Question about Shure SLX-2 Handheld Wireless UHF Transmitter SLX2B87AH5 Microphone
Fingernails have mangled the rubber on-off button. Replacement?
Bought 3 of these a year and a half to two years ago for my church.
The rubber on-off button on the PGX2 (616A-SLX2) has been destroyed by people using their sharp fingernails. The unit works fine aside from that.
Where can I get a replacement (maybe more than one) ???
  • Anonymous Dec 08, 2008
    How do you replace them? How is the switch/LED cover removed so that the rubber button can be installed?
Hmmm...apparently this is a common problem. So common, all you have to do is call the Shure parts ordering line (800-516-2525 opt 3), and ask for the "rubber button" for the PGX2 (SLX2) handheld transmitter. They are 81 cents apiece, but with a $10 minimum, you will end up buying six (or more).
Posted on Dec 04, 2008
ORLA R610 factory reset keys
hi there try Hold down the 4 Lowest Keys on Upper Manual C C# D D# hope this helps you
Jan 06, 2012 | Computers & Internet
After using the computer twice,it stopped working.we changed batteries to no avail. it was bought dec2009.smyths was contacted where it was bought,but couldnt be replaced as it had gone out of stock....
Usually the manufactures warranty covers material defects for a limited time, and ranges from 90 days to 3 years. I have never seen a warranty for a computer more than 2 years personally, and you bought the computer 8 years ago. Unfortunately I think you will need to pay for the repairs yourself.
Dec 01, 2017 | Bob The Builder Toys
Where to find tasco 3 x 9 40 rubber armored scope
I have an original Tasco rubber armored sope that I bought over 20 years ago. It is Japanese made very good quality comes with the special rings made just for it. It also has lens covers as well. I will it go for $40 dollars. you can reach me at dacroce@hotmail.com. Thanks, Dennis.
Nov 13, 2010 | Tasco Golden Antler 3 - (9 x 40 mm)...
Cnt download music doesnt show on computer
Is the problem that you have music in the HCSD and can not get it into your computer because the computer does not see the SD card?
If yes, many older (and not that old) computers will recognize the HC vesrions of the SD cards. My computer that I purchased about a year ago has no issue with them, another computer I work on at church, bought 3 years ago, will not recognize it. I think it has more to do with the card reader than the computer itseld though.
Upgrading the card reader may solve your problem. determine the manufacturer of the card reader in your PC and go to thier website to see if updated drivers or firmware are available.
Peace,
Mar 07, 2010 | PNY 4GB Secure Digital High Capacity...
I bought a Toshiba DVR about 3 years ago and ever sence I bought it, it has never recorded anything on any DVD+R OR DVD+RW that i could find and it will not even play already recorded dvd's or play half of...
Don't understand why you didn't take it back and ask for your money back 3 years ago? I suggest you go to an legal advice center and see if you can still do something about it.
It sounds like the lazer or lens could be faulty. However it could be just a bad soldering joint.
Jun 20, 2009 | Toshiba DR4 DVD Recorder
Turntable belt drive keeps slipping off.
I have a Linn LP12. At least in the case of my turntable, that's just how you are supposed to use it (i.e. this is what the manual says). You could get a replacement belt f you like, but I would guess it will not make a difference - that is, I think you do not need a replacement belt.
However, in my case I don't have to be very careful about the start-up push on the turntable, just one tweak to get it rotating at about the right speed is enough in my case.
Mar 10, 2009 | Thorens Audio Players & Recorders
Can't Print on Card
I had the same problem with my 3 year old HP Officejet 5610. Feeding heavy paper or white card stock would result in a paper jam. The card stock would start to feed, but then stop half way. The pinch rollers seemed to spin without advancing the paper, even if the paper was fed one sheet at a time.
Solution: Clean the rubber pinch rollers with isopropyl rubbing alcohol. Partial disassembly/reassembly required.
To access the rollers, remove the scanner plate:
1. Disconnect power, USB, and phone cables.
2. Open up the scanner sheet feeder by tilting it left.
3. Unlatch the scanner scanner feeder so that it opens completely vertical. Latch is on front hinge only.
4. Remove the 4 corner hex screws on the scanner plate. Remove the 2 hex screws on the sheet feeder. (I used a small flat blade screw driver in the hex heads)
4. Lift the plate and sheet feeder away from printer box. Disconnect the 2 flat cable wires from the circuit board.
5. Scrub rubber pinch rollers with alcohol on a swab. Dry thoughly.
6. Reassemble. (NOTE: This is a good time to clean the underside of the glass plate and the scanner head)
Oct 18, 2007 | HP Officejet 5610 All-In-One InkJet...
274 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
