Question about Zenith XBS341 System
Poor sound problem
I just bought a home theater in a box and when i power it up all i get is clicks and pops. when i turn up the volume to half i get louder clicks but some sound. can anyone help?
0 characters
1 Points
Bose system is just over 1 yr old, hooked up to Smart Tv ( same age) sound was working fine, turned volume down, no sound at all after that
Hi, You have a Bose Home Theater System hooked up to your television and I'm wondering if you're controlling the volume through the Bose Home Theater System or the television because both have a volume control and if you have the television volume turned down and you're using the Bose Home Theater System for volume or visa-versa then you're not going to get a decent sound. I hope you know what I mean...... CHEERS..
Mar 31, 2016 | Bose Home Theater Systems
I need help with volume and popping and cracking in the speakers. It's a new system and it's only plugged into my record player.
You are most likely going to need a preamp to go between your home theater and record player. The popping and hissing is usually a grounding issue. You will have to ground your system properly to get rid of this.
Dec 21, 2014 | RCA Home Theater Systems
I have a sony home theater system. my cable box volume is all the way up but still with watching TV the volume is so low, eventhough the volume on the sony system is set to "MAX". also i get a...
First, TURN THE VOLUME DOWN. We don't test with max volume any more than we start our cars with the accelerator floored.
How is the audio from your TV getting to the HTS? Name names and be specific.
Your TV audio output may be dependent on its volume control. Many TV's have a FIXED setting in their setup so you can lower or turn their speakers off while letting REAL electronics and speakers handle the sound duty.
OR, you could (and should) bypass the TV entirely as an audio source and go to the cable box's audio output.
Feb 05, 2011 | Home Theater Systems
Philips HTS8100 owner. Have ben using the soundbar since Decembr 2007 with no issues. it is intgrated with a sony bravia tv. tried to turn on sound (tv input) and have very limited sound. Turned up to...
Same problem with my HTS8100. Little-to-no sound. Sometimes sound comes on very intermittently. I downloaded the software patch from the Philips website and installed it. This fixed the sound problem for about a week, then the problem came back. I'm not sure what else to do.
Dec 22, 2010 | Philips SoundBar DVD Home Theater with...
Speaker pop
Volume is up to high to begin with or there could be some power source close to the unit that is causing it. Turn down or turn off volume and try to do it. Thsi isn't a broken system it does happen to some units, mine included butr when I do the things I have listed it is much better. It is worse with my better sound systems.
Dec 22, 2009 | Onkyo HT-S5100 Theater System
Can't figure out how to connect a subwoofer to my RCA RTD315W
HI,the rca system should have a sub pre out socket,plug a phono cable into this then to input on your sub and set volume to half way,also make sure the sub is set to on in the setup menu on the system.
Hope this helps.
Apr 18, 2009 | RCA RT2500 System
Cracking popping type sound coming from front and center speaker
if u are trying to connect the audio of ur tv as input to flow out from the home theater; this is a common thing; u need to replace the audio cable that connects the tv to 3565 with a good quality cable
Apr 01, 2009 | Philips HTS-3565 Theater System
Audio: hearing everything twice
you have a delay time on your home theater JVC, that is normal. So it's either you reduce the delay time of your JVC or do not use the TV sound. Set the delay time of your DSP so you can heqar the sound you wish... like the delay time of your surrond.
Mar 30, 2008 | Home Theater Systems
Zenith XBS341 System Logo
21 people viewed this question
Top Zenith Home Theater Systems Experts
Are you a Zenith Home Theater System Expert? Answer questions, earn points and help others
