Question about Kenwood KDC-MP228 CD Player
No memory every thing resets when car turns off
    Problem Solver:
  • 10 Answers
Did you in stall by your self?? Sounds like you may have taking the memory yellow wire and with the red wire Primary switched and hooked them to the switch (Acc) on the harnes . Try looking at the harnes and see if the harness from the radio to the fact harnes hass a yello or red wires . Un hook them and try them in reverse
Posted on Dec 03, 2008
2002 Isuzu Trooper reset check engine light how
you can reset any vehicle code by taking off the negative (black) lead off from battery for 30 minutes. make sure it don't touch anything else. if you have light on go to your local auto parts place and have code checked before hand. resetting light will also reset all codes and delete them. why is the light on?
Dec 01, 2016 | 2002 Isuzu Trooper
How to reset fuel pump on 2005 bmw 3x
I cant thin of a good reason to perform a "fuel pump reset" if there were such a thing?
Understand, the fuel pump is simply a tiny motor in the fuel tank that pushes gasoline out for the engine to use. It has no memory, no settings, or adjustments (for the most part, some newer ones do regulate w a duty cycle, but the pump is still a simple motor).
If you are having problems with starting or acceleration and it may be fuel related, the best thing you can do is get it scanned and or tested mechanically by a technician with access to an enhanced BMW scantool.
As to the fuel pump reset, there really isnt such a thing...fuel pump;s always work with the kjey and engine rpm UNLESS something breaks, or the alarm/theft system disables fuel. Thjere are no fault codes that turn off the fuel pump on your vehicle, so no memory to erase to ruen it back on or change its operation.
Apr 13, 2015 | BMW Cars & Trucks
Error Insufficient Memory
Try a Factory Reset or turn the phone off for about 2 hours or overnight if you can.
Jul 13, 2014 | Samsung Galaxy Axiom
Turn off torch light
try to reset the phone using the code *2767*3855#......it automatically gets reboot.
but the thing is ur phone gets reset so ur phonenumbers, msgs, images, videosetc saved in the phone memory will be deleted....so better take a back of phone memory and the go 4 th reset....
Oct 30, 2011 | Samsung SGH-G600 Cellular Phone
When i turn my nokia 6303 off it resets everything. my phone memory is not working.all contacts saved in phone memory are not available and new contacts are not saving.phone memory shows empty but when i...
You could try a full Factory Reset - by going into settings and selecting Restore to Factory Default.
If this does not fix the issue then you may have to take it back to the shop you purchased it from as you will have a 2 year warranty.
Dec 16, 2010 | Nokia 6303 Cell Phone
I cannot seem to cancel an old job stuck in there. I have hit cancel, powered off and on, unplugged. Everytime I try to print a new job it puts out this old one.
moz-screenshot.pngThe best thing to do is do a memory reset. But this could also clear pages and formats, user defined characters and fonts, configurations,tables,or all of these parameters.
To reset memory
1.Turn off the printer.
2. Set the DIP switches to reset a portion.
3. Press and hold the Feed/Pause button while turning on the printer. The printer prints out a hardware configuration test label.
4. Hold the Feed/Pause button for 1 second. The printer resets a portion or all of its memory.
5. To exit test and Service mode, turn off the printer.
6. Reset the DIP switches to their original setting and then turn on the printer.
That should do the trick.
Sep 13, 2010 | Intermec EasyCoder 4420 Thermal Label...
1999 cadillac deville a/c off low refrig error
I had the same problem. The mechanic could not get the compressor to take in new freon. It has to do with the car's memory. You have to reset it by disconnecting the hot wire from the battery which for thirty seconds. This resets the cars internal memory, so it won't remember that it's out of freon. Reconnect it turn on the car and turn on the air the compressor will start.
Apr 26, 2010 | 1999 Cadillac DeVille
Image memory overflow
Hi Sidewinds you need to purchase additional memory for your copier. A basic copier only has 20mb of printer memory hope this helps regards Dr Bob1 (uk)
Jan 31, 2007 | Panasonic Workio DP-4530 Copier
Kenwood KDC-MP228 CD Player Logo
70 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
