Question about Samsung SCH-a670
Blank Screen! dropped the phone and it broke apart. tried putting it together and got all the parts back, but the screen no longer shows up. both the red light works and the keypad lights work. what should i do?
  • 3 Answers
Bring it back for repair.
Posted on Feb 20, 2007
SOURCE:
I have a blackberry curve 8310 and i had to replace the outside clear screen on it and when the tech put it back together and sent it back it was not put on correctly and now it is full of dust underneath...
You can prise off the clear screen with a small thin flat-head screwdriver or the like, give it and clean and replace the clear screen again. If it loses its stickiness when you take it off, then dab a couple of drops of glue along the edge before replacing.
Beats having to take the phone completely apart
Aug 17, 2009 | RIM BlackBerry Curve 8310 Smartphone
I dropped my pantech matrix in the water and the screen is white around the edges but i can see the screen
you need to first take the phone and have it service and the screen replaced so take it to a mobile repair shop.
Jun 07, 2009 | Pantech Matrix Cell Phone
Nokia 6210 Nav new screen just flashing white
These models 5110,6110,6150,6210
Are very sensitive in display contact.
Sometimes if u just dropp the phone The screen can start to fade.
take the phone apart again and dlean all the gold-plated connectors on the screen and contact areas on the mainboard with a cotton stick soaked in
isoprophanol. Let it dry avoid fingering on the cleaned surfaces.
mount the screen carefully to the mainboard tighten the skrews from left to right to finally tighten the skrews carefully.
This should do it! Please vote!
Jun 06, 2009 | Nokia 6210 Cellular Phone
Dropped my cell in water
does your phone still work after being submerged?? i did the same and it was toast...
the screen is layered...glasss, lcd, and they are not meant to come apart. The phone needs to be left out, taken apart as far as you can get to air out. Leave it for a day or so, and put together. Hope this helps
May 05, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
LG ku990 blank screen
yea mate I broke my screen a few months ago. So I bought a new screen from ebay (about $70 AUS inc P&H) opened up my viewty and replaced it. All parts in the phone snap in together no soldering required. The screen connects through a simple snap in ribbon cable. Only tricky part is that adhesive strip that holds the front cover in other than that the phone should come apart with some light prying.
cheers
uldemar(at)hotmail dot com
Feb 17, 2009 | LG KU990 Viewty
Phone switches on but blank screen
you should take the phone to a mobile service center and have them replaced the flexcable for you
Oct 26, 2008 | Samsung SGH-D600 Cellular Phone
It turns on but a blank white screen only shows
i had the same issue when my phone got slightly wet. try taking everything apart (sim card, battery, back). let them dry out for a little bit then after like a day or two put the phone back together. turn it on it will be a white screen for a little bit but give it like 2 or 3 mins and if should come back. I did this for my phone cuz i really needed the pictures off it and it worked! hopefully if will work for you too. GOOD LUCK!
Jul 16, 2008 | Nokia 6133 Cellular Phone
Samsung SCH-a670 Logo
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
