Question about Acer Computers & Internet
None of my usb ports are working andi have no sound.says no audio output device is connected
  • 6,487 Answers
There's a big possibility that the driver for your USB and audio device is not installed properly, it will be better if you can run again the setup CD for your motherboard so all software will be reloaded again for it like the driver for your USB and audio device...
Posted on Dec 03, 2008
Connect a CD player to LF320EM4A
Hi, plug red and white rca connectors from cd player to audio in - rear of tv.
Feb 02, 2015 | Emerson Televison & Video
Appears to be installed properly but doesn't record
When you first connect the turntable, Windows XP (and Mac OSX) will often select the "USB Audio Codec" as the audio input and output for your entire system. Since your turntable does not have speakers, audio will not be heard from your programs until you tell Windows not to use the turntable as an output device. Here's how to change these settings so that your internal sound card will always be used for playback whether or not your ION TTUSB is connected via USB:
    For Windows:
  1. On the bottom left of your screen, select the "Start" menu.
  2. Select "Settings" then "Control Panel".
  3. In the window that opens, select the "Sounds and Audio Devices" icon. (If you don't see a choice called "Sounds and Audio Devices," choose the "Switch to Classic View" option in the panel on the left of the window, and the "Sounds and Audio Devices" icon should become available in the list on the left.
  4. Select the "Audio" Tab at the top of the "Sounds and Audio Devices" control panel window.
  5. Under "Sound Playback," choose your internal sound card as the default device. This varies by computer but should not be set to "USB Audio Codec" or "Microsoft Sound Mapper".
  6. Under "Sound Recording," select "USB Audio Codec" for your default device.
  7. Check the box titled "Use only default devices".
  8. Click "Apply"...then "OK".
    For Mac:
  1. Open your Hard Disk.
  2. Open your "Applications" folder.
  3. In the "Applications" folder, open the "Utilities" folder.
  4. In the "Utilities" folder, open the "Audio MIDI Setup".
  5. In the "Audio MIDI Setup" under Audio Devices, set:
    • "Default Input" to "USB Audio Codec"
    • "Default Output" to "Built In Audio"
    • "System Output" to "Built in Audio"
Now, all programs, including Audacity, will only use your internal sound card for audio output.
Dec 26, 2007 | ION Audio iTTUSB Turntable
Hi, I want to know if there is a way to watch tv (sound & picture) with a htmi cable or similar even if I do not have a hdmi port. thank you
You might be better off with external speakers connected to the laptop's audio output. Flat panel TV speakers tend to be weak.
If you want to continue with the HDMI option and your laptop doesn't have an HDMI port, try a USB to HDMI adapter. Look carefully, some models output 720p not 1080p. One possible unit: http://www.walmart.com/ip/Aluratek-AUH200F-Aluratek-USB-to-HDMI-1080p-Adapter/16386417 . However, your video rate may be sluggish due to the limits of the USB port. (If you have a USB 3.0 port on your laptop and find a USB 3.0 adapter, it won't be as bad. USB 2.0 adapters are more common.)
Look at the specs for your laptop or add a comment with the make and model. My mom's HP laptop (purchased in 2009) has an HDMI out; however, the audio driver doesn't go to HDMI out by default.
You may need to adjust the audio output options. (In Windows 7, Start > Control Panel > Hardware and Sound. Then Select Manage Audio Devices under Sound. Check the Playback tab for your audio output options and change the default device if needed.
I hope this helps.
Jan 17, 2013 | Computers & Internet
3rd USB Port doesn't work and "no audio output device is installed" in Vista 32-bit
The USB port is damaged, or missing the driver for that port, check device manager.
Mar 15, 2012 | Computers & Internet
Need audio output device
Hello...
Full details about sound issue in my website...
www.sureshayyar.110mb.com (Support page)
As an alternative u can do this (i am using this solution till date)
If u cant install the sound driver correctly, just buy a " USB Sound Adaptor" and connect it to the USB port and connect the speaker sound jack to the sound port in this adaptor....u will get back the sound....also keep in mind that u " may " have to disable onboard sound in BIOS, u may also have to make changes in the Control Panel / Sound and Audio Devices / Audio Tab / Sound Playback option... Click the drop down button and select the "USB Audio Devices/Headset"
You can get it in Ebay for $1 to $4 or google it to locate a place near u......
This is the one i am refering to(I bought it in Ebay for 1$)....u can buy something similar also....there are many available mfd from China, just plug and play on your USB port....
If you find this solution useful please leave a feedback and rating to this solution.
Regards....
Mar 21, 2010 | Office Equipment & Supplies
I try using realtek ac97 audio driver for win xp 3 but it stated device cannot start error code 10
"No Active Mixer Device installed".....
The Sound and Audio issue of Windows.....the infamous issue being faced by many PC/Laptop/Notebook users all over the world....on clicking the volume control icon in the task bar near the clock.....or....Sound and Audio Devices Grayed Out in the Control Panel
Go to Device Manager, select Sound, Audio and Games Ctlr expand (+) press the plus sign, go one by one on all those that show a speaker image...select each one by one and right click, and if it has the "uninstall" option...just uninstall.
Dont do any thing further....shut down pc/laptop
Then...u need to go into system BIOS
1 - Start PC/Laptop...press DEL or F1/F2/Insert/Home key...this selection of key to go into BIOS depends upon ur type of PC in some Del key works in some F1/F2 key works to go into BIOS....you need to do this before the WindowsXP screen appears....get into BIOS...
2 - Scroll/go to On Board Peripherals...press enter...next screen....
3 Look for
A- "On Board audio"
B- "AC97 audio" or any thing that says "Audio"
C- "Look for anything that says "MIDI" with some numbers 301,205 etc in [ ]
just Disable all the above by using PgUP PGDN key
Press F10 and chose Yes to save the setting in BIOS
or use Save and Exit in BIOS
Let WinXP load...go to Device Manager...go to Sound Audio and Games Controller...check all those that you uninstalled earlier if they RE-Appear...
It should NOT......Re-appear.....if it does then do the above process once more.
U are now all set for the next move....
U need to spend just 1$ to buy this product on Ebay...you can buy any similar product of your choice but it must have the audio and mic output ports like this one has...and must be able to connect to your USB port of your PC/Laptop
This below image and product name is only for your info, you can buy any such similar product available in your area....but it's must have the Audio and Mic output ports like the one on the image below and must be able to connect to your PC/Laptops USB ports...
"USB 2.0 Mic Speaker 5.1 Audio Sound Card ADAPTER #9340"
You can Google it and locate it where you can buy...
Connect it to a USB port, connect your speakers/mic to the correct audio/mic slots in this device....WinXP will auto install this hardware and you will get back your Volume Control Icon...and all functions will work in Control Panel (Sound and audio Devices)...
Dec 14, 2009 | Computers & Internet
Driver installs ok and detection also but no sound.i have try to put also in the volume control the sound getting out from behringer.doesn t work
"No Active Mixer Device installed".....The Sound and Audio issue of Windows.....the infamous issue being faced by many PC/Laptop/Notebook users all over the world....on clicking the volume control icon in the task bar near the clock.....or....Sound and Audio Devices Grayed Out in the Control Panel
Guys....the solution's very simple....This is a sure shot solution...101% guarantee...Just do this...
Go to Device Manager, select Sound, Audio and Games Ctlr expand (+) press the plus sign, go one by one on all those that show a speaker image...select each one by one and right click, and if it has the "uninstall" option...just uninstall. Dont do anything further....just shut down pc/laptop
3 Look for
A- "On Board audio"
just Disable all the above by using PgUP PGDN key Press F10 and chose Yes to save the setting in BIOS or use Save and Exit in BIOS
Let WinXP load...go to Device Manager...go to Sound Audio and Games Controller...check all those that you uninstalled earlier if they RE-Appear...It should NOT......Re-appear.....if it does then do the above process once more.
Connect it to a USB port, connect your speakers/mic to the correct audio/mic slots in this device....WinXP will auto install this hardware and you will get back your Volume Control Icon...and all functions will work in Control Panel (Sound and audio Devices)...01be335.png
Nov 03, 2009 | Behringer F-CONTROL AUDIO FCA202 External...
From my pc's motherboard 845 GLM audio port audio as well as mic is not functioning, but it seems to be all right with internal configuration. How can i get best solution. please guide me...........
3 Look for
A- "On Board audio"
Connect it to a USB port, connect your speakers/mic to the correct audio/mic slots in this device....WinXP will auto install this hardware and you will get back your Volume Control Icon...and all functions will work in Control Panel (Sound and audio Devices)...61d861a.png
Nov 03, 2009 | Computers & Internet
What would be the solution when my crative sound card doesn't detect a connected microphone
3 Look for
A- "On Board audio"
Connect it to a USB port, connect your speakers/mic to the correct audio/mic slots in this device....WinXP will auto install this hardware and you will get back your Volume Control Icon...and all functions will work in Control Panel (Sound and audio Devices)...e40c396.png
Oct 22, 2009 | Creative Labs Sound Blaster Live! 5.1...
I am getting no sound
hi
maybe vista is not recognizing the device or it is not compatible with that os. Have you tried using windows xp, there a greater chance that it would work
Feb 13, 2009 | MSI 865GVM2-LS Motherboard
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
