Replacement hose for hinari PAC9100 air con unit
I am wanting a replacement hose for the hinari PAC9100 air con unit
    Top Expert:
  • Heating & Co... Master
  • 85,111 Answers
I am sorry but fixya has no parts resources of any kind. You can try this site if you are in the USA www.repairclinic.com
Posted on Jun 21, 2012
4 Suggested Answers
SOURCE:
  • 69 Answers
SOURCE: I have a Danby DPAC 8020-5 air con unit. Air con
is there a flashing light on the unit? If so it will correspond to a needed repair. check your manual to match the number of flashes to the warning it is giving you.
Posted on Aug 03, 2009
  • 415 Answers
SOURCE: Vent hose for a WA-903
Here is the Sunpentown Site, manufacturer of your A/C. They should be able to assist you with replacement parts for your unit, if available.
Hope this helps!
Posted on Mar 30, 2010
hammondskeit
  • 46 Answers
SOURCE: where can i buy a hose for my amcor air con unit.
you can get a part from any supplies part store .. that sells a/c parts
Posted on Jun 28, 2010
How to regas a goldair air con unit
ok first the blue hose onto the suction line(the thicker of the two pipes)of the ac unit,the yellow onto the vacuum pump.the red hose not necessary.After vacuum is completed remove yellow hose from pump and put it on gas bottle now you ready to charge the unit
Dec 13, 2014 | Heating & Cooling
Water leaks under portable air con unit
Look for a crack on the water tank or a dried up gasket on the tank. Loose hose clamps can allow a leak as well.
Jan 04, 2014 | Heating & Cooling
Where can I get a manual and recipe book for Hinari Genie Model number MB280 please.
I am looking for a manual or instructions for the Hinari 8 in 1 blender model MB280 I have misplaced mine and want to see how it works. I have had different things said to me but want to see in the instructions etc. thank you
Aug 02, 2011 | Computers & Internet
Air con not working. Operation and timer lights flashing, then operation light flashes and then lights go off. Air con is blowing air but the outside unit is not blowing any air.
First check your timer on and off. If you want to reset, remove batteries from remote and power off to unit. Reset it. Now run the unit. Set temp mode once again in your remote and wait for 3 minutes. If still out door unit not working, check power line to out door unit.
Dec 31, 2010 | Fujitsu Heating & Cooling
Hope this helps!
Mar 30, 2010 | Heating & Cooling
Water dripping from air con use
If the unit is mounted on an outside wall check the condensate drain that comes out with the line-set to the outdoor unit. If the pipping goes up into the attic than you have a small condensate pump that may have failed. The float in the pump may have stuck in the down position not allowing the pump to come on.
Nov 08, 2009 | Fujitsu 24C1 Air Conditioner
I HAVE A HINARI REFRESH AIR 3 IN 1 AIR CON DEHUMIDIFIER
May be a bit late for this one but if you go to www.hinari.co.uk
there is a help line with these phone numbers
CUSTOMER SERVICE: 0161 621 6900
SPARES LINE: 0161 621 6855
Anne
Dec 21, 2008 | Dehumidifiers
Heating & Cooling Logo
135 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
