Question about Medion Computers & Internet
Monitor goes to sleep and can take up to 15 minutes to wake up again. Screen is black, blue 'on' light either flashes or disappears altogether. Computer is fine so often have to turn off by pressing 'windows' key then 'u' twice.
  • anniebliss Dec 04, 2008
    Have changed that - many thanks (now have to wait and see!)
    Has worked, so far!! Thank you so much....
  • 61 Answers
Turn off the hybernation mode from the power management option in control panel
Regards
Samson Ved
Posted on Dec 03, 2008
My Acer AL2216W monitor this morning went blank. I woke up, turned on pc and went to sleep like an hour more, when I woke up, the screen was black and light orange, as usual, when pc is not used for a...
Go to Control Panel, (top right View Small Icons). Then look for Power Options. On this page, you'll have the option to leave the monitor on. You should also check "Advanced Power Options". Don't be afraid of the word, "Advanced." It only means "customizeable"
If your mouse isn't waking your monitor, try the keyboard's space bar. I found it works better than the mouse at waking a sleeping computer
Apr 04, 2017 | Acer AL2216W LCD Monitor
Moved my computer and now my monitor won't wake up. unplugging the cord to the computer comes up with a no connection signal but the blue light stops flashing. Plugging the cord to the computer back in...
Be sure computer is actually starting. Power off then on computer you should see the boot sequence and then windows screen on monitor. If you do not see startup sequence monitor is not sleeping either the monitor has failed or the video card has failed. Try another monitor first.
Oct 16, 2017 | Samsung SyncMaster 940N 19 inch LCD...
Monitor goes black immediately after waking from sleep, at the same time the power light changes from green to yellow. Image is just visible on black screen when viewed with a torch, After a wait of about...
Common problem in this model is bad DC filter caps, that will be the first place to look.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Sep 01, 2010 | HP Pavilion F1523 15" LCD Monitor
Blank screen after monitor sleep just blue flashing light
First of all you can change the Power Settings in Control Panel. You can configure as you need. I mean after how much wait it should go for sleep n all.
If it takes 5 min. to wakeup that means you have so many applications running that system cannot manage or RAM is small.
The final solution just remove the Display drivers and reinstall it.
After removing please restart the system once to proceed further
Aug 03, 2009 | HP Pavilion dv9000z Notebook
Monitor displays slowly after the computer starts.
try to turn off you screen saver just turn off power monitor to see monitor easy wake up after long time.if ok means windows screen saver have problem if still same look like is you monitor something wrong need to check
Jan 03, 2009 | Dell Dimension 2400 PC Desktop
Monitor in sleep mode
I think it maybe time to buy a new monitor
Aug 09, 2017 | X2Gen MG15VT 15" LCD Monitor
Screen goes black
It could be a bad backlight bulb.
Sep 08, 2008 | HP vs15 15"LCD Flat Panel Monitor
Monitor went to sleep and won't wake up
my monitor comes on for a few seconds and then shows monitor going to sleep and then it does. can you please help me as i really need my computer.
many thanks
barneytina
Aug 11, 2008 | Princeton Digital VL17151 17" Flat Panel...
Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Feb 24, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
169 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
