Question about Microsoft Realsync DS771 17 Black LCD 8ms 600:1 300cd/m Monitor
Black screen when I first hooked up my computer and turned on the monitor it lit up a message reading "no signal" came up the screen went blank and the green light turned amber plus my tower constantly beeps somebody help me please.
  • 624 Answers
The beeps are probably BIOS beep error codes. Through a series of long and short beeps the computer communicates computer problems that occur early in the startup processes. It's likely the problem isn't your monitor but something in your computer box itself. If you can tell us what the pattern is we can start diagnosing your problem. We'll also need to know the manufacturers name, the specific model computer you have and what operating system you are running.
Posted on Feb 06, 2007
My Desktop computer is dead
it means that the monitor is not receiving any signal from the cpu, check the cable that goes from the tower (cpu) to the monitor
Jun 06, 2011 | Dell Dimension 2400 PC Desktop
My monitor is black and the power button is flashing blue, ...
If the screen is black or blank, but an error message such as No Signal displays on the screen, the problem might be related to the video signal, also check the power to the monitor, test the video connection between the computer and the monitor to make sure it is connected correctly, and connect the monitor to a different computer.
thanks for using Fixya
Felix Alphonso
Oct 03, 2010 | HP w2207 Monitor
Screen went blank
cslkkent, Your description of problem fits the common "black" or "blank n black" lcd screen symptom. Because 98 percent of all desktop cold cathode fluorescent lamp back-lit lcd monitors use the same basic lighting technology, it will be in your best interest to view some video clips of CCFL back-lit lcd monitor repair on YOUTUBE just for info on typical causes of black or blank n black screen symptoms and how some owners do repair on the cheap! Yes, your unit may have BAD capacitors on the power supply printed circuit board or one "thermally intermittant" component solder joint which will need to be resoldered. Just do some research first. Read fixya profiles of "buddymc" , "budmrtn" and my own files. Good luck on your quest. 12fixlouie
Jun 09, 2010 | LG Flatron L1919S LCD Monitor
Monitor went black and now stays black after
pdshapiro, Learn flashlight test in my fixya profile to determine current state of shutdown of units "switch-mode-power-supply"... Then do more reading and visit some of the web links mentioned in my many responses to other owners of Black or Blank n Black screen monitors. You will find out all you need to know and all options if you read my older (late 09 posts) responses to other owners of same or similar sympton ccfl back-lit lcd monitors. JUST DO SOME READING FIRST. Then come back to this post and give it a rating if it steered you in the right direction. Bye for now. 12fixlouie
Mar 27, 2010 | Dell UltraSharp 1504FP Monitor
I have a proview pl2230wdb, was working fine ,then it went all white (the screen). shut it off and turned it back on ,and all was fine. But it happened again, and when i turned it off ,all i get is a...
grybicki, Sounds like "switch-mode-power-supply/ccfl inverter supply" problem. Is pl2230wdb "black" or is it "blank n black". Yes, it can be both or just "black". Do some reading in my fixya profile to understand your options that you have open to you. Your ccfl back-lit lcd display no different than any other brand in it's basic design and operation. Use warranty if possible! (you didn't state date of manufacture) Could be a failed solder joint (open circuit) or bad capacitors on "smps/inverter" board. First, do a lot of reading before making decision on fixing or trading up. Good luck with repair. Let us know what you will do after you do some reading. Reading is free!!! 12fixlouie
Mar 19, 2010 | Proview PL576Ws 15.4" Widescreen LCD...
Philips 150S screen turns on for 1 sec. and then gose dark???
nyounger4242, Very common problem!! learn to do flashlight test to evaluate "switch-mode-power-supply" status. Read my FIXYA profile to find out all you need to know about Black, or Black and Blank lcd screen fixes and the options you have. Your monitor NO DIFFERENT than any other CCFL Back-lit LCD monitor in it's basic design and operation!! Good luck with repair. Use warranty if possible. Read, Read, Read, before you do anything!!!! 12fixlouie
Feb 04, 2010 | Philips 150S4FB 15" LCD Monitor
The moniter went all black and the power button on the moniter is flashing on and off
Please disconnect the monitor from the PC and if still the monitor is blank then monitor is defective because when you disconnect the monitor from the pc you should see a message on the screen about signal like no signal etc..
Jan 29, 2010 | Dell Computers & Internet
Blank or black screen
there is a problem with the flex..might be damaged..have it replaced by a cellphone technician
Jan 01, 2008 | Motorola Mobility i880 Cellular Phone
Viewsonic VA712b issuses
Digital-to-Analog Converter - DAC When referring to Audio, DAC is also short for Digital-to-Analog Converter and is the process of converting a digital signal into an audio signal.
Random Access Memory Digital-to-Analog Converter - RAMDAC Pronounced Random Access Memory Digital-to-Analog Converter, RAMDAC is the ... the digital data to an analog signal to be displayed on a computer monitor.
Good Luck, Please dont for get to Vote/Thank you.
Dec 19, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
Computers & Internet Logo
156 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
