Question about Frigidaire FGF378AC Gas Kitchen Range
One stovetop ignitor doesn't work: the gas comes out, but no clic
Frigidaire FGF378AC Gas Kitchen Range ignition
    Habit-Forming:
  • 171 Answers
There is a swich behing the knob that turns on the ignition, it most be replace. every burner has one of those swiches, when you remove the knob you can see it, it's white in color about an inch long.
Posted on Dec 08, 2008
Pilotless ignition wont turn off wont stop clicking
You will need to replace the ignition switch assembly. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 12, 2012 | Frigidaire FGF378AC Gas Kitchen Range
Gexl44 gas range, oven stopped working for no apparent reason, stovetop still works just fine, no gas smell
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Feb 04, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Broil on gas oven runs for a few minutes then pops, goes out then relights. flame come sright back to gas orfice, any suggestions
Oven not Working or Oven not Heating
heatman101
Nov 24, 2010 | Frigidaire FGF378AC Gas Kitchen Range
Model FGF326ASD. Gas oven igniter glows but no gas there to light. What controls the gas valve in the oven?
From what I can see on the web, all point to a weak "glow ignitor," some says that the glow ignitor can glow and sometimes can even be drawing the correct current but still not hot enough to ignite the gas. Tho one thing I don't understand is how can a ignitor range in price that much... I can find one online for $16 to $50... local appliance part stores wants $70 - $80 for it... and its not refundable...
Jul 29, 2010 | Frigidaire FGF378AC Gas Kitchen Range
Frigidaire oven wont ignite
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 29, 2010 | Frigidaire FGF378AC Gas Kitchen Range
I have frigidaire gas free standing oven range.When I press BAKE and set the temperature,the preheat and oven lights both lit on the display and I can see the ignitor red but no flame.
If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Nov 02, 2009 | Frigidaire FGF378AC Gas Kitchen Range
Older frigedaire range oven quit working
the problem is in the ignitor it is not pulling enough amps to open the safety gas valve even though it glows doesnt mean it is good
Jan 07, 2009 | Frigidaire FGF378AC Gas Kitchen Range
Frigidaire 337 range
regulators are where the gas line coming from the house behind the stove conects to the stove. it's square about 2 inches by 2 inches.
Nov 24, 2008 | Frigidaire FGF378AC Gas Kitchen Range
Frigidaire FGF378AC Gas Stove
There are 2 possibilities:
1) Are there 2 knobs to control the oven? If so, they may be switched.
2) Depending on the thermostat used, it may be possible to put the knob on upside down.
Jan 22, 2008 | Frigidaire FGF378AC Gas Kitchen Range
Oven won't start
If you look at the oven igniter in the bottom portion of the range, (where the gas controls are) look to see if the igniter is glowing hot. If not, replace your igniter. This is the part that starts the burner and keep it lit. When you get a new igniter DO NOT TOUCH THE ELEMENT PORTION of the igniter. Or it will pre-maturly fail. Good luck.Hope this helped ya!
Dec 07, 2007 | Frigidaire FGF378AC Gas Kitchen Range
Frigidaire FGF378AC Gas Kitchen Range Logo
262 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
