Indesit w103 programme selector turns constantly, tried resetting
Tried resetting by holding power button while selector set to "Stop/Reset", and the light flashed 3 times and then blinked slowly.
However, the problem continues - selecting a wash cycle makes the pump go, but the drum does not fill, and then the selectoe begins turning quickly again.
  • Anonymous Dec 26, 2008
    We have the same problem. Occasionally the programmer keeps turning after we switch it on. We find sometimes if we turn it off and wait a few minutes before restarting that it proceeds fine but just want to know if there's a part or something we can replace easily to sort this out?
    stephen
barkencoa
  • 3463 Answers
SOURCE: Indesit WA6x washing m - dial clicking around...
This sort of problem is usually associated with a faulty control board
If there is a reset point on the timer, then reset it, and try again, if it still does the same thing, then it it is going to be the control board.
Posted on Mar 22, 2010
Testimonial: "thanks - good to know even if notgood news."
dazmaraz
  • 67 Answers
SOURCE: indesit W123 washing machine
it maybe your brushes are worn out, on alot of machines these days if the brushes wear the machine wont fill , or your motor itself could be faulty or your board. Unplug the machine , take the back off , get yourself a test meter disconnect the motor and put the probes from the meter and put it across the tags, if the motor is wrong you wont get continuity between 2 tags normally 1 and 5 looking from the top of the block going down
Posted on Mar 31, 2008
  • 177 Answers
SOURCE: No power - washing machine
Start at the outlet
Did it trip a circuit breaker?
did a GFCI outlet Trip:?
or did it blow a fuse?
Posted on May 03, 2008
SOURCE: indesit W1A111 starts cycle when selector set to "off"
hi i need a user manual for this machine. Where could i get one please. x
Posted on Jun 17, 2008
SOURCE: Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Posted on Jul 15, 2008
How do i reset washing machine AEG 64840
You can choose the right programme for any type of laundry following the descriptions on the washing programme tables (see «Washing Programmes»).
Turn the programme selector dial to the required programme. The programme selector determines the type of washing cycle (e.g. water level, drum movement, number of rinses) and the washing temperature according to the type of laundry.
The pilot light of button 8 starts blinking.
The selector dial can be turned either clockwise or anticlockwise. Position "0" to Reset programme/ Switching OFF of the machine.
At the end of the programme the selector dial must be turned to position "0", to switch the machine off.
If you turn the programme selector dial to another programme when the machine is working, the yellow pilot light of button 8 will blink 3 times and the message Err is displayed on the display to indicate a wrong selection. The machine will not perform the new selected programme.
Dado
Jan 15, 2015 | AEG Washing Machines
Hi i have an indesit w 123s washing machine, that set to any program it doesnt move on it just does that setting,then if you turn the machine off and set it to end program you can reset to rinse and the...
hello try restting it before you bin it
  1. Turn the washing machine off with the on off button.
  2. Turn the selector knob to a dot, or any off position
  3. Turn the washing machine back on and watch for rapid flashing on the neon light
  4. Turn the washing machine off and select the new program (or maybe spin)
  5. Turn it back on and the new program should start
NOTE: Resetting the timer selector knob as shown above may stop the clicking round, but if your washing machine has a fault, the clicking round may return when your washing machine encounters the fault again. If your washing machine's program selector knob is clicking round on its own, then read the section above Washing machine stops with lights flashing hope it helps
regards
shaun
Mar 13, 2011 | Indesit W 123 Front Load Washer
When I try to send a fax I get a redo message and no pages are sent...i have sent many faxes to this number....a message appeared after one page was scanned that said to prress clear and srop...i could not...
Please reset the Printer by following these steps:
Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
Release "Stop/Reset" while holding down the "Power" button.
Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
Push the "Power" button, then lift the MX310 cover open.
Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
Feb 27, 2011 | Canon MX310 Office All-In-One Printer
Device Selection menu stays on constantly and flickers...
sounds like a bad selector switch from the onboard card that has the console controls. my hitachi did something similar, and it turned out to be the board that the buttons are on
Mar 01, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
Error 5800 on Canon Pixma MP170
Solution #1 worked with my MP170 but it could be described more clearly, as follows:-
1. If the power is on, turn it off (press the on/off button).
2. Hold down the stop/reset button (red triangle in red circle).
3. Whilst still holding down the stop/reset button, hold down the on/off button.
4. Whilst still holding down the on/off button, release the stop/reset button.
5. Now press the stop/reset button twice, quickly.
6. Next release the on/off button.
7. Wait untill the LCD display shows “Canon idle” (this may take a few minutes).
8. Now push the stop/reset button 4 times in succession, quickly.
9. Press the on/off button twice, quickly.
10. Now press the on/off button to switch the power off.
11. Finally, press the on/off button to switch the power back on.
This sets the ink pad counter to zero, even though the pad still contains ink.
Remove ink from the pad, as follows:-
Open the lid of the printer to reveal the cartridge track and ink pad.
Winkle out the ink pad, using a pin or a small screwdriver or tweezers.
Wash the ink pad in clean water, squashing the pad to remove the ink.
Dry the clean pad by squashing it between sheets of kitchen paper.
Replace the pad, taking care to fit it between the alignment notches.
Amen!
Jan 09, 2009 | Office Equipment & Supplies
Dial keeps rotating
This a common problem with Indesit washers..
It is not a timer but a programme selector switch.
What you need to do is the following.
Switch the m/c on, let the drain pump empty the water, then switch the m/c off.
set the selector switch to one of the black dots on the dial, which is stop/reset.
Then switch washer back on, if the dial still keeps going round and round, then you are going to have to call an engineer, as you have what is called an Anomaly (fault).
Plz leave feedback for this solution.
Thanks
Dec 09, 2008 | Indesit W 123 Front Load Washer
Indesit W103 On program 7 starts to work then controller just clicks round and round by itself.
I've found you need to reset the program cycle for this. It's annoying to lose the soap and conditioner but generally, if you download the manual and follow the reset instructions (which for me also involved turning the machine off at the mains aswell as holding the power button down with the machine on stop setting) it usually works ok.
Nov 12, 2008 | Washing Machines
INDESIT WD10 WASHER N DRYER WATER WONT EMPTY PLZ HELP
I had exactly the same problem, found the answer on another website. The filter had a small sock stuck in it, stoppin the ppump from turning and draining the water out. Lever off the front panel right at the bottom of the washine machine, then unscrew the round black plug, lots of water will come out. Pull out the black thing and stick you fingers inside and pull out watever is blocking the pump. Turn off the electrics first. Mine now works fine again. :)
Mar 21, 2008 | Washing Machines
Indesit W1A111 starts cycle when selector set to "off"
many indesits have a memory on board, set the timer to off position, turn on the mains press start let the machine finish what it is doing, and it will reset normally, turn off at mains for a few minutes can also do the trick, it sounds like one of the option buttons was pressed and you didn't let the timer finish its course,
Aug 29, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
246 people viewed this question
Top Washing Machines Experts
