Question about Asrock K7VM3 Motherboard
ASRock K7VM3 2nd IDE won't detect any drives
I had an ASRock K7VM3 motherboard that died and I never had any problems with the board so I bought another identical board. Now it won't detect any drives on the 2nd IDE. I have tried every combination of drives and jumper settings but the 2nd IDE will not detect any drive...PLEASE HELP!!! Thank you.
  • sayful May 08, 2008
    yes I have the some problem, i don,t detect my 2 IDE bus controller. now and NTLRD file is also missing, Pls help me to How to solve this problem?
  • hmsmariano Jan 14, 2009
    Same problem. Mother worked fine until yesterday, when power supply died. I replaced it, but it gave me a lot of trouble until the computer started. I cleaned contacts at RAM, add-on video card and it came to life. But it is now very unstable: at first, it began recognising randomly the DVD drive ( even with the several different drives i tried: SONY CD, SONY DVD, LITE-ON DVD Combo. Now it doesn't recognise any of them. I tried changing flat cables too. Now it boots XP normally but freezes up after a variable amount of time, from a few seconds to a few minutes after booting is completed. Voltages are a kind of strange, as Everest reported: low cmos battery and under 5/12 v for the mainboard. I'll try another power supply. Any idea? thanks
Changing power supply again solved this issue. Now motherboard behaves normally. The previous power supply works fine with other motherboard, but not with the K7VM3. There must be some slight difference that is not tolerable by K7VM3.
Posted on Jan 15, 2009
  • 624 Answers
Go into the BIOS and make sure the 2nd IDE channel is enabled and set to auto detect.
Posted on Feb 04, 2007
P4i45gv motherboard can support 250gb ide harddisk
The motherboard has 2 IDE connectors on board, specified to ATA 100 so I would be very surprised if a 250Gb IDE drive didn't work wth the board.
It is vital however if you have more than one device connected to one of the IDE ports (each port will take 2 devices) that the jumpers on the drives are correctly set to "Master", "Slave" or "Cable Select" as necessary, to ensure that both are recognised
Hope this helps
Aug 27, 2014 | Asrock 845GV (P4I45GV) Motherboard
Does the mother board Asrock 845GV (P4I45GV) support pci sata card
If you are trying to install Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Nov 19, 2011 | Asrock 845GV (P4I45GV) Motherboard
By startup fails to see IDE 0 and IDE 2 , says no channel 0 and channel 1. Is it possible that the cmos battery is empty?
Once your powered on the CMOS battery is no longer an issue. If it isn't reading the IDE or SATA channels it could be because they are not set in the BIOS. Check your BIOS setting and double check your cable connections. You also need to make sure, for IDE devices, that one of the drives is set to Master and the other to Slave otherwise they confuse the board and cancel each other out.
Jan 03, 2011 | Asrock P4VM8 Motherboard
775Dual-880 Pro cannot boot sata
Have you tested the same with IDE ODD ? Check SATA drive is detected in BIOS. If yes enable IDE simulation in BIOS
Oct 02, 2010 | Asrock 775Dual-880 Pro Motherboard
My asrock k7vt4a-pro motherboard did not detect IDE hard disk whats the problem
The disk has died and everything on it is lost. Junk it and install a new one.
Jul 07, 2010 | Asrock K7VT4A-Pro Motherboard
I have asrock prescott 800 ddr400 fsb800 motherboard. i bought a new dvdrw that is sata. is this dvdrw compatible with the mother board? where to connect?
Sorry but the motherboard Asrock 845GV (P4I45GV) doesn't have a SATA controller and there for does not have the ability to connect a SATA CD/DVD-ROM drive to the MB. However you can buy a serial ATA IDE to SATA converter which will allow you to connect you're SATA CD/DVD-ROM drive into an opened IDE port. Provided is a link to you're motherboard; Next, is a link for the SATA convertor;
Jan 30, 2010 | Asrock 845GV (P4I45GV) Motherboard
Cannot detect floppy drive
The cable for a floppy can be tricky. You should see a red line running down one side of the cable. If you look closely on your motherboard, you should a little "1" imprinted on the board near one of the corners where the cable plugs in. Make sure the red line is on the same side. Take the other end, and on the back of the floppy drive you should see another "1", do the same thing and make sure the red line is on the same side.
Turn on your PC and try that. Monitor your floppy drive, and the light should blink a couple times while it starts up, and go off. If it stays solid, you should double check the cable connections, or try another cable.
You can then check your BIOS and see that it is listed, typically on the front page, or under the drives section.
Hope this helps.
Jan 30, 2008 | Asrock P4I45GV R5 Motherboard
Asrock K7VM3 Motherboard Logo
159 people viewed this question
Top Asrock Computers & Internet Experts
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
