Question about Photography
I have a Nikon N2000 it was givin to me and it is virtually new except the baterries were left in it and correded the friend that gave it to me took out the batteriesand cleaned( the best he could) the corrosion i put new batteries in and it wont power. i also noticed that it looked like the battery holder had on of the ends replaced before and maybe is not makeing a good connection?? has anyone ever had this problem and if so is there a fix you might recomend? thank you for any help
    Scholar:
  • 63 Answers
Hopefully your friend cleaned the battery compartment with something like baking soda to deter the acidic chems of the batteries, without letting moisture get into the rest of the camera. Then, I would take some fine sand paper or steel wool to clean any rust or currosion off the battery contacts. After this, place the new fully charged batteries in position and give it a try. Good Luck!
Posted on Dec 03, 2008
  • John Ballou
    John Ballou Dec 04, 2008
    If what I suggested above does not help, then your idea about the loose connection may be the primary problem. In that case, you might want to see if there is enough wire visable to reconnect the wire with a more secure connection. If you are not in to soldering wires, consider getting or borrowing a cold solder kit or using electrical tape to try to secure the connection. I know that wires in this area are usually small and may be a problem trying to splice. You might even have to resort to glue to hold the wires together, but soldering is best. If you don't want to pay a repair shop to try this, you might consider asking the electronics class at a nearby school. Sometimes the students will make free repairs for the experience, and often you will find them more competent than their higher priced competition! Hope this helps!
I have a Nikon N65 camera that I have not used in a year or so I put new battery in the camera and it would not come on at all,tried several other batteries and still no go, I am confused so could you...
Cameras are a "use it or lose it" device, especially old ones like your N65.
It's most likely that the internal lubricant films have dried out and gummed up due to lack of use. On older mechanically operated models it's sometimes possible to free things off by leaving the camera in a very warm place for a good few hours and then gently forcing the controls against the softened grease or even by banging the camera against a firm surface. You have almost none of those options on the N65: it's an autofocus model with electronic controls, and the all plastic construction won't stand up to abuse. The only thing you can try is to leave it in a warm place and then try turning it on.
Camera servicing could solve the problem, but your camera is a consumer grade model designed for a five to six year maximum lifespan and was never intended to be serviced. The cost of servicing far exceeds the residual value of your N65 body (just a few dollars).
If you cannot get your camera working then it's time to bid it farewell. The good news is that the worthlessness of many 35mm SLR bodies (and many lenses) makes them easy to obtain for free/cheap. I've had dozens of them over the last few years from friends, neighbours and relatives just by asking and most of them have come from total strangers via my local FreeCycle and Freegle groups. On one day alone last year I picked up a boxed and virtually unused F75 (N75 in USA) with the 28-100mm kit lens and a freshly serviced Nikon N8008 with a Sigma 24mm AF and a Nikkor 300mm. Everything worked perfectly once i replaced the batteries. A week later I collected an Olympus OM1n kit for free and was offered an Olympus Pen FT plus lenses for just £10 (worth well over £200). None of this is intended as a boast, it's just to illustrate that you can get superb and possibly upgrade quality replacements for just the cost of fuel mileage and a set of batteries.
Good luck, I hope you manage to use this information to fix your camera, or at least are able to use the information to help decide whether to replace it with another.
Mar 04, 2011 | Nikon Photography
I was given a nikon nikkormat el camera and i can't find a battery compartment
The battery compartment is inside the mirror box, on the lower side. To change the battery, remove the lens, lock up the mirror, then push the lid to the left and lift it up.
You can download a copy of the manual from
http://butkus.org/chinon/nikon/nikkormat_el/nikkormat_el.htm
Feb 17, 2011 | Nikon Photography
I thought I loaded the film in a Nikon F100. The Camera showed the film was moving 1-24 I got to 24 the film re-winded I took it to get developed and The film was clear I just need to know how the load...
Since you managed to close the back of the camera and shoot, you've placed the actual canister into the camera correctly.
What happened is there are a series of pegs on the left side of the camera, or sometimes just a red indication line, that the film must be placed onto. If you don't lay the film onto this, the camera won't pull the film out of the canister when you shoot, but it will rewind it back into the canister correctly when it thinks you are out of shots. This will result in a blank roll of film.
Feb 16, 2011 | Nikon F100 with 28-80 and 70-300 lens 35mm...
Mirror locked up on Nikon F75
Try pressing and releasing the shutter button. If that doesn't do anything, then turn the camera off and on and press and release the shutter button. If that still doesn't do anything, then turn the camera off, remove and reinsert the batteries (or a fresh set, if readily available), turn the camera on, and press and release the shutter button.
I ran across a Nikon N80 last week which hadn't been used for many moons. I tried the shutter and the mirror promptly locked up. It took about half a dozen tries, but the mirror eventually shook loose or whatever, and the camera now works perfectly.
If the above procedure doesn't do it, then you may have to take it in to a good camera shop for a CLA (clean-lubricate-adjust), the camera equivalent of an automobile tune-up.
Feb 05, 2010 | Nikon Photography
Where is it? I hve the nikon f75
I have a nikon camera, and they usually lable the timer next to the button. Or they will use a graphic that looks like a clock and has a little hand on it,
Nov 29, 2009 | Nikon Photography
Cant get power to Nikon N2000
I would try some CLR on the end of a Q tip and scrub down all of the contact points to clean off any corrosion. Then I'd use the eraser end of a pencial and remove any last bits of residue. Then reinstall batteries and try it. If iyt still doesn't work, then it is not a cost effective fix. You can get a replacement used, working N2000 (or F-301...its the same camera) on eBay for no more than $25.
Dec 03, 2008 | Photography
Compatability issue
Curious, Have you tried another AF lens on the N55?
Oct 01, 2008 | Nikon N55 35mm Film Camera
Minolta XG-se Camera Owners Manual
If you can find the manual for the XG it can be used. the se ( special edition ) is the same camera.
Aug 14, 2008 | Photography
Photography Logo
89 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
