Question about HP Office Equipment & Supplies
Printer lights flashinh - HP Office Equipment & Supplies
  • 75 Answers
Check for ink in catriges and the paper is stuck also light blinks
Posted on Dec 03, 2008
2002 explore,hard shifting,no o/d light flashinh?
These symptoms are usually caused by improper transmission fluid level or need for fluid and filter change in transmission.
Once you have serviced the transmission (which should be done every 5 years or 50,000 miles), any other issues can be identified by doing a readout of codes from the computer, using code reader.
May 13, 2015 | 2002 Ford Explorer
All led's flashing
That is normal, you just need to set the clock and everything should be ok.
Dec 31, 2011 | Stoves 720EF Electric Double Oven
VCS light is on ABS light is on and 4 hi light is flashinh on my 2007 toyota tundra
Hi. This means that your brakes need to be looked at by a mechanic.(maintenance is required)
Jun 30, 2011 | 2007 Toyota Tundra
1995 MONTERO SR 4X4 FLASHINH LIGHT
the mitsubishi pajero have a vacuum control valve to control the engage and disengage the 4wheel it is located at the engine compartment right side near the air cleaner.there are 2 vaccuum solenoid valve
Feb 24, 2011 | 1994 Mitsubishi Montero
What do symbols on top mean?
Welcome to Fixya
Half circle symbol means printer is in ready state. The printer control panel is comprised of six lights and two buttons. The lights produce patterns that identify the printer status.
1 Jam light: Indicates that there is a jam in the printer.
2 Toner light: When the print cartridge is low, the Toner light illuminates. When the print cartridge is out of the printer,
the Toner light blinks.
3 Paper out light: Indicates that the printer is out of paper.
4 Attention light: Indicates that the print-cartridge door is open or other errors exist.
5 Ready light: Indicates that the printer is ready to print.
6 Go button and light: Initiates action or indicates status.
7 Cancel button: To cancel the print job that is currently printing, press the Cancel button.
Thank you for using Fixya!
Feb 08, 2011 | HP LaserJet P2015dn Printer
Printer won't print. one of the lights is on, but I'm not sure what the symbol means. Cannot locate user manual.
Can you provide us information which light is on on the printer? the printer lights is represented by six light. starting from the left is error light, paper jam light, load paper light, toner light, ready light and continue button (green button). The light sequence will indicate a specific problem on the printer.
For further assistance, please contact Lexmark Technical Support.
Jan 26, 2011 | Lexmark E260dn Laser Printer
Dont start and red led flashinh
check y board and replaced power supply board
Nov 07, 2009 | Samsung HP-S4233 42 in. Plasma Television
Pc didn't start,flashinh green light in the back..I disconnect all inside and the green light is solid now,.How I can check my motherboard?
Failure of motherboards is usually due to breaking capacitors. A few years ago a capacitor company stole the "recipe" for making capacitors from another company and tried to make their own, unfortunately they did not get the ingredients right and the capacitors started breaking after 2-3 years of use. They sold these capacitors at very cheap prices and a lot of computer companies and power supply makers bought them. This is easy to diagnose. Look for capacitors (caps) (they look like little tiny soda cans) on your motherboard (mobo). They should be perfectly flat on top and not bulged or swelling or leaking anything. The dead giveaway is the fact that you are not getting a monitor signal and if you listen to your computer as it starts up, a few of the devices may not start (hard drive, etc). Mobos are usually expensive to replace because the computer makers have them made especially for them and only order so many. They usually do not have a lot of extras laying around. There are a few companies that will repair broken capacitor issues. Hope this explains why they can fail. They can also fail if overheated (like when a case cooling fan fails), the cpu is overclocked and not cooled down (which raises temps), the power supply fails or by lightning and power surges. Also if you add a bunch of extra components without upgrading the power supply you can suffer underpowered situations.
If you can get another power supply unit then you can try that first. Usually when the condition you describe happens it is either the motherboard or Power Supply. If you replace it with another PSU then you have to have at least the same or greater output watts.
Apr 24, 2009 | HP A500N PC Desktop
Blinking green timer light and fan turning on randomly, now no power at all
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
Check C8F19, C8F21, C8F22 and C8F27 (1000 uFD, 16V, 105C) on the FMT PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
thanks
scott
Sep 30, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Flashing lights
the printer when i on the swich the flashing light is on but can't work the printer
Feb 24, 2008 | Epson STYLUS CX3900 All-In-One InkJet...
70 people viewed this question
Ben Johnson
