Question about Canon imageCLASS D761 Copier
Paper jamb the paper is jambed at the exit area. we tried pulling the paper out slowly put it tore now we cant get our hands on it from either side . what do you recommend I have a paper caught just as it was coming out of the copier. I could see it catch and get sucked in. It is right at the exit. I have removed the toner cartridge, but still cannot get to the location where it is caught. I need to know how to access the area so the paper can be removed. I am reasonable competent to disassemble the necessary parts to reach the paper jam, but need to know the sequence to get there.
  • 3 more comments
  • secreterry Dec 05, 2008
    Removing the back cover gave me access to the circuit boards, but not the paper jam. Somehow I need to get below the auto doc feed which slides part way to remove a jam in the paper feeder, but my paper is at the exit. Does the auto doc feeder have a release that will allow access?
    See previous
    I'm still looking for how to disassemble the copier to get access.
    There is no door at the back, and turning it off and on again just sets of the jam alarm
    OK. How do I get to the fuser?
  • 4,472 Answers
Http://tech-manuals.net/
If you follow this link you can purchase the service manual for this printer which will give all the necessary step by step instructions. If you need further assistance let me know. You can also have a computer repair professional service the printer as well though that would be much more costly then acquiring the manual and doing it yourself. Please take a moment to accept and rate my solution accordingly.
Good luck and enjoy,
Lee
Posted on Dec 05, 2008
    Guru:
  • 859 Answers
The problem you have is the need to get the machine open enough to access the paper path. I can guess you are not that proficient or qualified and/or experienced. A tech would be. In the paper path are sensors that engage when paper is present and this causes the paper jam error and stops the paper drive so nothing is damaged.
What puzzles me is that there isn't a provision for access and the ability to manually turn the rollers and clear the jam.
The only thing I can think of doing is what another tech (moe) at fixyourownprinte.com uses to reset a D680 printer. Thanks moe if this works out.
Even though this is for the D600 series is may also work for you or put you into a maintenance menu that will allow you to clear the jam. In your case go to Copy Function and see what options. Often, by having a start such as this you may be able to find the glory button on your own. To bad there isn't a printer guru nearby. Its a shame how much the call out fees are to come do an easy repair like this. The purpose of the stoppage is to prevent damage to sensors, as those will freeze your machine when broken and then you have no chioce but to have a Canon Authorized tech come by.
I've often found that really good car mechanics can figure out things like this, gaining access to the inside paper path of your printer. Perhaps you know one of these kinds of people, a woman or a man who is a whiz mechanically.
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
Best of luck and before you refuse this post, would you comment on your findings? Perhaps with more to go on I can give you more assistance. Once, you refuse a reply from us you cannot go back and review.
Good Luck, Worldvet
http://www.fixya.com/users/worldvet
  • 535 Answers
U have chage the roller of ur printer or chage the gair of printer
    Scholar:
  • 81 Answers
In paper jam, have you seen at the front of your printer, a button with paper icon and has an arrow pointing to printer exit, that button can also help, pull out jam paper and in assist with your hand in pull out.
and also in turning off and then on can also help in paper jam with the assist of your hand to pull out.
  • 1 more comment
  • Alver Clamonte
    Alver Clamonte Dec 05, 2008
    with a card board it can help as thin as punch card, to push the paper jam at the center if your printer have an access at the center or back.and the paper jam at the back or center.
  • Alver Clamonte
    all the green and yellow lever and is to crank the roller manually. to pull out a paper jams
  • Alver Clamonte
    Alver Clamonte Dec 08, 2008
    most copier has a tight roller that when pull out the jam paper in bare hands it only tear the jump papers.
    that they provide a lever, for the user to pull the jump papers and you see it, in parallel of the roller where jump paper is. mostly it is in diferrent color green or yellow or gray. with an arrow up and down just crank it and follow the direction of the arrow to pull out the jump paper.
    if you already tear the paper and mostly in the exit area. you can forced the paper to pull out.by a plier but please don't up to the roller. it will damaged the roller.
    Sergeant:
  • 306 Answers
I suppose the pathway may be blocked....try to clean up the way opening the side ballot
  • AbdulRahiman S Dec 05, 2008
    but if tis doesnt fix then you have to replace the fusing unit on that machine, when it jams inthe fuser like that the fusing unit is going bad. the fusing units range from: $200.00 to $295.00 plus service call.. it always comes down to replacing the fusing unit, even if you get the paper out it will jam again.
    Have you tried to run copies from both paper trays? Will it jam in the same spot with both trays? If one works, but the other jams, it may be as simple as making sure the paper tray is set to the correct paper size? Is it set up in the paper tray as LTR, but the tray is saying LTR-R on the display. If so just change the paper size knob to the correct size. Also, if it stops in the same spot with all of the trays, look for something blocking it. Also, try to cheat the side door and make sure everthing is turning correctly..
  • Canon Master
  • 1,879 Answers
Usual places to get jammed paper out - there's a door at the back
or
most printers spit out torn paper when turned off then on
Posted on Dec 03, 2008
    Genius:
  • 1,550 Answers
You need to loosen the fuser enough to be able to reach the paper.
You need to remove all the covers and the front door assembly then you need to remove the plastic cover over the fuser then the metal plate under the plastic cover then try to get the fuser out.
  • Canon Master
  • 13,433 Answers
Have you tried simply to turn the printer on and off, in most models the paper should be ejected automatically, you can also try feeding some paper thru it.
if that doesn't help and you need to take it apart a service manual would be the best choice http://tech-manuals.net/
    Sergeant:
  • 217 Answers
Check out on the back area of the printer their is a assess door .open that door and remove the jammed paper easily.
Canon pixma mp495 rear tray rollers only pulls paper in on one side then it jams
When the paper does not feed straight, dirty or sticky rollers can cause it to jamb or crinkle, also failure to remove all traces of paper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these pieces of paper. The rollers may be dirty or sticky and causes the paper to not feed straight.
Try cleaning the rollers with methylated spirits.
Mar 30, 2013 | Canon PIXMA MP495 Wireless Photo...
Paper keeps jamming on my canon mp 480 . I have already turn upside down and looked for small bits of paper nothing came out when i try and print it makes a small buckle in paper just off center to left...
Small bits of paper lodged near the gears at the back of the rollers are difficult to see and remove. This causes the paper to jamb and crumble.
You most likely need to dismantle the printer to find the bits of paper.
When you pull paper from a fresh jamb out of the printer, do it slowly and avoid tearing the paper, if you do make sure you have all the pieces of paper.
Apr 03, 2012 | Canon Pixma MP480 All-In-One InkJet...
I cant get the paper to feed without jaming is ther a way to adjust the feed
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.The rollers may be dirty or sticky and causes the paper tonot feed straight.
Nov 03, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Printer will not feed paper straight grabs one side and pulls the paper crooked and crumples the paper
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Aug 07, 2011 | Dell 922 All-In-One InkJet Printer
I am using Canon Pixma MP145. Paper gets jammed every time i want to print. Paper gets pulled in only from right side and it gets jammed, but printer does't show any error. I have to pull the paper...
Jul 14, 2011 | Office Equipment & Supplies
Paper will not feed, goes in crooked. gets caught on right side
Jul 07, 2011 | Dell 725 InkJet Printer
Hp deskjet 5550 is always had a paper jam. what do you think is the problem of my printer? what is the possible solutions?
When removing a sheet of paper from a jambed printer, you need to be careful to slowly remove the paper without tearing the paper. This could lead to a tiny piece of paper being left behind and this will cause other paper jambs.
When this happens, the printer may need to be dismantled to remove the paper.
The other cause could be that there is uneven pressure across the rollers or dirty rollers which causes the paper to feed through unevenly and results in a paper jambs.
Check the printer for pieces of paper near the rollers and gears.
Clean the rollers, make sure there are no deposits on the rollers.
May 26, 2010 | HP DeskJet 5550 InkJet Printer
Printer starts to grab paper then paper jambs.
Hi, Follow these steps:- 1.Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred. 2.Turn off the printer. 3.Remove any paper trays. Inspect them for wrinkled or damaged paper. 4.Open any other doors that give access to the printer's paper path and to the toner or ink cartridge. 5.If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it. 6.If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly.The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam. 7.If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. 8.Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. 9.If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Thanks! mannu_rakesh
Sep 09, 2009 | Brother HL-2170W Laser Printer
Paper jamb
you need a copier tech to fix it the fuser unit has to be removed to get jam out i done a lot of them and when some people try as you have to remove the jam they do more damage
Aug 20, 2008 | Canon imageCLASS D761 Copier
Canon imageCLASS D761 Copier Logo
48 people viewed this question
old marine
old marine
