Question about Teac CD-RW880 CD Recorder
Won't record using memorex 700mb cd-r.......set for analog....analog and no toc indicators are lit....press record, waiting indicator flashes......then screen reads "blank 0:00" and nothing happens even when I hit play. What am I doing wrong?
  • 492 Answers
Well first of all make sure that you are using CD-R Music not CD-R Data
Posted on Dec 03, 2008
I have TEAC LP-R500 Rec LPtoCD ?set tracks record 2 side of album
It may have recorded but in order for you to see it the disc needs to be finalized. This is when the TOC- Table of Contents is written and when the files/track show up.
Dec 20, 2012 | Audio Players & Recorders
NEED operators manual for ITRR-501 retro 5 in 1. lost mamual. NEED TO KNOW how to record to CD Disc. Also will it record fro records to disc and record cassett to disk. PLEASE SEND me a manual. OR a zerox...
The unit will record to CD from the turntable, cassette or the AUX port. Place a blank CD-R or CD-RW in the CD tray. (Note: CD-RW discs may not play on other CD players.) Press the Phono, Tape or Aux button to select your audio source for recording. (For Aux, you will need to connect the source device to the AUX port in the back of the ITRR-501.) Wait for the CD disc to load and check for any indicator lights (you should see the "NO TOC" and "CD" or "CD-RW" lights lit). Select your Track increment (or Auto Manual for unattended track formation).Press Record button and the up arrow to adjust the recording level.
If you are recording from an LP, put the tone arm down on the record. For all sources, press Play. Press Stop to end recording or Pause to temporarily break the recording. Press the Track Increment button to advance the track number if you are doing so.
To finalize your CD-R to make it readable on all players: after stopping the recording, press the Finalize button.
The manuals for Innovative Technology products are available here: http://www.ithomeproducts.com/support . The products are listed in alphabetical order. The direct link to the ITRR-501 manual in English is http://www.ithomeproducts.com/sites/default/files/pdf/ITRR-501.pdf .
I hope this helps.
Sep 19, 2011 | Innovative Technology ITRR501 Audio Shelf...
Hi - I have been recording some of my vinyl albums onto CD's for several months now. All of a sudden, when I went to use the turntable yesterday, I can't get the Record light to light. What am I...
If the red indicator on the record button does not light, reload a record-able dics, wait a few seconds until "NO TOC" and "CR-R" (or "CD-RW") indicators light on the display, and press the record button again. BE sure your using the CD -R or -RW disc and make sure to use a disc bearing the "Digital Audio" mark on it.
Richard Roth
The FixYa Team
Aug 09, 2011 | Teac GF350 Turntable
I have lost the manual that goes with my anderson nicholson cd recorder home stereo model # E6906. i can not get it to finalize. can y ou please tell me how to?
The manual for Model E-6906 on page 31
1. Press the FINALIZE button, in the STOP mode.
2. Press the PLAY button to start finalizing. The display will show busy, during finalizing, wait until busy dissapears to complete the finalizing.
When the operation has been finished the NO TOC indicator turns off and the time display returns to the track/time display.
_____________________________________
The instructions sound good but I can not get my CD to FINALIZE, even following the instructions. Let me know if this works for you.
Mar 31, 2011 | Audio Players & Recorders
My Memorex MX4118 no longer has sound when CDs are played. The display shows the CD tracks and progress while "playing" but no sound. Used a cd lalser lens cleaner but still no sound.
If it's clocking time on the disc predictably don't mess with the laser.
http://www.retrevo.com/support/Memorex-MX4118-Radios-manual/id/1082dj096/t/2/
Is the CD indicator lit? See page 18.
Press the PLAY/PAUSE > '' / POWER ON button to select CD; the CD indicator will appear in
the display.
Feb 03, 2011 | Memorex MX4118 Shelf System
It is not recording. I press play then I record. When I am finished I press stop. I then press finalize then record. But it does not record. Am I following the proper recording sequence?
Don't you have the manual?
http://download.p4c.philips.com/files/c/cdr870_17/cdr870_17_dfu_eng.pdf
Press REC and the RECORD indicator will start flashing when the unit is ready to record. You can set your levels for an analog input by playing it while in this mode.
When your source is ready and you have your levels set up, press PLAY on both units.
If you don't see the time incrementing , it's just standing still.
Apr 20, 2010 | Philips CDR870 CD Recorder
Need user manual
I have the CDR-200 and did not have the manual either. However, I did discover the same problem and found the solution. There is a "confirm" button on the front of the unit under the display area. After you press the record button "Record" will begin to flash in the display area and then you press "Confirm". It should start recording. Note however the following:
BURNING FROM EXTERNAL CASSETTE OR PHONO
Before starting this procedure make sure you have an AUDIO recording CD in the RECORDER tray of the CDR-200. A regular CD-R type of disc for computers is not going to work and may cause an annoying message on the display which does not go away until you put the right type of recording CD in the unit. It must be either an AUDIO CD-R or an AUDIO CD/RW.
1. When copying from an external cassette deck, you should set the source (press source button) until the setting is "Analog".
2. The "Dual" button should not be in effect. In the lower right portion of the screen you should only see a small number "1" with a circle around it. This indicates the CDs currently being used by the burner. In "dual" mode you can copy from the Playback CD of the CDR-200 to the Recorder CD. In dual mode you see "1" and "2" with circles around them. The active CD tray will flash on the display.
3. When copying from an external cassette unit, you use the "Record" button to start the recording. At the end of the cassette track you MUST press the STOP button by the CD Recorder tray. After you press STOP the unit will say "Update" which indicates it is closing out the track on the CD-R. You can continue to write tracks by pressing RECORD again, then CONFIRM when the tape is positioned at the right PLAYBACK track. It is usually helpful to have a few seconds of blank tape at the start of the PLAYBACK track before pressing RECORD. Press play on the cassette deck, then RECORD followed by CONFIRM on the CD burner.
4. When the track has finished burning you must press STOP to close the track on the CD-R. After you press STOP, the unit will display "Update" to indicate it is updating or closing the track. When the process completes, the unit will display the tracks it has written to the CD-R and will be ready for you to copy another track or FINALIZE the CD-R. When the unit is waiting after the STOP, you can change the cassette tape, reposition to a playback track and ready the playback tape for more recording. When the PLAYBACK tape is ready repeat STEP 3. Repeat steps 3 and 4 until you have about 14 or 15 tracks on the CD-R.
5. When you have finished recording about 14 or 15 tracks onto the CD-R, you will want to finalize the CD-R. Press the FINALIZE button, and then press the CONFIRM button. You will see the the unit start to display the progress of the finalize by advancing the level meters of the left and right channels in the display. When the unit is finished finalizing it will return to the number of tracks display for the CD-R. After finalizing the CD-R you can play it back to make sure the burn was successful. Be sure to wait for the tracks display before removing or playing the CD-R after the finalize is done. Removing before the finalize is done may damage the unit and may render the CD-R bad.
BURNING FROM THE PLAYBACK CD
1. Set the unit to "Dual" mode. As described above, you will see "1" and "2" with small circles in the lower right portion of the display.
2. Make sure the "Source" mode is set to "Analog" by repeatedly pressing the SOURCE button until it shows "Analog".
3. When copying from the PLAYBACK CD tray you will not use the RECORD button by the CD Burner tray. You will use the 'DUB" button just to the right of the display.
4. Put an audio CD in the PLAYBACK CD tray and press the skip track button ">>" until you arrive at the track you wish to record from. If the track you want to start at is track 1, then you don't need to skip tracks.
5. When positioned at the correct playback track, press the DUB button. The unit will show "CDR" and then "DUB" on the display. When it says "DUB" press the CONFIRM button. The unit will start recording. You can adjust the record level during the first few seconds to make sure you don't have the recording volume level set too high.
6. When the track is finished, you should see the unit indicate on the display "Update". This indicates it is closing the track and it should do this automatically. If it does not do this you may have to press STOP near the RECORDER Tray to force closing of the track. Usually the unit indicates "AUTO" in the display area and I believe that is what controls the automatic track numbering feature. I am not sure how the AUTO feature is turned on. I noticed on the CDR-200 it is on by default.
7. After the UPDATE is complete, the unit will display the number of tracks it has written to the CD-R. You can at this point change the PLAYBACK CD to another one or advance to another track for continued recording. When at the correct track simply go back to step 5 and continue.
8. When you are all done copying tracks from one or more CDs, and you wish to finalize the CD press FINALIZE and then press CONFIRM to start the finalize process. I noticed on the CDR-200 if you wait too long after recording a track the unit may start the finalize process automatically. This happened after at least 5 minutes. It is best to try and stay with the copy process to monitor what is happening. The finalize can also start if you have written to many tracks to the CD-R and it runs out of space. Typically, your safe if you burn about 14 to 15 tracks to a CD-R at a time. You might be able to fit more if the tracks are very short (2-3 minutes each).
One last note about the connections on the back of the unit. Read the labels of the connections on the back very carefully. The CDR-200 and probably the 201 have separate outputs for the PLAYBACK CD (CD) and BURNER CD (CDR). You will want to connect these to seperate inputs on your audio amplifier. Or you might also wish to merge them using adapters into one input on your audio amplifier. If you keep them separate you will need to change sources on the audio amplifier to hear each tray. For example, you might need to switch to "CD/TAPE" for the CD, and "AUX" for the CDR. It is probably easier to merge the two using audio adapters which can be readily obtained from RadioShack.
I hope this helps!
May 08, 2008 | Classic Electronics CDR201 CD Recorder
Nakamichi cd45z
The CD45z does not play MP3's ....Nak is about SQ ...since MP3's are poor quality ...this doesn't fit with what Nak is about.
Mar 03, 2008 | Nakamichi CD-45Z CD Player
Fisher cd-rw1000
ah..yes..mi friend, i was in that spot one time. one suggestion i have is-make sure the blank cd you are trying to record on is a "compact disc DIGITAL audio"...or try hitting the "input select" button.
Feb 08, 2007 | Fisher CD-RW1000 2-Disc CD Recorder
Teac CD-RW880 CD Recorder Logo
188 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
