Question about HP Photosmart 2410 All-In-One InkJet Printer
Err. mess.: pr. cartridge on right side is wrong type/uncorr inst
Nothing works, the whole area, buttons on, copy, scan, fax and photo are blinking. All conventional methods of turning off / pressing cancel button give no results. What can I do not to have to throw it directly into the garbage? I really liked it up to now. Thanks
  • 781 Answers
You probably may want to uninstill the software and printer driver. download a possible updated driver and sofrtware from here:
http://h10025.www1.hp.com/ewfrf/wc/solveCategory?lc=en&dlc=en&cc=us&product=303753
and follow the instructions to install the cartridge, driver and software then retest.
Posted on Dec 10, 2008
Error e000002
addntl func
2&8 (at the same time)
addntl func
at this point the screen should change. If not hit reset button and try again.
copier
func
clear
err
ok (in the lower right hand corner of screen)
Turn power off and back on. (black switch on the right lower side of copier)
DO NOT ATTEMPT TO DO ANYTHING ELSE IN SERVICE MODE! YOU CAN REALLY MESS UP YOUR COPIER BEYOND REPAIR IF YOU DO!!!!!
Mar 09, 2015 | Canon IR2535 Copy Machine
Black band down right side of page when copy or fax
Most common cause for a band on copies or sent faxes is debris on the scanner glass. A cotton swab dipped in rubbing alcohol will usually work in cleaning the scan area. After cleaning the area, allow it to completely dry prior to testing the machine.
Feb 21, 2011 | Office Equipment & Supplies
My fax type hp laserjet 3015 display a very big line (blanket of line) on the right hand side of the paper, and the left hand side is normal. This problem is observed in the received fax and during...
The mark is not being produced from the toner cartridge or scan mirror. The line is being produced by the Drum unit. You need to replace it.
You can purchase one online or at you local stationery retailer.
Hope this helps.
Best regards,
Dave
Please vote if this helped
Nov 26, 2010 | Brother IntelliFAX 2800 Laser Fax
My lexmark 7170 printer has error message : right cartridge incorrect. I pulled the brick. Waited a few minutes, replaced but error still appears. Turned off and on etc. Lexmark quide was not helpful. any...
You are trying to put the wrong catridge into right hand side,. the catridge you have put is incorrect. try removing the catridge and put the right catridge back
Jan 09, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Brother MFC 8220 all-in-one fax prints with a vertical line
First guess is you have a bit of dirt (often white-out from people scanning corrected paper that's not quite dry) stuck on the fax scan window. This should be described pretty well in your user manual (which you can download online from brother.com).
Its also possible that there is dirt (typically loose toner) on the laser scan window (there's a laser that shines through it to get the image pattern on the drum). That window is often along the bottom of the unit under the drum/cartridge (take the cartridge out and look). The Brother manual I've seen seems to ignore this possibility.
Print streaks DO NOT mean cartridge drum replacement in many cases !! On brother Intellifax or MFC or other laser copier/printer/fax, keep in mind that either the fax/copy scan window OR the laser scan window can get dirty. If the fax scan window is dirty, you see streaks on outgoing faxes and copies (but NOT incoming faxes). If the laser scan window is dirty, you see streaks on all prints (copies, faxes, print-from-computer).
Note also that when transporting/moving some laser copier with the toner cartridge inside, the toner can get out and make a big mess inside (including getting the laser scan window dirty). An air compressor can be usefull to blow it out. And sometimes using alcohol to clean is a BAD idea (maybe incompatible with plastic and rubber parts). A damp rag is probably fine.
Nov 21, 2009 | Brother Office Equipment & Supplies
Message wrong cartridge on lexmark 7170 printer
for Lexmark x7170 ink cartridge is #32 and #33.
double check the number on the ink cartridge. and make sure to take the tape off the bottom of th eink cartridge before insert it in the cradle.
as far as the cleaning. there are contact pins in the ink cradle and on the bottom of the ink cartridge.
clean them using a coffee filter with little alcohol.
Dec 03, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Remove and Check Cartridges
Hiya timcarter1... Clear tray of any paper...would suggest you are ceratin that the cartridges are engaged! Otherwise try doing a reinstall of your software... and are you using generic cartridges " copy" rather than the branded ones .. tends to result in same message!
Regards Faggly
Mar 19, 2008 | HP PSC 2210 All-In-One InkJet Printer
Remove and Chk Cartridges
Hi Timcarter,
Please click on the web link given below and perform the following as given in the web link.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00055502&cc=us&lc=en&dlc=en&product=79499
This will help you fix the issue.
Photos
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
Jan 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
Printer cartridge
try a new cartridge, or try cleaning the contact inside where the cartridge sits.
Jun 04, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
HP Photosmart 2410 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
