, ink is good, but nothing prints out on paper.
Nothing at all? Poor you are. The pump may damage or lost electricity.
May 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Samsung 1710 stops after warm up
Chances are, you're getting paper jams.  Try cleaning the rollers (as indicated below.)  If that seems to help the situation, then you'll need to get new feed rollers.
Look where you put the paper in. See if you can see inside there and see the roller that turns and picks up the paper. If you can, make a mixture of alcohol and a little dish soap. Damp a rag with it, and reach in there to clean the rollers.  See if the rollers will turn manually, but be careful not to force anything.  Another way to get to the whole roller, would be to start making a print, while watching the rollers.  As soon as the rollers have turned half way, unplug the printer.  Now you can reach the other side and clean that.
There is another way to clean the rollers.  Using the alcohol mix, take a single sheet of paper, and damp one half of it with the solution.  Stick the single sheet in the paper tray, and make a print, but hold on to the paper so that it doesn't feed through the machine.  Do this several times, and the rollers turning against the wet paper should clean them.
Try to print again. It might take a few tries. The rollers have to turn against the paper and dry themselves off again.
If this works, then you need new rollers (cleaning them will only make them work temporarily and the problem will come more frequently until you change them).
Thankyou,
Oct 29, 2007 | Samsung ML 1710 Laser Printer
k24674
jasbo
jasbo
