Question about Plantronics Explorer 220 Bluetooth Headset Wireless Headset
Discoverable mode My LG voyager is asking me to put my device in a dicoverable mond. My bluetooth is charged and the power is on. I dont know what to do. there is only one button. any help?
  • 827 Answers
Follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Explorer 3XX device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
Posted on Dec 19, 2008
How to turn on LG hdm 210 headset?
Informational Only ' Limited support: This solution is intended for informational purposes only. AT&T provides network, billing, and provisioning support for the wireless voice and data networks. Additional support beyond this article must be directed to the phone manufacturer or Bluetooth headset manufacturer.
Instructions:
While the device is off, press and hold the Call/Send button for five seconds.
To pair a Bluetooth speaker with a device, simply activate the discoverable mode on the headset and enable Bluetooth on the device:
Activate discoverable mode on the LG HBM-210
1).
Jul 22, 2012 | Radio Communications
Plantronics voyager pro plus is connected and paired with blackberry tour. when a call is coming in, I cannot answer or hang up the phone from the bluetooth headset.
Make sure that your Blackberry's headset mode is activated. If the headset mode is turned on in the Blackberry menu and settings, you may also need to re-pair the headset to your phone to make sure that it has a good connection. Before running through the pairing process, be sure to totally delete the headset from the Blackberry's menu. You may want the headset turned off for this process.
Once you make your Blackberry discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Plantronics Voyager Pro Pairing Instructions
Good luck from Headsets Direct!
Mar 09, 2011 | Plantronics Voyager PRO Bluetooth Headset
I cannot connect my Plantronics Voyager Pro to my iPhone 4.
Once you make your iPhone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Jan 25, 2011 | Plantronics Voyager PRO Bluetooth Headset
I have a PS3 and I want to put BB 655+ headset but it is from my mom and I dont know the password.
Hi, All headset devices use a default code which 4 zeros,'0000'.
I guess that will do..
You can pass your comment..
Use this as a guide
Step 1: Set the headset to be discoverable
1. Turn off the headset.
2. Press and hold the headset button for about eight seconds, until you hear the startup tone and then five quick high beeps.
The headset is now discoverable and will remain so for about five minutes. The status light blinks while the headset is discoverable.
Step 2: Turn on Bluetooth on the other device and search for devices
1. On the device, turn Bluetooth on and set the device to search for other Bluetooth devices.
2. On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000.
See the instructions that came with your other Bluetooth-enabled device for more information about pairing it with Bluetooth devices.
Thanks for using fixya............
Jan 07, 2011 | RIM BlackBerry 8100 HS-655 Bluetooth...
Cant set to my phone
Once you make your cell phone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Dec 13, 2010 | Plantronics Voyager PRO Bluetooth Headset
Dont know how to put device in discoverable mode
I might be wrong, but I think there are some H700 headsets which support smart find. If this is your case, you must ensure that all the bluetooth enabled devices, which have been previously paired with it, have their bluetooth radios turned off. Then, some 5 seconds after you open the headset's boom, the light should become steadily lit, thus indicating it is in pairing mode. Otherwise (i.e. if it doesn't support smart find), with its boom closed, press the call button for some 5 seconds, until the light is steadily lit. Then, open the boom. Either way, turn on the bluetooth radio of the device you now want to pair your headset with, and make it search for new devices. After a while, the H700 should appear in the device' screen. Select it and make it connect. If a pairing code (or PIN or passkey) is requested, enter '0000' (four zeros).
Hope you are able to sort your problems out.
Regards, Carlos
Jul 15, 2010 | Motorola Mobility H700 Wireless Headset
How do I know if my bluetooth is in pairing mode
The Explorer 220 is not in discoverable mode until the light is flashing alternating between blue and red. This is done by holding the button as long as it takes.
So, the steps to pairing the phone should be as follows:
1 - Power on bluetooth on your phone. With most phones this is done by finding "Bluetooth" in the settings and tools menu and choosing the option for "on"
2 - Put the headseat in discoverable mode by holding the button for at least 30 seconds to a minute. The light should be flashing and alternately turning blue then red
3 - Then you may have to tell your phone to search for any discoverable bluetooth devices (warning if you have a computer or netbook with bluetooth capability your phone may find that too) be sure to wait until the phone shows "Plantronics" or "Headset" as an option
4 - Choose that option and click ok. Your phone will try to "auto pair". If that is unsuccessful it will ask for a code. That will typically be four zeroes (0000) for this particular headset.
The phone will tell you when pairing is successful.
Nov 01, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Bluetooth connection problem
Depending on the phone... try andremove the current bluetooth device. Close theheadset. Go to the phone and choose discover, or search. Open the headset and pressand hold the big button. It should then turn purple and should be recognized.
Also make sure the battery on theheadset is charged before doing this.
If this doesnt work: Start the search onthe phone, Keep the boom of the mic closed when you press and hold the buttonon the h700. the light should turn purple. After this, open the boom
Jul 27, 2009 | Motorola Mobility H700 Wireless Headset
Cannot place LG-HBM-710 in discoverable mode
It sounds as if the device is not paired with your Chocolate. Press and hold the button on the face of the HBM-710 headset for approximately five seconds, or until the light comes on and stays on steadily, then discover the device with your handset's Bluetooth screen. Once it shows up in the list of devices, select in and pair it with your phone.
Jul 07, 2009 | LG HBM-710 Wireless Headset
Discoverable Mode
Here is the on-line manual: http://www.motorola.com/mdirect/demos/how2_h3/main.html -First off make sure the headset charges for at least two hours. Also make sure theindicator light turns on indicating charging is occurring. -After the charge is complete you will need to refer to your phones manual to pair the headset to the phone. The discover mode is a mode the phone goes into not the headset. I don't have an LG8600 nor can I find a manual on-line so I can't help you with that part. If you still need assistance let us know and please don't forget to rate the posting.
Jan 23, 2007 | Motorola Mobility H3 Bluetooth Headset,...
Plantronics Explorer 220 Bluetooth Headset Wireless Headset Logo
621 people viewed this question
Top Plantronics Radio Communications Experts
Ed Nelson
Ed Nelson
waldofrog
Level 1 Expert
sonic boom...
sonic boom...
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
