Question about Pioneer PD-F1009 301-Disc CD Changer
U1 FAULT CODE
The player wont load,the door opens but the main mech' doesn't turn. U1 then displays itself on the led display,i'm sure this indicates a problem with the unit.I guess i need to know, is this something i can fix? or does a tech' need to look at it? The unit belongs to my sister who moved house last month,but didn't remove cd's from unit(all 300) of them,and as you would imagine,they all fell out! I live in Australia where this player is called a Pioneer pd-f1007. I look forward to a positive reply as my sister wont stop calling me. Cheers!
  • wchin Nov 15, 2007
    Same problem happened to my CD player, after a move, all the CDs got jumbled in the carriage, and I had turned it on without noticing that, then I emptied out all the CDs and the U1 warning came on. The carriage is stuck at position 204 in front.
  • Anonymous Jan 04, 2008
    Sorry I don't have an answer. I have the exact same changer and it is also stuck and won't respond to remote or manual efforts. The authorized repair service listed by Pioneer does not repair this changer. They have attempted to remove their name from the Pioneer list of authorized dealers for CD changers without success.I am taking it to a local repair shop and they believe they can fix it with a minimal of effort and expense. I don't want to scrap it just yet. I like the way it works when it did work. It is two years and three months old. Warranty only good for one year. I'll post a follow-up after I get the unit back next Wednesday. Ray
I had this same problem today.
unplugged it
took off the cover screws ..2 on each side and 3 in back on top
in the middle of the unit there is a white arm with a tab on both sides
it lifts the cd into the middle to be played
the white tab had come out of the slot it was suppossed to be in on the black cd arm
just carefully ease the tab back into the slot and its like new
Posted on Jan 06, 2008
  • szalaish Dec 07, 2010
    I've done this three times now. The problem is that after playing twenty or so CDs, the white arm has now popped back out three times now. Any solutions to that? That is, any solutions to make it not pop back out? It is very easy to fix, but it's still a pain to have to do when you'd rather just be listening.
  • Victoria Richardson Sep 18, 2013
    SS123 - Thank you so much. I can't believe that you figured this out yourself because it is really hard to see that the white tab needs to move over almost 1/2" to the left to fit into the vertical black slot! You saved me a lot of frustration - the machine is 11 years old and who knows where to get it serviced.
This worked for me today!! Thanks for posting the solution!
Posted on Nov 20, 2009
This helped me as well. Thanks!!!!!!!!!
Posted on Aug 10, 2008
My Maytag front load washer , powers up and lets me change the settings, but when I press the start button , it beeps and displays d5 and wont start??
this fault code ind a door lock problem ,hence this is why it wont start , it thinks the door is not closed , id say the door latch mech. needs service
Feb 26, 2016 | Maytag Neptune MAH9700 Front Load Washer
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
Hi I have a panasonic split air conditioner. It turns itself off immediately after turning on, the timer button then flashes and that's all.... I have checked for an error code it is H00. I have also made...
Hi Tania,
Have you gone through this checking sequence.? it's from a Panasonic a/c manual. It could be something as simple as a clogged filter. Once you have rectified the fault, you will probably have to clear the fault code as described at bottom below, before it will condescend to work again.
David
  • Once error occurred during operation, the unit will stop its operation, and Timer LED blinks.
  • Although Timer LED goes off when power supply is turned off, if the unit is operated under a breakdown condition, the LED will ON again.
  • In operation after breakdown repair, the Timer LED will not blink. The last error code (abnormality) will be stored
    in IC memory.
14.2.2 To Make a Diagnosis
  1. 1 Timer LED starts to blink and the unit automatically stops the operation.
  2. 2 Press the CHECK button on the remote control continuously for 5 seconds.
  3. 3 "- -" will be displayed on the remote control display.
    Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
  4. 4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed and signal will be transmit to the main unit.
  5. 5 Each press of the button (? or ?) will increase error code number and transmit error code signal to the main unit.
  6. 6 When the latest abnormality code on the main unit and code
    transmitted from the remote control are matched, Power LED will
    light up for 30 seconds and a "beep" sound (continuously for 4
    seconds) will be heard. If no codes are matched, Power LED will light up for 0.5 seconds and no sound will be heard.
  7. 7 The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5 seconds or operating the unit for 30 seconds.
  8. 8 The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
14.2.3 To Display Memorized Error Code (Protective Operation)
  1. 1 Turn power on.
  3. 3 "- -" will be displayed on the remote control display. Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
    unit.
  6. 6 When the latest abnormality code on the main unit and code transmitted from the remote control are matched,
    Power LED will light up for 30 seconds and a "beep" sound (continuously for 4 seconds) will be heard. If no
  8. 8 The same diagnosis can be repeated by turning power on again.
14.2.4 To Clear Memorized Error Code after Repair (Protective Operation)
  1. 1 Turn power on (in standby condition).
  2. 2 Press the AUTO button for 5 seconds (a "beep" sound is heard) on the main unit to operate the unit at Forced Cooling Operation Mode.
  3. 3 Press the CHECK button on the remote control for about 1 second with a pointed object to transmit signal to
    main unit. A "beep" sound is heard, and the Error Code is cleared
Dec 10, 2014 | Panasonic Heating & Cooling
Wont start machine error come up
Door open error code can also be displayed as "dOE" On non-display panel models this fault code is denoted by the light for the door lock being lit or flashing.
  • Check door is closed correctly and latched
  • Check door handle for damage or wear
  • Check door safety lock if inoperative replace door lock
  • Check door lock wiring
  • If there is a clicking sound once or twice when the Start/Pause button is pressed the main control board may be faulty
Apr 08, 2014 | LG WD-1280FHD Front Load Washer
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
Panasonic dmres30v unable to open dvd drawer led displaying u99 and cant remove
Press the power button on the main unit to switch the unit to standby. When the unit is in standby , press the power button again on the main unit to turn it on. If the unit doesn’t switch to standby, press and hold the power button on the main unit for about 10 seconds to forcibly switch it to standby.
To open the drawer, press and hold STOP and CH UP buttons on the main unit at the same time for about 5 seconds.
Nov 27, 2009 | Panasonic DVD-S35 DVD Player
Code de when yo try to start load
HI. This is a door open error code. check the following to address this issue.
  • Door not all the way closed
  • Loose electrical connections at door switch and pwb assembly(Check the wiring hraness that is linking the door switch mechinsm to the PWB(main control)
  • Door switch assembly is out of order
  • Gasket on door may be creased in. If creased, try to straighten, so that the door will close evenly.
((Also, try to unplug the unit for five minutes if all the above dose not clear the code. If the unit continues to display the code after the five minute reset, replace the door switch mech))
Oct 01, 2009 | LG WM-1832C Front Load Washer
Whirlpool Duet will not work
Hi, you could have a control fault here or a door lock mechanism failure as well. the best way to find out if its ether the control or the door lock that may be faulty, is to unplug the unit for 5 minutes. this will drain all power from the control board, in return, resetting the program.
After the five minutes are up, simply switch your circuit breaker to the on position or plug the unit back in. If the control is working correctly, you should see a error code that says FdL(Failed door lock). If the control simply continues to malfunction like it was previously, this will confirm a major fault within the control board(microcomputer).
In this case, you will have to replace the control board in this unit. Remember, after the reset, power up the unit and watch the led and control panel carefully for any error codes. if the error code display is not functional, it will confirm control failure.
If you get an error code(FdL), check the wiring harness that connect the door lock mechanism to the control board. make sure they are in good condition and not lose. if the wires are ok, replace the door lock mech.
Please rate and god bless:)
May 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dishwasher isn't turning on
Hi
Kindly turn  it off for 10mins and then after restarting press the stop button twice.
Feb 19, 2009 | Dishwashers
Firmwire upgrade, Spoiled my mp3
my yp-u1 mp3 have cracked the cover, so do you have the cover of yp-u1 to repair?
May 22, 2006 | Samsung Yepp YP-U1X MP3 Player
Pioneer PD-F1009 301-Disc CD Changer Logo
630 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
