Question about Garmin nuvi 205 GPS Receiver
My Garmin 205 shows "system software missing" after update. Tried to hold on the start button for a minute and tried to touch the lower right corner on screen, but its dead...
  • Anonymous Dec 16, 2008
    Hello there feel to explain everything that happened we would put too will explain in words ...
    I bought a Garmin Nuvi 205 navigator, I have attached to the PC to charge the battery but I accidentally formatted ...
    Now how do I make it work?
    I used the driver suitable aiutooooooooo
  • 3 Answers
Hey!
I just got an answer from Garmin Support Germany and they sent me an file which fixed the problem. Just download http://e-trex.info/fw/nuvi/2x5/nuvi205_085101000280en.rar
It contains a "Updater.exe" and a file called "085100010270.rgn".
Follow the following steps and you should have your nüvi back.
Firstly connect your broken nüvi. Then drag and drop the 085100010270.rgn on the updater.exe. Choose USB as a connection and it should put an old firmware back on your device.
I hope I was able to help you!
Alex
Posted on Dec 04, 2008
The same thing happened to me today. I just brought the thing and in 10 minutes of taking it out the box and updating it was broken. I called the company and they get me set up in about 10 minutes. After which I was up and going. The tech told me when it comes to trying to update "IF it ain't broke, don't fix it". Proof even the company doesn't recommend updating.
For Garmin contact information click on the following link http://www.garmin.com/garmin/cms/site/us/lang/en/supportcontact
Hope this works for you. They were extremely knowledgeable and helpful.
Memory full message
The unit may require a software update
goto http://www8.garmin.com/products/webupdater/
if that doesn't work you may need to do a master reset (you would loose any saved favorites and waypoints, saves etc)
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
  5. You will see a new message: Do you really want to erase all user data?
  6. Remove your finger from the touchscreen when this message displays
  7. Touch Yes
  8. The device will automatically reset
(garmin.com/support/searchSupport)
Jun 13, 2011 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 750 shows streets ahead. not one you are on
IF garmin is showing weird behaviour, reinstall garmin software with updater.
Aug 15, 2008 | Garmin GPS
I updated software on unit, now when it restarts, the screen is stuck on updating bluetooth firmware. Tried re-setting and even disconnecting battery. Help.
You may wish to perform a master reset and clear all of the problems this way:
To perform a Master Reset on the nuvi 200, 205, 465, 500, 600, 700, 705, 1100, 1200, 1300, 1400, 1600, 2200, 2300, or 2400 series device:
Note: A master reset will erase all waypoints or Favorites and will restore your unit to the default factory settings. If you would like to back up your Favorites to your computer, you can find instructions to do so here.
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes*
The device will automatically reset. Follow the on screen prompts and then place your device in an area with a clear view of the sky until it acquires satellites.
*If the text language on your nuvi is not set to English, touch the button on the right.
May 27, 2011 | Garmin Nuvi 465T Car GPS Receiver
Garmin 260...unit turned on with good signal and fully charged batery and plugged into car power. display asks to AGREE to terms and conditions, then goes to WHERE TO or VIEW MAP, if either optionis...
Have you tried a master reset or updated the software?
Note: A master resetwill erase all waypoints or favorites and will restore your unit to the defaultfactory settings. But who cares if you have problems, right?
  6. Touch Yes
The device will automatically reset. Follow the onscreen prompts then place your device in an area with a clear view of the skyuntil it acquires satellites.
IF this does not work, try updating to current software and maps.
Feb 03, 2011 | Garmin nuvi 260W GPS Receiver
Ihave a Garmin 1300,less than a year old,symptoms:Garmin Logo/coptright/2009 come on,the operational aspect will not.Tried draining the battery,then external power,cycle on/off...nothing happening.Thanks.
You could try pressing and holding the power button for 10 seconds. If that doesn't work, Try a master reset by:
Start with the unit off and unplugged from power.
  1. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  2. Continue touching and holding the lower right hand corner of the screen then power the unit on.
  3. Release the power button when the device powers on.
    • You will see a new message: "Do you really want to erase all user data?"
  4. Remove your finger from the touchscreen when this message displays
  5. Touch "Yes"
  6. Restart the unit
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Oct 08, 2010 | Garmin GPS
My garmin freezes on startup. Can't master reset
You could try pressing and holding the power button for 10 seconds. If that doesn't work, try a master reset by:
  5. Touch "Yes"
  6. Restart the unit
Please let me know if it helps.
Thanks
May 03, 2010 | Garmin nuvi 1350 Car GPS Receiver
My Garmin nuvi 205W was working fine but I wanted to update it on the computer before a family trip. Update seemed to work fine but the unit would not turn back on afterwards - not in the car, by USB, or...
Have you tried a master reset??
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To perform a Master Reset on the nuvi 200, 205 series device:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  6. Touch Yes
The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
Nov 24, 2009 | Garmin nuvi 205W GPS Receiver
My garmin nuvi can not find sterlites can you advise please. all else works fine , i have not updated since i bought it some 12 months ago ? i have tried the reset button but still the same . it has asked...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First try a MASTER RESET:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To perform a Master Reset on the nuvi 200, 205, 465, 500, 600, 700, 705, 1200,1300,1400 or 1600 series device:
  6. Touch Yes
If that doesn't work.......
THEN FIRST make SURE you have the latest software in YOUR computer and in YOUR Garmin.
You can get that FREE at Garmin here:
Normal 0 false false false MicrosoftInternetExplorer4 To download the latest unit software visit Garmin website: www.garmin.com/webupdater
After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
REMEMBER: It takes hours to do a complete a map update.
Unless you bought the Lifetime maps you may have to pay for current maps
Does this help? Let us know. Thanks.
Oct 15, 2009 | Garmin nuvi 200W GPS Receiver
How do I reset the Garmin 1300t? It is locked up
turn it off and unplug it from power, then press and hold the lower right corner of the screen, then power it on. when it comes on release the power button and you will see a message similar to: do you really want to erase all your data? YES, release your finger when you see that message, then follow the on screen prompts.
bill
Oct 14, 2009 | Garmin nuvi 1300 Car GPS Receiver
Firmware Update
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The latest software which can be done by installing a program called WebUpdater. WebUpdater can be installed via the link below and you must use it:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Once updated please allow the unit to reboot which will ensure the software successfully installs.
Garmin Communicator Communicator Plugin is properly installed and up to date, version 2.9.1.0. (Dec 21, 2009) If after following all the above the final steps would be to perform a master reset.
  4. Release the power button when the device powers on. After 5-10 seconds you will see a new message: Do you really want to erase all user data?
  6. Touch Yes, and wait
The device will automatically reset. Please follow the on screen prompts on the nuvi and when completed place your device in an area with a clear view of the sky until it acquires satellites.
Mar 26, 2009 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 205 GPS Receiver Logo
1,052 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
