Question about Brother XL-2230 Mechanical Sewing Machine
My needle broke, and i don't know how to replace it.
My needles broke, and i don't know how to replace it.can anyone tell me?
  • a m e l i a Dec 06, 2007
    my needle broke too. i don't know how to fix it either. urgent! : (
  • Anonymous Mar 30, 2014
    The needle threader on my machine broke. How to I get to it to replaced the part?
There should ba a screw that can be loosened enuf to remove broken needle. Be sure to replace new needle with flat side in the same way as the old one, otherwise thread will keep breaking.
Posted on Mar 24, 2008
SOURCE:
What size needles fit a Rex 26-188 walking foot machine?
16x63 needle system, unless it's been retimed for something else. Suggest you might want to find the dull, bent up or otherwise still intact needle and show it to your industrial supplier or repair person, so they can check for you.
Needle system tells you about the length and timing distance of the needle: see, e.g.: http://designer-entrepreneurs.com/blog/illustrations/Singer_Needle.pdf Size tells you about the diameter of the needle: here's a suite of home sewing machine needles, all of the same needle system, but one of the photos shows a comparison of sizes:
http://www.picturetrail.com/sfx/album/view/17206792
Jan 18, 2014 | Brother XR-65t Mechanical Sewing Machine
I broke a needle and tried to replace both needles. Now I can't get my machine to chain. I have rethreaded it, and replaced the needles, closely following the manual and threading guide but still
it's possible that when the needle broke it could have caused the
machine to jump time and would need to be serviced to see if it
needs adjustment.
Mar 08, 2013 | Sewing Machines
I have a juki mo 2512 and both needles broke need to know how I replace them?
I have a Juki MO103, on mine, I have to take a screw driver and loosen a screw on each of the needle bars to remove and replace the needles.
My machine requires two different sized needles so make sure you know what needles you need.
Sep 19, 2012 | Sewing Machines
Elna Lock L1 won't keep thread chain
for a manual try elna customer service
as for the needle, check to see if it's inserted correctly in the needle holder
the needle must be pushed all the way up into the needle holder--
the flat side goes to the back side of the machine
you also mentioned that you broke a needle, when a needle is broken some times it can cause the machine to go out of time, which means it has to be taken to a sewing machine repair shop & be retimed,,
and it needs to be serviced.
Mar 01, 2012 | Sewing Machines
When the needles go down the lower looper move on the back of the needles goin up the lower looper moves in front of the needles and causes the thread brake and makes a craking sound when the lower looper...
I have a Singer 14SH654 Serger, trouble started when I broke a needle. I replaced needle now it does not sew properly with two needles. Can anyone help me
Jul 03, 2010 | Singer 14SH654
Needle Size.
I usually use Kenmore needles. I bought my machine through Sears and was told the needles were compatible. Otherwise I get the appropriate size for my fabric weight at JoAnn Fabric. As long as it has a flat back it will work fine.
Jun 28, 2008 | Janome 2049LX Mechanical Sewing Machine
Sewing machine
While I don't have specific solution for your problem, I have a similar problem with my "Euro-Pro 9101. My needle keeps breaking and it hits the needle plate. The needle plate is now very rough. Does anyone know what the solution might be?
Jan 05, 2008 | Sewing Machines
Brother XL-2230 Mechanical Sewing Machine Logo
154 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
