Question about Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 TV won't turn on
I don't understand your question.
Are you inlet power supply to the TV? What are you asking me?
  • jsroda Dec 12, 2008
    Didn't get any answers. and did not respond back to my comments. Was not worth the $10. Was able to solve the problem with other resources.
  • Mable Kelley
    Mable Kelley Sep 27, 2011
    how did you solve
Sanyo 32" TV has no Picture sound fine.Model DP32746
Posted on Dec 08, 2008
TV turns off by itself(not sleep mode) usually turn back on sometimes unplug & try again in 5 min.s
This problems is the cause by the power supply board is dying.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 10, 2010 | Sanyo DP32746 32 in. LCD Television
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Dec 13, 2009 | Sanyo DP32746 32 in. LCD Television
Will not come on /nothing happens
you have a power supply problem, i will check the power supply first. maybe it is only a fuse.
May 19, 2009 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 screen black no sound screen flashes when turned on
Hello, I just posted this to another user's question, and you might find it useful, too.
I have a pile of these in my shop. Unfortunately and usually, a backlight lamp is bad, and the inverter board is damaged when it goes out. The backlight lamps are sealed inside the panel, so the usual method of repair is to replace the panel.
If you turn the lights off in the room, then turn the tv on, you will probably see a momentary flash of light from the backlight trying to start up. The lamps can be replaced, but the option is not really cost effective given the amount of time it takes to replace them/very delicate nature of the lamps/availability of the lamps/cost of the lamps. Replacement panels might be available, but you'd have to use a TV shop for reference or call Sanyo directly.
These units also have a history of power supply heat damage, so if you don't see the momentary flash, it could be the power supply. But the momentary flash is the dead giveaway.
I hope this helps you...
Dec 10, 2008 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 - No picture or Sound
Damage is in the power supply. I am an authorized tech for Sanyo, and in the Chattanooga TN area. Contact Sanyo at 1-800-877-5036. At the prompt hit the 0 key, and then ask for customer service. They will be more then happy to assist. If your set is to old for warranty service, and you wish to repair yourself, check out the site www.shopjimmy.com, they can provide functional pwb's for a fraction of the cost of new.
Jul 14, 2008 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 Power Supply
Yes replace the power section of the tv.
Jul 13, 2008 | Sanyo DP32746 32 in. LCD Television
Will not turn on?
You problem is in the power supply. I am an authorized tech for Sanyo, and in the Chattanooga TN area. Contact Sanyo at 1-800-877-5036. At the prompt hit the 0 key, and then ask for customer service. They will be more then happy to assist.
Jul 09, 2008 | Sanyo DP32746 32 in. LCD Television
Sanyo
Check the power cable and power socket. If they are working, and the indicator lights in the tv do not light up when connected to power, that means the PSU (Power Supply Unit) is faulty. Take it to a repairer.
Jul 26, 2007 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 32 in. LCD Television Logo
500 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
