Question about Lenovo ThinkPad T61 Notebook
Repairing the left click
I use a futures programe that should respond to left click but will only respond to right click on mt T61
Is there any simple way of fixing this
many thanks
  • 53 Answers
Try going into Control Panel - Mouse settings and under the Buttons tab theres a button configuration make sure this isnt ticked.
Hope this helps
Remember to vote
x
Posted on Dec 03, 2008
Tip
How to avoid losing your work in case a program stops responding
Sometimes, while doing some specific work on your PC or browsing the internet, the program you're using suddenly stops responding without any apparent reason. If you hadn't been saving your work regularly, you'll most likely lose it when Windows prompts you to close the program.
There's however a solution that could help you avoid such frustration. Here are the steps to follow in case a program stops responding :
1. Once you encounter such a problem, don't close the program you're using.
2. Open the Task Manager by pressing Ctrl + Alt + Delete.
3. In the "Processes" tab, find "explorer.exe", choose it and click "End Process" on the bottom right.
4. Click "Yes" (Everything you see in the background will disappear but don't panic, it will come back).
5. Click "File" on the top left.
4. Choose "New Task (Run...)"
5. Write "explorer.exe" in the box.
And everything comes back! You can now resume your work...
on Sep 28, 2010 | Computers & Internet
Trackpoint is not woring..
there should be button with a circle on it at the top of the key board push it then try it again
May 27, 2010 | IBM Lenovo ThinkPad T61 Notebook
How to exit a program that is responding
Do you mean NOT responding?
If so, hold down the command key (that's the one right next to the space bar), then hold down the ALT key (that's the key next to the command key) and while you are holding them down press the ESC key (top left hand corner of the keyboard).
A window will open up showing all the running programs. Normally the problem program will be high-lighted and will have (not responding) tagged onto the end of its name. At the bottom of the window is a button marked "Force Quit".
Alternatively you can mouse over the program's icon in the dock, click on it and hold the click for a couple of seconds. A menu will pop up with "Force Quit" in it. That's it.
Jan 24, 2010 | Computers & Internet
HAVE TO REPLACE THE LEFT CLICK BUTTON BELOW THE TRACK PAD- NEED A PART NUMBER TO ORDER THE RIGHT PART
The buttons may not be readily available and it would be easier just to change out the palmrest as a whole because the pad and buttons come already installed. Below is the item number for a T61 palmrest I found on Ebay, look up the number and then contact the store that has it directly to find out more.
400065218534
Jan 13, 2010 | Lenovo ThinkPad T61 Notebook
Both right and left click on my touch pad working
go to control panel->key board and mouse settings and then you can edit the settings from there.
Jul 26, 2009 | Dell VOSTRO 220MT E8400/3.0G 2G WVB 160GB...
Thinkpad T61 mouse left click not working since yesterday. However the right clck and other keys are working
ok go to control panel and mouse settings and make sure that for the left button its checked to bring up menu or double click or whatever you like
Jul 26, 2009 | IBM Thinkpad T61 Motherboard
Error loading c:\progra ~1\my webs~1\bar\1.bin\ on windows vista
Hi colewilfred, this is very common for MyWebSearch program. Its a simple fix.
Right click once on the start button, (A pop-up window will open), slide up to Explorer & left click on it once. Right click once on the C:\ drive & left click Search from the list.
In the search top window type the name of the file: m3plugin.dll
Click search.
Windows will find the file. Right click once on the file m3plugin.dll listed in the right hand side of the search window & left click Copy from the list. Windows Explorer is still opened. Scroll down to the folder, Program Files & left click the plus sign next to it. Program Files will open & you'll see all kinds of folders.
Find the Mywebsearch folder & open it. Find the folder 1.bin, Right click once on that folder & left click past from the list.
Close all opened windows & restart the system.
Thanks for using fixya.
Mike
Please vote....
Jan 11, 2009 | Intel Motherboard
Lenovo T61 - When I go to Control Panel and select Display, all I get is Themes tab. How do I restore the other display tabs?
In Windows Vista you right-click the desktop background, and select Personalize...
Select Display Settings to open the Display Settings window...
To change the appearance of the control panel...
When you first open the control panel, on the left side off the pane click Classic View to revert to the older style of the panel.
Nov 28, 2008 | Lenovo ThinkPad T61 Notebook
Lenovo ThinkPad T61 Notebook Logo
338 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
