Lg tv no menu display - Televison & Video
  • 6 more comments
  • timlove Dec 03, 2008
    lg tv du-42px12xc can not get no menu the power light come on green after 10 blinks no sound no video when menu button is press notthing comes on the screen
    ok on the lg tv du-42px12xc im not getting anything no screen no rasta all i am getting when i turn it on the relay click the power light come on green no sound no video that the problem with this tv i unplug it for about 2 hours same problem
    that's the model #DU-42px12xc it a plasma lg tv
    this tv is 2 years old changing the adc board could that solve that problem
    ok wnen i press the menu button on the remote all i get is the power light which is green blinks and no menu on the screen also when i press it on the tv front pannel also nothing happens i know a little about tv i should get the menu on the set ok
    ok guys let me tell you all something i am a tv tech for over 20 years with sears and i don't you all can solve this problem thank you all guys
    i know what the problem with the tv i just want to know if you all guys know what you all are doing or only taking people money and say you all solve the problem because you all ask me alot of dum question if the tv is plug on and i told you all the model # i told you all the green power light is on why ask dum question
    that is not so good try doing better
  • 2,326 Answers
If you have experience with TVs, then you can open the back cover and check the voltages from the power supply to the other circuitry. If the video is missing more likely a Y sustain board might be defective. If you find one of the fuses blown on that board; please post the assembly number to see if that can be fix to the component level.
Posted on Dec 03, 2008
  • Jaime Hernandez Dec 03, 2008
    Having 20 years experience swapping boards at sears should be good enough to know more or less what is wrong with your plasma and not pay for assistance.
    Genius:
  • 1,011 Answers
Sir,
check whether the tv is turned ON
Is the power cord inserted into wall power outlet?
Test the wall power outlet, plug another product's power cord into the outlet where the TV's power cord was plugged in.
might may be problem with power supply board. contact for help
COMPLIANCE:
The responsible party for this product’s compliance is:
LG Electronics U.S.A., Inc
1000 Sylvan Avenue, Englewood Cliffs, NJ 07632
1-201-816-2000
  • Asfiya Ahamed
    Asfiya Ahamed Dec 03, 2008
    the green light blink is for Lamp Replacement. Check with the lamp. Replace lamp it will be OK
  • Asfiya Ahamed
    click this link for more information
  • 4,889 Answers
A few more details would be more helpful. Whats the model number? And what exactly do you mean by no menu display?
  • eagle338
    eagle338 Dec 03, 2008
    Right. It looks like Y-sustain board or the PS board problem. Difficult to tell without testing the set. Usually the Z board goes bad soon after the Y-board. So you might have to replace them both. Remember there's no such thing as an instant solution... Rate the expert who helped you get close to the problem.
    Thanks,
    Sai.
  • 1,800 Answers
Sure we can help but we need more details.
plz do not rate till we give solve ur problem.
  • Jalal Sordo
    Jalal Sordo Dec 03, 2008
    change your adc(analog to digital converter) board will help out.
    its not an easy task but u shud take it apart and locate it first.
    and i am not sure that u may get harm or making more damage to TV!
    Genius:
  • 1,550 Answers
You need to provide model number details .
Just try hard reset .
Unplug the power chord for 30 minutes and plug back the power chord to tv .
  • SAM ANDERSON Dec 03, 2008
    You need to replace PSU board .
  • 19,396 Answers
TRY FIRST UNPLUGGING THE POWER CORD FOR TEN OR TWENTY MINUTES.
In the meanwhile give me more details on your problem, it is not clear.
Do you get channel picture?
Is tv on standby?
Is just the remote not working?
  • 3 more comments
  • Ginko
    Ginko Dec 03, 2008
    You need to get a technician testing your TV, I told you.
    You need somebody that can read voltages and test components working on your TV without destroying it.
    The problem is probably the PSU, try powering off the set, if light stays red instead of green it is either the PSU or one of the two sustain boards.
    Both components should be tested.
    See the service manual here
    and have fan.
    Unless you find an easy repair, with a faulty cap on PSU board, or a blown fuse on Ysus , Zsus, and you have a solid background in servicing electronics and TVs, take the unit to a repair shop and have it fixed.
  • Ginko
    Ginko Dec 03, 2008
    Now I do not want to seem rude, but you do not fix a tv the way you think.
    This is not a desktop PC were you replace a $20 PCI card and fix a problem.
    You need to test components inside , and some of the test is dangerous for your TV and for your safety.
    On a plasma TV you have high voltage running, and you can get heavy discharges even when TV is unplugged.
    Before damaging the TV , or wasting few hundreds dollars on the wrong board I suggest you calling the number listed on the owner manual and asking the cost of a warranty extension, or a repair.
    The TV is relatively new, and a warranty extension, if available will be less expensive than a single repair and will cover your TV for one extra year or longer.
    Regards.
  • Ginko
    Ginko Dec 03, 2008
    One last hint, some of the guys anwering you, like the one that said
    "the problem which u stated is due to the faulty capacitor or ic on the
    board that needs to be replaced by checking on the board that which 1
    is faulty.also it could be because of the small fuse of the tv gone
    dim.or loosing its power.as u said u get the green power on the front
    led this says that fuse is not blown off completely."
    Do not have any technical knowledge, the guy is an user, surely with less knowledge then you, and is just posting his thoughts, the answer did not make any sense.
    Call the phone number first, if you want to do it yourself, and the led turns green , then it is usually PSU, Y sus or Zsus, all components must be tested before replacing.
    If you DIY dont attempt testing voltages, just test fuses and resistors for continuity and inspect components on power board.
    This is more than enough for a newbie.
  • Ginko
    Ginko Dec 03, 2008
    Well if you are a tv tech, then the problem is fixed, test the power caps on the PSU, test the voltages and the fuse on the two sustain boards,
    All you need is the service manual here .
    On the service manual you find how to test Ysus and Zsus
    less than one hour and the job is done.
    You can find replacement parts here.
    ShopJimmy
  • Ginko
    Ginko Dec 03, 2008
    I am sorry sir , but your point is not clear here, you knew what the problem was , and you ask me just to know if " if you all guys know what you all are doing or only taking people money and say you all solve the problem "
    And your conclusion must be that by telling you what the fault is, and wasting my personal time , "I am taking people money".
    That is rude and abusive sir, I charge a lot of money to fix a plasma TV. I cannot understand how you can afford to come here, waste your and our time, and end up insulting everybody.
    I told you that some (and I mean some) comment is from users with no technical background, they are supposed to be tech support.
    You have at least three electronic answering you and wasting time on your little joke.
    I am sorry sir but we have better things to do, all the support and the solution is on this thread, you should be entitled to no refund in my view.
    Goodbye, and enjoy the service manual that on the market is worth $25 or so.
    Sergeant:
  • 217 Answers
Give the exact model number of the tv.
  • llincon Dec 03, 2008
    the problem which u stated is due to the faulty capacitor or ic on the board that needs to be replaced by checking on the board that which 1 is faulty.also it could be because of the small fuse of the tv  gone dim.or loosing its power.as u said u get the green power on the front led this says that fuse is not blown off completely.
  • 586 Answers
   Please call 1-201-816-2000 to locate your
nearest LGE Authorized Service Center.
Visit our website at:
http://www.lgservice.com
Thanks
What's wrong with my LG 55LV9500 LED TV? Power on, black screen.
Hello, either the power supply is failing to power up the LED's or the LED strips in the screen have failed, a common issue with these sets. Power supply part # is EAY62169701. LED strips are only available as a complete screen assembly from LG....thanks
Apr 23, 2017 | LG Televison & Video
Best way to remove a parental lock from a lg plasma tv
LG Service Menu Instructions
Method 1
Press and Hold <OK> button on remote as well as TV panel at the same time for a few seconds.
Method 2
Press and hold the {MENU} button on the remote and the {MENU} button on the TV at the same time for at least 5-7 seconds.
Method 3
Press and hold the {MENU} button ON THE REMOTE until a 4-digit password screen is displayed.
LG Service Menu PIN/Password Codes
  • 8 7 4 1
  • 8 7 4 3
  • 7 7 7 7
  • 0 0 0 0
  • 8 8 7 8
  • 0 4 1 3
LG LCD Monitor Service Menu Instructions
  1. First turn off the lcd monitor, then press and hold the "MENU" button, then turn on the monitor. Release MENU button after the monitor is turn on.
  2. Press "MENU" button to open the OSD menu, at the bottom of menu, you can see a new selection to go into the factory service mode. Inside the factory service mode, you can see useful information like, product model, manufacturer date, F-ENGINE chipset version, lcd panel number and etc.
Mar 16, 2016 | LG Televison & Video
Lg tv cf20s12e
CHECK TV OSD(ON SCREEN DISPLAY ) SETTING
Jul 19, 2013 | Televison & Video
LG 47LG50 Program Menu displays on its own without remote control or manual inputs.
Thats the IR board. You can get the IR board along with the button assembly at the following link for your model its 15.00 just scroll down the page. It also may be the main board that has the issue if it is you can also get the main board there also its 84.00
http://tvrepairworld.com/lg__zenith_lcd__plasma_power_supply_boards
Dec 16, 2012 | LG Televison & Video
LG TV MODEL 442L0520 SERIAL 005RMKUA3341 PICTURE IS TOO BIG FOR THE SCREEN,K TOP AND SIDES CUT OFF. WHEN WATCHING SPORTING EVENTS, SCORES CANNOT BE SEEN.
You need to go into the TV menu and change the settings for the display! Press the Menu button and adjust the Picture! It's probably set to automatic and not reading them correctly.
Sep 28, 2010 | LG Televison & Video
Lg lcd tv and the liquid crystal display light is on
U have cables,satalites or telicom compannies pay services?Unplug the tv and any of those services box about an hour,replug both back let the box upgrade it software.Turn on the tv.The tv push the button on the remote said Menu.PICTURE go down to reset,the tv now reset it back to factory setting.The air broscasting signal,now should on ur tv.
Jun 23, 2010 | LG 37LC7D 37 in. LCD HDTV
TruMotion Demo
If anyone else has the same problem it can be sorted by going into the main menu - select display - select advanced at the bottom of this screen - in this menu you can turn on/off the trumotion demo.
Jan 29, 2009 | LG Scarlet 42LG6000 42 in. HD-Ready LCD TV
LG HD Digital Video Recorder LST 5402P has stopped displaying menu onscreen
first i assume you are trying to watch the unit through AV. If this is the case, turn on unit, press "Display Format" on the front of the unit, keep press it till you have "YPBPR" displaying, press select on front panel, next press "Display Format" again till you come to 576i, press select. Now press menu and it should display. If this problem occurs with HDMI, simply change the display settings to HDMI, and 1080i. Hope it helps, Murder-face.
Jan 13, 2008 | Televison & Video
Televison & Video Logo
249 people viewed this question
Top Televison & Video Experts
