Question about Pentax MZ-50 35mm SLR Camera
Pop up flash will not stay open when you push the release button.
You have to hold the pop up flash open with your finger to make it stay in the open position. Suspect spring but do not know how to repair it.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 216 Answers
The post that holds the spring commonly breaks off. The top has to be removed to replace it - a $60 repair by an independent repair shop. I wouldn't recommend removing the top yourself unless you know how to discharge the 300Volt capacitor.
Posted on Dec 06, 2008
Internal flash won't work anymore
Try a factory reset. In the menu go to the third spanner and select 'Clear settings'
To pop up the flash put the camera in manual mode (M) and press the flash release button and it should pop up.
Oct 15, 2017 | Canon EOS 600D Rebel T3i Digital Camera
The flash will not fully release, only opens up
Having the same problem. We rig it by tucking the strap into the pop up flas to hold it up...
Dec 05, 2009 | Fuji FinePix S700 Digital Camera
How do i open my 1990 chevy lumina hood from outside the car?
You have to engage the "hood release" from inside the car...
(lower left, under the dash, on side panel.)
The hood must "pop" up enough for you to reach under the hood at the center front. There is a lever an inch to the right of the center of the front of the hood. Swing that lever up and to the left about 2 inches.
The hood will pop open.
As you lift the hood, notice the horizontal metal rod that holds the hood up. While holding the hood open with one hand, lift the metal rod and insert it into the slot (hole) on the hood, beign careful that it is the correct slot on the hood.
Note: If the hood does not pop up when you engage the inside latch, then push down on the hood (it may be stuck) .... don't push down gently... give it a good push and release.
It will pop up.
I know that you knew some of this, but the detail may help others.
Hope this explains it for you.
Sep 17, 2009 | 1990 Chevrolet Lumina
2004 Toyota Sienna power slide door won't open all the way
The suggested fix above did fix my problem. The problem is that a 2.5" hinged finger that pops up from the floor of the door opening to block the door. Apparently, the finger should, but doesnt go back down after the gas flap is closed. Even after I got hinged finger down (so that the sliding door would open/close all the way), it still would not go back down after the gas flap has been opened. i.e. I have to push the finger back down every time after we fill up with gas. It looks like there is a little wire/spring that should pull the finger back down, but it is off of the finger. I think that replacing this back on the finger should fix the problem permanently.
Mar 16, 2009 | 2004 Toyota Sienna
Canon Camera Rebel XTi reads error 05 and the flash will not pop up
Err 05 means: Something obstructed the built-in flash's pop-up operation. Turn off the main switch and turn it on again.
Prepare to press the flash request button with your left hand. With your right hand, position your thumb and finger to gently pry up the flash head, perhaps using fingernails. Push the button and pry. With that help, it should pop up.
Dec 20, 2008 | Cameras
My camera flash just won't work anymore
Again, the best advice is to immediately contact Canon, and get advice - if you try and fix yourself, it may invalidate the guarantee!
My guess is that when you press the flash release button, to pop it up, an electronic switch powers a release, and a spring loaded action pops up the flash - remember, you have to push it shut after use, it is not auto retract! I also am sure that the charge circuit is activated when the flash pops up. If it is not popping up when you press the button, the charge circuit will not be operating either.
I am sure you will find that if you ring Canon, there is a procedure which will return the camera to default settings, which would reset the flash action too perhaps. It may mention it in the handbook of instructions, or Canon will tell you. I had mine go weird, but it wasn't flash, and they told me, and it fixed my problem when I followed the advice - always ring them, and if you take the advice, and it causes a problem, you have a valid way out of responsibility if they claim you made the problem worse by forcing it to do something it wasn't doing as it should.
Hope this helps
Adrian
Nov 16, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Xti rebel 6 mths old - flash will not pop up
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Feb 03, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Flash
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Jan 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Flash don't work
Check out the Technical Support team at Sony. When you press the button to release the flash- holding the button in depress the flash a little with a finger.
Jun 15, 2007 | Sony Cyber-Shot DSC-V1 Digital Camera
My Flash suddenly will not pop up.
Hi Randy, It seems like the problem could be the settings. Try to set the flash manually, and then try to pop it up. If this doesn't work, and since the pop up flash release is electronic, have the camera cleaned at a camera shop. This would be a small price to pay if it works, and would be worth it for such a great camera. Please let me know if this works for you. Best regards, nightdiver
May 29, 2006 | Olympus Camedia C-770 Digital Camera
Pentax MZ-50 35mm SLR Camera Logo
191 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
