Question about Refrigerators
Freezer and refrigerator are not cooling
The refrigerator and freezer was not cooling when it was in the mid temp after i increase the temp it seems to be working after two weeks, then it does not seem to work anymore. the fan is working just fine and we clean underneath the coil with all the dust and free-on it does not seem to help. can you help please My freezer was not cooling and then it went to the refrigerator side. I have turned it off and then it would work again for a day or two but then have no cooling at all. I cleaned the coils and tried again but with no luck. When turned on, you can hear the motor working and but it doesn't cool either side.
We called an appliance repair company and it was the Control Panel that was causing the problem. $317 later it is now working properly.
Posted on Dec 04, 2008
How to set freezer on LG Bottom Freezer LRFD22850
Hello Fran Miller,
For OPENERS... (my opinion)
always start by setting you temperatures at mid range.
Owners manual... Page 16
Setting the controls 16 - 17 Adjusting control settings...
http://www.searspartsdirect.com/partsdirect/user-manuals/LRFD22850ST-LG-Parts-Refrigerator-Parts-manual
I get a little PUSHY about FOOD TEMERATURES...
(stored poorly there's no quicker way of poisoning ones self)...
I strongly recommend getting TAYLOR refrig/freezer
THERMOMETERS (like Amazon... cheap = $6 ea).
Let the refrigerator stabilize EMPTY 24 HOURS
Loaded with food (not recommended: 72 hours).
ADJUSTING CONTROL SETTINGS
Give the refrigerator time to cool down completely before adding food. It is best to wait 24 hours before you put food into the refrigerator. The mid-settings indicated in the previous section should be correct for normal household refrigerator usage. The controls are set correctly when milk or juice is as cold as you like and when ice cream is firm.
THERMOMETERS
Amazon com Taylor Refrigerator Thermometer 20 Deg To 80 Deg 3 1 4 3 3 4...
Hope I am helping
Carnac the Magnificent
Jul 11, 2017 | LG Refrigerators
Freezer temp. seems to go up and down, creating ice buildup near the ice maker. Unsure of proper temp settings. Pls advise.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 28, 2010 | Refrigerators
For the temperature, to make it colder to we turn the knob towards the higher numbers or lower?
Normally the lower number is more cooling and hence the setting is ideal to be kept at mid point.
In twin door adjustment witth single control lower setting more cooling to freezer and as it goes up the temp of the fridge increases.
So you might need to recheck with this model
Sep 16, 2010 | Avanti 308YWT Compact Refrigerator
Temperature control of refrigerator/freezer not working
Let me know if the compresor and the condensing fan motor works beacause most of the times the problen is not in the temp control.But if you whant tomake sure that the temp control works or not you can pull the two wires out from the temp control and put a jumper wire between them and if starts cooling you just need to replace it
Apr 21, 2009 | Refrigerators
WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH
You need to look inside the freezer at the rear wall cover and see if it is frosted over. If your refrigerator is not defrosting that can cause the refrigerator side and the freezer side also not to cool to the desired temp.
Mar 30, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
My refrigerator does not cool properly. The freezer does not have ice built up and the fan is working, I can here it blowing when i open the freezer. The freezer almost works too well, it is at its lowest...
The lowest setting in the freezer compartment may be set to cold holding back cooling to the refrigerator. Try your settings at mid-point on both refrigerator and freezer settings.
Dec 05, 2007 | Kenmore 73503 Stainless Steel Bottom...
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
