Question about Microwave Ovens
Reattaching rubber pieces inside microwave
I need to reattach the rubber pieces inside my microwave door. Is there a particular glue I need to get?
  • Microwave Ovens Master
  • 9,098 Answers
I might need clarification, but household cement or even caulk should work as long as it's allowed to dry fully.
Posted on Dec 08, 2008
My Jenn Air microwave model JMC8130DDS door panel has come unglued...what do I use to reattach it?
Super glue, hot glue, or J. B. Weld would all work, if applied neatly in minimal quantities to squeaky clean, dry surfaces which are then clamp lightly until the glue sets.
Jan 05, 2014 | Microwave Ovens
The part that holds the door switches inside the oven is broken; can the part be replaced
Yes this can be stuck using a instant glue if the broken pieces can be found. Usually this needs to hold the switch and lock in alignment.
So try this out , you can remove the front panel and get access to this assembly.
Jan 21, 2013 | Microwave Ovens
I pulled the door off my advantium today to clean it after I cleaned the vent grille. I set the door carefully on it's side so I thought but a small little plastic piece broke off where the door...
Glue won't work, the part must be replaced.
We have the service manual at our site and you can download it free here.
You can order parts from the Pros here, our favorite supplier.
Jul 07, 2011 | GE Advantium 120 Convection/Microwave Oven
Glass in door is loose
you may be able to dissassemble door and reattach glass with a hot glue gun. the plastic tabs are more than likely broken.
Apr 14, 2011 | LG LMV1630 Convection/Microwave Oven
We take turns replacing microwave ovens where I work. The latest one, a GE JES1358WL, stopped working after opening the door while running on a one-push (1 minute) start setting, and the control panel is...
Sounds like part of the peg broke off and is left inside the recepter slot area where the sensor switch is. If it is the lower door plastic hook thing (inside bottom) that broke off, it is possible to re-attatch it to the door if you save the broken piece. Drill a small hole the size of a small wire or nail you have lying around to make a splint - Cut the nail or wire to about 1/2" to use it as a hidden "bone" or skeletal support inside the broken plastic. Glue the nail half way into the broken plastic using modelers glue. Closely align the nail peg to where the plastic broke off and mark it for drilling. Drill carefully making sure you are centered so that your wire "bone" will allow proper alignment of your plastic. Insert the pinned piece into the newly drilled hole checking for alignment, if it looks close enough you can glue it in place and you should have a strong enough repair. Dangerous to use a wooden peg to fool the internal switch. As it will be running even when the door is open and you don't want to get zapped.
Nov 04, 2010 | GE JE1235 Microwave Oven
Hello I have a LG Microwave/grill/convention oven. I caught my bracelet on the bottom lug thing that is attached to the door and now the microwave runs all the time? Please help is this something i can...
Nov 04, 2010 | Microwave Ovens
The bottom of the door handle broke off. GE spacemaker xl
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Door wont open
After unplugging the microwave, I took the side/top panel off by removing the screws on the back*. Inside I found the piece that had broken off the part that pushes the door release. I then glued this piece back on using "Extreme Power" medium advanced performance instant adhesive. I bought this glue in a hobby shop in Richardson, Texas. I waited 12 hours for the glue to set. The door has been opening for the last two days.
*With the cover off, you can open the door by pushing the door release.
Nov 02, 2008 | Panasonic NN-C994S Convection/Microwave...
Broken Handle
On almost any microwave oven door if you open the door,on the inside part of the door,theres a square plate thats plastic that is a one piece unit that goes all the way around the edge of the door . That held on by little plastic clips that are molded right on the suround and easy to break, so take a small screw driver(of course the ovens unplugged by now) and start at one end and start prying it out inch by inch. Being care full not to crack it. If yop do crack it, you must replace it, but its not that expensive. Once you have off the cover surround, you will see the screws that hold on the handle. If you need help getting the part go to http://www.repairclinic.com as even if its not listed get the phone # and call them and they will assist you. Good Luck
Jun 03, 2006 | GE JVM1640 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
