Question about RCA P61310 TV
My RCA big screen tv shuts off and comes on by itself.
I had someone come fix it last week because there were colored lines though the picture and he replaced a blown fuse. Two days later the fuse must of blown again because the picture was doing the same thing and then it started shutting off and coming on all by itself. The same guy replaced the fuse again and everything is fine with the picture. I told him that the tv was shutting off and comin on by itself but of course it didn't do it while he was here. So the picture is fine but the tv is still shutting off and coming on by itself. What is the problem with it?
  • o_spoon Jan 19, 2009
    yep 2000 rca big screen tv just goes on and off anybody?
  • o_spoon May 11, 2010
    thats what i was thinkin but do u need 2 replace the hole board?
I know this is a little late but my nephew's RCA big screen was doing this also. He told me his young infant would often bang on the TV's control buttons there on the front. I removed the front panel and disconnected the wire connector for the small board which runs those controls. Problem solved.
Of course, you'll no longer have control of your TV, except through the remote. By doing this, you'll at least verify that this is, indeed, the problem.
Thanks.
Posted on Jan 21, 2010
    Problem Solver:
  • 22 Answers
On top of the fuse it sounds like the power supplie is going bad
Posted on Dec 03, 2008
BIG SCREEN TV WILL NOT COME ON
YOU LOST VERTICAL DEFLECTION THIS IS NOT HARD TO SOLVE
Dec 25, 2009 | Televison & Video
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Colors are in three
Convergence ICs need to be replaced.
Feb 03, 2008 | RCA P61960 61" Rear Projection Television
RCA P61927 NO POWER!!! HELP
If it is a ctc or ptk 195 then you have a bad flyback High Voltage transformer: the large white kindof square thing with big red wire coming out; Must get original RCA part. If picture was good before could cost you a total of (average) $300.00 according to which repairman.
Dec 14, 2007 | RCA P61927 61" Rear Projection Television
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
RCA HDTV blurry
this indications that you have a problem with convergence. first try to go into customer menu...setup....convergence. and see if the convergence will adjust.. if it wont then you have a problem with the convergence cuircit boards.
Oct 05, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 REAR PROJECTION
there should only be three colors.. can they be aligned?
Sep 16, 2007 | RCA HD52W59 HDTV Projection Television
RCA 37'' has sound but no picture
1)confirm service # on back of tv 2)Is sound from tv or surround system? 3)suspect bad flyback xformer.
Sep 01, 2007 | RCA F36665 36" TV
Picture flickers, loses color, goes green, white, and negative, then TV turns off.
the unit has a bad color wheel.rca has seen this problem before.The color wheel has a bad bearing which over time can seize causing the single color you see.Keep on them they know it is defective
Mar 19, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
RCA P61310 TV Logo
704 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
