How do I add another computer to my printer? Does it matter that the computer it is currently attached to is an iMAC, but the laptop I want to add has the Vista operating system?
  • 3 Answers
That depends on if the printer has its own IP or if it is connected to a PC and shared. If it is connected to a PC and shared, then no you can't connect them due to the difference in OS's (even if you are sharing from an XP machine you can't connect from a Vista believe it or not). If the printer can be put on a network (use a small office router) and then connect the printer either thru its own NIC or with the use of an external jet direct it would be the best alternative simply because the printer would be its own entity on the network and not need a master PC to operate.
Hope this helps.
MJ Krier
Kriers Computing
Posted on Dec 03, 2008
Can I connect my apollo 2250 to my old imac?
OS X drivers for the Apollo 2250 apparently exist only in 10.5 and 10.6, both of which your iMac G4 is too old to run.
If you have this printer attached to another computer on your home network, you could activate printer sharing and allow your G4 to print to it that way.
Mar 11, 2010 | Apple iMac G4 Desktop
Just purchased an iMac computer for my HP DeskJet 880C
You can log on to the hp site and get the current driver/printer software for your printer. Get the mac os version and install via usb. Download and install then restart your imac... then attempt a print...
Should work fine with an iMac.
K
Sep 01, 2009 | HP DeskJet 880c InkJet Printer
Printer will not add to my computer
Ok, since you state that you have an older iMac, I'm going to presume that it is not an Intel-Mac and that your OS X version is Linux based. So with that information known, you will just have to search for the printer (Lexmark 3400) drivers for the version of OS X you are currently running. Since the older Mac's use CUPS instead of drivers that PC's use. Basically instead of searching in Google for a Lexmark 3400 print drivers for an iMac, you would need to instead search Google for CUPS Lexmark 3400 OS X. Then you would get a link like this:
http://fixunix.com/ubuntu/505065-lexmark-printer-ubuntu.html
And if you follow that link you would get to download the needed file(s). And usually the installation instruction is there on the same site. It is a bit confusing to figure it all out but if you get lost there come back and post it here and someone will help. And if i happen to come across you i will be glad to help with the confusing manual installation of the CUPS into your iMac.
- Luke
Feb 09, 2009 | Apple Computers & Internet
Connectivity of printer with newer computers
does ur unit have The LPT connection or COM ports .
u can use this ports as a alternative connection.
also check for MAC converter cables!!
plz rate this post as good as u can
Feb 06, 2009 | Epson Stylus Color 3000 InkJet Printer
New Epson R2880 printer will not interface properly with iMac
Problem not yet solved, but we have a local Mac/Epson guru who is working on it.  Thanks all the same.  Phyllis kedl
Nov 19, 2008 | Office Equipment & Supplies
Can't connect network printer to Windows XP laptop
Does this computer see the other two computers and do they see this computer?
Sep 18, 2008 | Microsoft Windows XP Professional With...
My printer (Epson Stylus DX4200) does not work.
hi check here http://driverscollection.com/? for your drivers or epson main web site may have them also .
riz.
Nov 20, 2007 | Apple iMac G5 Desktop
46 people viewed this question
jasbo
jasbo
