Intertherm e3eb020h electric furnance won't start just hums
It was the thermstat i replaced the thermstat
thank you
Posted on Dec 04, 2008
Our intertherm furnance is clicking twice before the burner lights. Why?
If your unit has a spark igniter you'll hear clicking noises until the flame is lit. If it hasn't done this in the past, then its quite possible the igniter is starting to oxidize and needs to be cleaned. The best way to do this is use a light abrasive cloth to remove the oxidation, or otherwise known as soot. Sometimes, the igniter needs to be removed and as always remove power to the system before attempting any repairs.
Jan 22, 2017 | Intertherm Heating & Cooling
I have an electric furnacein my mobile home and it will every once in awhile hum like it is trying to turn on but won't unless I tap the blower cover.
The motor is a 'sleeved bearing' motor, not a sophisticated 'ball bearing' type motor. The bronze sleeves probably need lubrication. Some motors have no oil ports, and are referred to as 'permanently lubricated' motors. If you have oil ports, they will be approximately 1/16" in diameter near the top with little yellow plastic or gray pewter plugs in them. Remove the one plug you should be able to see and gently drop 30 drops of light weight oil into it.
The oil will slowly saturate the felt 'wick' that surrounds the sleeve bearing. The second oil port will probably be inaccessible with the blower installed inside the furnace and unless you are pretty handy, should be left for a pro. Unfortunately the oil port that is inaccessible is the bearing that carries virtually all the weight of the squirrel cage blower and is probably the culprit.
Another possibility is that the capacitor could be bad. With a bad capacitor, it probably wouldn't start on its own at ALL. Also the motor would overheat and would cycle on its internal winding thermostat.
Dec 23, 2014 | Intertherm Heating & Cooling
Intertherm feh 015ha
i think the pc board is popped
Dec 08, 2013 | Heating & Cooling
I have an e3eb020h furnace that, when I cut it on, the blower works fine, but I have a weird humming noise coming from the furnace unit. What could it be?
humming could be a body panel or metal to metal point that came loose and just needs secured in the furnace or ductwork. could be an electrical issue that you may or may not be able to find with the doors off and trying to locate where the hum is coming from. it may go away when a panel is removed because it night be air sucking through a loose section of the door. the question is vague but I would press around while its running to see if it subsides. as always when its running with the panels off electric shock hazard and arc flash can occur causing bodily injury or death that's why they have the door switch which will cause the unit not to work with the door off. you can tape this switch to test the furnace but be very aware it is done on your own and I cant tell you it is ok to do this if you have no knowledge of electricity and its dangers. this is only for you to possibly find a hum and not press around on electrical components.
Oct 20, 2013 | Ruud Heating & Cooling
I have a intertherm furnace and split intherm heat pump when i turn the thermostat on it just seems to hum out side at the heat pump whats the problem
First thing to check is to see if you have electric out there. The hum is probably the 24 volt relay that is telling the a/c to come on. The 24 volt relay gets it's power from the indoor unit.
Jul 06, 2010 | Intertherm P3RC-030K Air Conditioner
Furnance not heating
Make sure that the thermostat is set for the proper medium that you are using being gas or electric. Inside the cover of the thermostat should be a setting for either eletrical heat or gas heat. Set this switch for what your system is G for gas or E for eletric. This may solve your problem. Good Luck hope this helped you some
Dave
Oct 26, 2009 | Intertherm P3RA-036K Air Conditioner
I need to find the wiring diagram for a intertherm furnance e2eh-012ha
Here is the manufature link. They will email you the manual directly.
http://www.intertherm.net/
Aug 18, 2009 | Heating & Cooling
I have a intertherm model feh-017h electric
It's the heat kit in the unit that is causing the problem. You need to do a continuity test on it to eleminate that they have shorted. This is the only thing in an electric furnace that will blow a fuse on it. Intertherm is a Nordyne product for manufactured homes. Of coarse they still sell them! I am a Nordyne dealer. Also a sequencer can not cause a fuse to blow. The service guy just wants to make money from you by installing a new unit. You can either re-wire the heat kit or you can purchase a new one and have it installed. If you are referring to the heat kit for 159.00, then that's a fair price for it if you are a non licensed person.
Mar 17, 2009 | Heating & Cooling
Intertherm model e3eb020h electric furnace won't start just hums
Check fuses. one may be blown, and the other one not, Therefore you are getting only 110V to a 220v circuit.
Dec 03, 2008 | Intertherm Heating & Cooling
Heating & Cooling Logo
174 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
