Question about Honeywell HZ-710 Oil Filled Radiator Heater
Won't stay on
When I turn the heater on there is an F appears. it stays one just a few seconds and shuts off.
  • 10 more comments
  • cookiegirl Nov 06, 2007
    My does the exact same thing.
  • cerah Nov 09, 2007
    ditto - press power button. if select temp (right button) you can change F (for farenheit? or C Celcius? if press center or left buttons three slashes like an E display and it powers off. Occaisionally a temperature displays, like 62.
  • Anonymous Nov 14, 2007
    same problem
  • RichardHead Nov 25, 2007
    Anybody figure out how to get it to stay on after seeing the "F"?
  • lee59 Mar 17, 2008
    when i turn my heater on an f appears and the heater only stays on for a few seconds
  • biglobster May 06, 2008
    It shuts off by itself after a few minutes or after the temperature reaches the thermostat setting. This problem happens 30% of the time.
  • sokol2 Aug 13, 2008
    I have the same problem. Once I thought the oil might be low so I tipped on it side and moved the oil inside around. It did seem to help once. It stayed on a couple hours. Not a solution, so now I am trying to get the manual.
  • Anonymous Oct 29, 2008
    It's very frustrating - It used to come on for a few minutes and shuts off , now you turn it on and the F appears on and off immediately. I called the 1-800-332-1110 and they told me that since it has a 5 year warranty to send the whole unit and $10 to 4755 Southpoint Drive, Memphis TN 38118.
  • Jon Martin Nov 19, 2008
    I'm seeing the exact same problem. When I attempt to turn on the heater, it displays 'F' and then immediately turns off. Sometimes I get the 3 lines for the power level. The unit worked great last winter, but after a spring, summer and fall in the closet it seems to be worthless.
  • Anonymous Dec 05, 2008
    This is the third heating season that I've had my HZ-710 and it looks like its finally quitting on me for good. I used to be able monkey with the buttons to keep it on for at least a little while but now it shuts of after a few seconds. This heater never has worked like I'd expected a $70 heater to work and should have taken it back to Walmart when i first had problems with it.
  • gap2th Dec 05, 2008
    when I turn on the power a F appears and it shuts off after a few seconds
  • Anonymous Dec 22, 2008
    What a royal piece of ****. Mine does the same thing after 2 years.
Mso 9]> Normal 0 mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> Warning this will disable the tip over sensor, Unit will not automatically turn off when knocked over!!
I had the same problem with the "F" appearing and the unit turning off. I read a similar post about the hz-709, that talks of removing the "tip over sensor". To remove the sensor, "two little black boxes on one chip, that rattles like there is a ball bearing in each box."
Remove two small screws on the bottom of the heater then remove two small screws on the top of the heater "top screws are under a small cap that can be popped of with a flat head screwdriver."
Inside long panel front Unplug three wires, White Brown Blue "remember where they where plugged in, so you can plug then back in later."
Inside long panel front there is a silver panel with eight screws on it only the, only the four "corner" screws have to be removed to remove silver panel.
remove silver panel then remove remaining 4 screws, Now remove front control from long panel front, there are 6 screws only have to remove the four inner screws, Open white box, slip large chip off three prongs,
there are two small blue wires connecting to the two small black boxes from the beginning of this post, cut wire from box, twist or solder together, and tape with electrical tape.
"You have just removed/disable the tip over sensor, Unit will not turn off when knocked over!!"
Reverse steps reassemble the unit and enjoy.
Posted on Dec 23, 2008
  • 23 Answers
Greg12345's solution seems to be correct. i have a model 710 and had already had it open, debating wheather to bypass that very tip sensor, when i searched and found this post encouraging me to proceed. removing the sensor and joining the 2 blue wires solved the problem. the unit still displays "F" when first powered on - i believe this is simply indicating that temperature will be displayed in Farenheit units... thanks!
Posted on Oct 13, 2009
Try the owners manual, which can be found at this link: http://www.kaz.com/kaz/store/product/4df158d6f493432c932f4e3aab483c85/
Posted on Nov 09, 2007
Had the same problem and called the company's (800) number. (800) 332-1110
Was informed that I could cut the chord and mail it to KAZ Returns Dept (250 Turnpike Road, Southboro MA, 01772). They will send you a new unit in lieu of a $10 check to cover return shipping.
Posted on Jan 23, 2008
Greg12345 has correct solution. Project took me 45 minutes and unit works fine now. Only thing I would add is how to open the white box. Note 4 tabs on ENDS of box. Using 1/8" slotted screwdriver push in tab lock while gently prying loose that corner. Repeat for each corner.
Remember, upon using Greg's solution you will have disabled the tip-over sensor. The unit will not turn off now if it is tipped over.
Posted on Nov 22, 2010
2 Suggested Answers
SOURCE: oil filled heater wont stay on
I was having the same problem and did a search to find this link. This morning when I turned it on, I backed the temperature down to 66 when it first came on (defaults to 70) and it appears to be working now (it's been on for over 10 minutes)
Posted on Dec 18, 2008
1999 lincoln navigator turns over won't start dash board lights stay on with key out.
sounds like antitheft system is acting up..needs reprogramed maybe..pull the negative cable with the key on....kills everything..then shut the key off..reconnect the negative.. turn the key to run position for a few seconds(resets all factory presets) see if it will start..
Feb 10, 2013 | 1999 Lincoln Navigator
Heater will fire but wont stay lit.
I assume that you are referring to a natural gas forced air furnace. If so you just described the symptoms of a dirty flame sensor. Remove the sensor with a 1/4" nutdriver. clean the flame sensor with a small piece of fine grit sandpaper or emery cloth. replace the sensor and turn the furnace back on.
Good luck.....
Apr 11, 2009 | Heating & Cooling
Heater on,off,on,off,on,off.......
That is a bad wall thermostat.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 24, 2009 | Williams 2509612 Ceramic Mid-Size Heater
Atwood water heater problems
probly the sensor on the modul. Take and clean it off with emery cloth and then reinstall it.
Jan 21, 2009 | RTO Atwood Water Heater - 6 Gal LP
The heater will not ignite properly
How old is the thermostat? Also there a limit switches at different points on that unit. If you have a volt ohm meter find the round disc like safety's and ohm them out. Take the wires off the disc before testing them. You should have a continuity should be closed they only open if unit gets too hot. Say something like 180 degree's.
A fast way to check out the thermostat is take a small diameter wire take the cover off the t-stat and jump across the R and the W on the t-stat. If the furnace comes on then t-stat bad. Let me know if this is helpfull. Ken
Nov 09, 2008 | Cozy (W352E) Heater
Oil filled heater wont stay on
Mar 17, 2008 | Honeywell HZ-710 Oil Filled Radiator...
The heater will not ignite properly and the heater will not shut off
Judging by your pics (helpful, by the way) you have a high limit wired into your thermostat wire. Try disconnecting that wire nut connection in front of your valve and hooking the thermostat straight to the top and bottom posts on the valve (eliminating the high limit). If it runs fine, either the connection was poor or your high limit wire is pinched.
Feb 28, 2008 | Cozy (W352E) Heater
Honeywell HZ-710 Oil Filled Radiator Heater Logo
1,026 people viewed this question
Top Honeywell Heating & Cooling Experts
Paul Carew
Paul
Paul
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
