Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Television wont turn on.
TV plug in wall wont turn on. Suggestion?
    Scholar:
  • 168 Answers
Try to check first if theres an output voltage in the wall outlet. if there is, you have a completely inoperative (dead) set. this symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or IC), it may also be caused by a breakdown in the horizontal deflection circuits (horizontal oscillator, pre-drive or drive circuits). this is because the supply voltages for the tuner, video intermidiate frequency (VIF), video amplifier, sound intermidiate frequency (SIF) and vertical output circuit are usually supplied by the horizontal output circuit. but again, if you are not inclined in this kind of job, better bring it to a qualified tv technician. good luck!
Posted on Feb 04, 2007
Sony Bravia built in DVD player wont accept the discs - why is this?
Performing a power reset
1. Turn off the television.
2. Unplug the television power cord from the electrical outlet.
3. Let the television remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet.
NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
5. Turn on the television.
How to establish an HDMI connection between a TV and other device.
Follow the steps below if the HDMI® connection between your TV and other device is not working:
1. Make sure both the TV and other device are turned on.
2. While turned on, unplug the power cords for the TV and device from the electrical outlet.
3. Disconnect the HDMI cables from the TV and other product.
4. Wait 60 seconds.
5. While the HDMI cables are disconnected, plug the power cords back into the electrical outlet.
6. Turn on the TV.
7. Re-connect the HDMI cables.
8. Turn on the HDMI-connected product.
The TV should now detect the HDMI signal from the connected device and operate normally. If there is still a problem, disconnect the HDMI cable from both products and then reconnect it in the opposite direction. In some situations this has been reported to resolve connection issues.
How to reset a TV to factory settings: https://us.en.kb.sony.com/app/answers/detail/a_id/61396
Hopefully this post helps you! If does, please mark it "accept as solution"
Aug 20, 2017 | Sony Televison & Video
Sony KDL 46HX820 turns on, then off and red light blinks four times.
Re: Bravia KDL46EX720. Red LED blinks 4 times and TV wont turn on. What is the problem?
Do a Power Reset.
1. Turn off the TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If the issue still persists after performing power reset, that may be an indication that the TV needs service. You may refer to this link to locate the nearest Sony authorized service center in your area.
Oct 21, 2014 | Sony KDL-46HX820 - 46" BRAVIA 1080p LED...
Wont even power on
Hi heres a quick solution.
Turn the tv OFF.
Even if it wont turn on swith that button anyway.
Unplug from the wall for 2 mins then plug back in again
Nov 29, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Can't turn my tv on. Have been away for ten days and now tv wont turn on with either remote or using on/off buttton on the side of tv.
The only suggestion I would have is to double check your power to the TV meaning if its plugged in completely in the back of tv to the wall, and if to a power strip that the power strip is turned on. If all the above are done but not recieving power to the power strip make sure the surge or safety wasnt tripped. If its not tripped and no power check your main fuses and the fuse in the power strip.
Feb 10, 2011 | LG Televison & Video
TV will not turn on. Red light flashes 4 times
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Mar 07, 2010 | Sony KDS-R60XBR2 Television
LG flat screen wont turn on. Ive tried unplugging from wall
The flashing light indicates the TV is in protection mode. Most likely logic board. Not sure what your model is but its usually the board that has your digital inputs in it ex HdmI etc. Post your model and you should get some one to post more info Ex ( LG XXX has a common problem with tuner board)
Oct 16, 2009 | LG 42LC2D 42 in. LCD HDTV
My akai lct3285ta wont turn on,the stand by light wont even come on
Hi
Thanks for using FixYa. Make sure the wall outlet is working and the TV is plugged in. Please also check that the remote has fully charged batteries in it. If still the problem persists then unplug the TV from the power out let and again plug it in after five minutes and try to use a different power socket.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 30, 2009 | Akai LCT3285TA 32 in. LCD Television
Tv wont power up ?
TV turned off and will not turn back on.
Sep 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv wont turn on
First reset the TV set by unplugging the AC cord for like 5 minutes. then plug it back on again, try turning on the TV, if it still dont turn on then I suspect a blown fuse or worse.
Jun 08, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
46 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
