Question about ASUS P4S800D-X Motherboard
Adding a new hard drive
Im trying to put in a new 40g hard drive but I keep getting this message: Master hard Disk : S.M.A.R.T. Command failed. What should I do when this message comes up
  • 519 Answers
It is possible that your hard drive is not S.M.A.R.T. capable, which simply means that you most likely wont be forewarned when your hard drive is about to fail. To prevent this S.M.A.R.T. message, check in your CMOS setup(by pressing DEL usually) when your PC starts up. Go through the list of BIOS settings until you find a setting to enable/disable S.M.A.R.T for hard drives. This is most likely enabled for your board. If so, disable the S.M.A.R.T. feature, then save these settings and restart your pc.
For any clarification or further assistance, please don't hesitate to post another message.
Hope this sorts your problem.
Posted on Dec 03, 2008
How do I back up my computer when this message appears Pri Master Hard Disk : S.m.a.r.t. command failed Press F2 to resume
restart computer and press delete button and in BIOS menu go to advanced menu set S.M.A.R.T disabled.
Jun 10, 2012 | Sony VAIO PCV-RZ44G PC Desktop
Im getting this message primary slave hard disk error the model is WD3200AAjs
Most (older) motherboards have two "channels" for devices (CD, disk-drives, ZIP drives, LS-120 drives).
Each channel supports two devices: one "master" device and one "slave" device.
Check the "primary" channel, not the "secondary" channel.
Check the "slave" device, not the "master" device, on the "primary" channel.
The device either has failed, or is announcing that it soon will fail.
Feb 28, 2011 | Computers & Internet
Pri Master Hard Disk:S.M.A.R.T. Command Failed
You do not seem to have a smart capable hard drive, disable the setting in the BIOS by pushing F2
Jul 05, 2010 | Computers & Internet
Pri master hard disk: S.M.A.R.T. command failed
there is problem with hard drive kindly replace it.
have a nice day dont forget to rate pls.
May 11, 2010 | Samsung (SP0411N) 40 GB Hard Drive
Hi there, my computer will not boot up, I get an error message "Sec Master Bad, Back Up & Replace" Any history of this?, came on very suddenly!
Seems that your hard disk drive is failing. First, try to move your data to another hard drive. You will need to attach your hard drive to a functioning system, & pull out all valuable data from your hard drive. After that, ypu can try to boot with a system disk/CD-ROM, & run CHKDKS C: /F on your hard drive. You can also run the FDISK /MBR command to try to fix the master boot record.
If none of this helps, try re-partitioning your hard drive. If this did not work either, you will need to find a replacement hard drive.
Nov 30, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
sounds like your hdd is failing, backup data by using external enclosure and get a new hdd.
try the solution in the link, it may get your computer to boot up.
Dec 20, 2008 | Averatec 3200 Notebook
"primary master harddisk S.M.A.R.T Command failed , press F4 to resume"
American Megatrends is telling us our Pri Master Hard disk: S.M.A.R.T. is bad, backup and replace.
By questions and answers from above, is this telling us to replace hard drive?
Aug 14, 2008 | Samsung (SP0411N) 40 GB Hard Drive
Compaq d540s hard disk upgrade
Jackwan -
Sounds like the boot record of the drive may be corrupt. When you runs the XP installation, you'll be given an option to start the Recovery Console. Go ahead and open that, should bring up a command prompt. At the prompt, type "fix mbr" (With the quotes removed). Select Yes or Continue when asked, and go through the repair process, then reboot the system and try installing Windows again.
You might want to check first, make sure the jumpers on the hard drive are set to Master, or Cable Select, and make sure the drive is connected as Drive 0 on the Primary IDE channel.
Hope this helps!
Jun 11, 2008 | HP Compaq d530S PC Desktop
Lost Master Harddrive Password
First chek in BIOS if exsist CHANGE HDD PASSWORD if not use download somwhere HIREN BOOT CD v8.2.Let me know if u got help;)
Oct 10, 2007 | IBM TravelStar 40GN 40 GB Hard Drive
ASUS P4S800D-X Motherboard Logo
154 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
