Question about JVC AV-56WP30 56" Rear Projection Television
Bad Picture The picture is showing doubles, with a reddish outline. It's definately with the TV, as I tried watching a DVD, and it did the same thing. It also reflected the same picture distortion when I watched DVR.
    President:
  • 1,284 Answers
You need to replace the convergence output IC's. I believe they are STK392-110's and there are ususally resistors that are opened due to faulty IC's. The IC's are located on a board behind the large speaker grill on front. There are 6 screws to remove to access the IC's. 4 in the back and 2 small screws behind the litte door on the front.
Posted on Feb 04, 2007
32" LCD Samsung TV:
See: http://www.fixya.com/postanswer.aspx?thid=9399346&prdid=0&ctgid=8&ref=unsl
Jun 06, 2011 | Computers & Internet
Double picture...not focusing right
maybe parts inside is worn out. causing the blurrines. just consult to your service center.
Jun 19, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Every thing looks doubled
On board above your Chassis it has a regulator IC
STK730-010? replace it! Call Mats Electronics 1-800-628-1118
Jan 06, 2010 | RCA P52926 52" Rear Projection Television
Hitachi 46F500 TV has red and blurry picture.. what to do?
If this problem has been gradually getting worse, it is most likely to your picture tubes getting weak, and it is time to replace the set I'm afraid.
If the red is smearing off to the side of reddish objects in the picture it is most definately the tubes.
Nov 02, 2009 | Hitachi 46F500 46" Rear Projection...
Hi!! my sony projection tv kp-51ws500 shows double picture. there is reddish outline & its out of focus. i need help to reapir this. please advise. thanks
This sounds like a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400
Sep 30, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony kp57hw40 tv blurry image,
Yes, you have a bad convergence Ic--set uses two of them---have someone change both and adjust the set in the Tech menu--if you need more information or help email me etower.766@netzero.net---
Aug 09, 2009 | Sony KP-51WS500 51" Rear Projection...
Red outlines around, and zigzagging thru the picture.
If you were to put an all white image on the screen, would there be evidence of this red color in the picture? If so, its likely that the light engine has gone bad. One or more of the LCD panels inside has been damaged by the heat from the lamp. This is an expensive part to replace. It never hurts to contact the manufacturer for assistance.
michtech
Feb 06, 2009 | Zenith E44W46LCD 44" Rear Projection...
Studioseries (samsung) 42" rear projection tv red duoble outline of picture
sounds like the red convergence Ic is weak ready to go out. try replacing the ICs around 10.00 do the blue as well as that will be next.
Mar 18, 2008 | Samsung HCM4216W 42" Rear Projection...
Picture turns into looking like a reverse negative
Often you will get a bluish or reddish looking picture if your wires from your cable box/satellite or DVD player are inexpensive RCA type video cables. Try using a nice set of component cables or HDMI cable from your sources to your TV. If this is your setup, try this first...its the most inexpensive first option.
Dec 31, 2007 | Hitachi 36UX59B 36" TV
JVC AV-56WP30 56" Rear Projection Television Logo
43 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
