Question about Dell Optiplex GX280 (99301) Motherboard
Optiplex GX280 Low Profile Graphics Failure
Getting 2 beeps on POST which suggests onboard graphics failure. What graphics cards will fit in this machine?
  • apoldotneth May 11, 2010
    How about if my tower is too slim, what video card with 512mb memory can you suggest, because if the video card is too wide, it won't fit. Can i buy something like an expander or something? my PCI slot expands into two PCI slots. thank you
  • 519 Answers
According to the Dell website your board has a 16X PCI express graphics slot. If so, you can ask for any PCI express graphics card at your retailer. The memory size and performance of the card will depend on your budget.
Hope you find this info helpful.
Posted on Dec 03, 2008
I have Dell optiplex GX280..with 2 GB ram and 3.0 processor,,, i bought a 256mb 3D card and put into slots for the graphics in cpu.. but when i turend on my pc at 1st it runs towards to the starting of the...
It sounds like you may have forgotten to turn off the on-board video. If you insert a graphics card when you have been using the on-board graphics before, you need to go into setup ( on Dell it usually involves tapping the F2 button before Windows loads) and turn off the onboard graphics or windows may try to load 2 video drivers and fail
Sep 30, 2012 | Famous Brand Dell Optiplex GX280 Intel...
Tip
Beep Codes (Different BIOS) " What they mean "
Standard Original IBM POST Error Codes
Code Description
1 short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
IBM POST Diagnostic Code Descriptions
Code Description
100 - 199 System Board
200 - 299 Memory
300 - 399 Keyboard
400 - 499 Monochrome Display
500 - 599 Colour/Graphics Display
600 - 699 Floppy-disk drive and/or Adapter
700 - 799 Math Coprocessor
900 - 999 Parallel Printer Port
1000 - 1099 Alternate Printer Adapter
1100 - 1299 Asynchronous Communication Device, Adapter, or Port
1300 - 1399 Game Port
1400 - 1499 Colour/Graphics Printer
1500 - 1599 Synchronous Communication Device, Adapter, or Port
1700 - 1799 Hard Drive and/or Adapter
1800 - 1899 Expansion Unit (XT)
2000 - 2199 Bisynchronous Communication Adapter
2400 - 2599 EGA system-board Video (MCA)
3000 - 3199 LAN Adapter
4800 - 4999 Internal Modem
7000 - 7099 Phoenix BIOS Chips
7300 - 7399 3.5" Disk Drive
8900 - 8999 MIDI Adapter
11200 - 11299 SCSI Adapter
21000 - 21099 SCSI Fixed Disk and Controller
21500 - 21599 SCSI CD-ROM System
AMI BIOS Beep Codes
Code Description
1 Short Beep System OK
2 Short Beeps Parity error in the first 64 KB of memory
3 Short Beeps Memory failure in the first 64 KB
4 Short Beeps Memory failure in the first 64 KB Operational of memory
or Timer 1 on the motherboard is not functioning
5 Short Beeps The CPU on the motherboard generated an error
6 Short Beeps The keyboard controller may be bad. The BIOS cannot switch to protected mode
7 Short Beeps The CPU generated an exception interrupt
8 Short Beeps The system video adapter is either missing, or its memory is faulty
9 Short Beeps The ROM checksum value does not match the value encoded in the BIOS
10 Short Beeps The shutdown register for CMOS RAM failed
11 Short Beeps The external cache is faulty
1 Long, 3 Short Beeps Memory Problems
1 Long, 8 Short Beeps Video Card Problems
Phoenix BIOS Beep Codes
Note - Phoenix BIOS emits three sets of beeps, separated by a brief pause.
Code Description
1-1-3 CMOS read/write failure
1-1-4 ROM BIOS checksum error
1-2-1 Programmable interval timer failure
1-2-2 DMA initialisation failure
1-2-3 DMA page register read/write failure
1-3-1 RAM refresh verification failure
1-3-3 First 64k RAM chip or data line failure
1-3-4 First 64k RAM odd/even logic failure
1-4-1 Address line failure first 64k RAM
1-4-2 Parity failure first 64k RAM
2-_-_ Faulty Memory
3-1-_ Faulty Motherboard
3-2-4 Keyboard controller Test failure
3-3-4 Screen initialisation failure
3-4-1 Screen retrace test failure
3-4-2 Search for video ROM in progress
4-2-1 Timer tick interrupt in progress or failure
4-2-2 Shutdown test in progress or failure
4-2-3 Gate A20 failure
4-2-4 Unexpected interrupt in protected mode
4-3-1 RAM test in progress or failure>ffffh
4-3-2 Faulty Motherboard
4-3-3 Interval timer channel 2 test or failure
4-3-4 Time of Day clock test failure
4-4-1 Serial port test or failure
4-4-2 Parallel port test or failure
4-4-3 Math coprocessor test or failure
Low 1-1-2 System Board select failure
Low 1-1-3 Extended CMOS RAM failure
on Dec 30, 2009 | Computers & Internet
Beeps:1 long 8 short pause 2 short pause 1 short
The first couple of beeps ( 1 long 8 short) points to graphics problems. Check the graphics card is seated firmly. If this fails, remove the graphics card and plug the monitor into the onboard graphics slot
If you have only the onboard graphics slot, try seeing if a graphics card, plugged into the motherboard ( may be agp or pcie fitting) solves the problem
The second pair of beeps ( 2 and 1) sounds like ram issues, if they are still there after you solve the graphics problem, try removing one ram module at a time and if it boots ok with that module removed, it is likely to be a faulty stick of ram
May 13, 2011 | Computers & Internet
I have an Optiplex GX280 SD running Windows 7 and have tried to install a Radeon HD 4550 graphics card into the PCI-e slot. It fits mechanically, with the appropriate low-profile bracket, although the VGA...
Are you sure the card is securely fit into the slot? Please confirm by checking if the fan attached to it is running or not. If you are still getting a display on your built-in adapter then the card has not been fitted properly or is faulty.
Mar 20, 2011 | Dell Computers & Internet
Can not reinstall os on mt acer 246lc it bleeps 4 times and swithes off
Without knowing what motherboard is in the unit - it will be difficult to determine what the 4 beeps means.
Generally, 4 beeps means issues with :
- memory
- video card
- keyboard
- motherboard failure
Things to try -
- make sure there is no keys stuck down
- remove the battery and AC adapter, remove and re-install the memory sticks (reseating the memory)
If this does not work, your problem may be more serious. Let us know the results of the above suggestions.
Nov 17, 2009 | Acer Computers & Internet
Six beeps at post and no joy with boot up
The exact meaning of the beeps for Dell depends on their... rhythm.
http://www.nullamatix.com/dell-diagnostic-beep-code-troublshooting-chart/
Six beeps might indicate a simple CMOS failure caused by a bad battery, which is easy to replace.
Nov 08, 2009 | Dell OptiPlex GX280 PC Desktop
I want to know what type of grapjic card dell gx280 desktop uses?
You can use a graphics card, instead of the integrated graphics.
The GX280 Desktop supports a PCI Express x16 Video Card.
The Maximum memory supported, is
Small desktop computer, 4 GB
Desktop computer, 4 GB
The GX280 specifications and service manual is http://support.dell.com/support/edocs/systems/opgx280/en/ug/index.htm
let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Sep 28, 2009 | Dell (E210882) Motherboard
Dell Optiplex GX280 Video Card Install Problem
You hit that one right on the dot.  ATI website showed the specs for that graphics card you installed as needing a 300 Watt power supply.  Good news though... I researched newegg.com and I believe I found your 300W power supply.  There are 4 different Optiplex gx280 designs with 4 completely different power supplies.  Since you bought the low-profile video card, I believe you have the slim computer case and this power supply should work for you...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817374002
Good Luck
Jun 10, 2009 | Dell OptiPlex GX280 PC Desktop
4 beeps 2373 laptop
Code Description
Code Description
200 - 299 Memory
300 - 399 Keyboard
AMI BIOS Beep Codes
Code Description
Code Description
2-_-_ Faulty Memory
Feb 19, 2009 | IBM ThinkPad T40 2373 Notebook
Upgrading graphics card onto gx280 motherboard
You need to find a "PCI Express" video card. Your Motherboard does not have an AGP slot. There are lots of them to choose from. Better to pay more now and get more memory on the video card than to regret the purchase and buy another one. IMHO
Jan 16, 2009 | Dell Optiplex GX280 (99301) Motherboard
Computers & Internet Logo
295 people viewed this question
Alun Cox
