Question about Mitsubishi WD-52525 52" Rear Projection HDTV
WD-52525 Shuts off, shows red lamp light even after replacing lamp
I turned on the TV, it strobed lots of colors at me but the menus and stuff were reduced to dancing monochromatic icons. Basically.. everything looked totally jacked with no video showing up and then it shut off leaving the red lamp light on. I thought it was finally time to replace the lamp, so I installed the new one that I bought over a year ago. No change. After resetting the system and unplugging and everything I could think of, if it even came on at all, it would flicker and shut off again. Mitsubishi won't help. They only warranty the lamps for 30 days (wish I had known a year ago). I got a Bravia in the meantime while I research this problem and try to get it repaired.. Any insight would be appreciated.
  • 1 more comment
  • Brian Roberts Feb 18, 2007
    I'm getting 3 and 4 for the blink code. Thanks for your help, btw.
  • pushrods Jun 07, 2008
    Yes I have same problem. Started out as a weird looking picture after startup and then progressed to a solid red lamp led. Code is 34 when I push the menu and device buttons. New Lamp has same symptom. No bent pins.
    Pushrods
  • Anonymous Jun 10, 2008
    no tengo video y audio
I have a Sears Teh over right now, in teh same position. They noticd that the original ballast is OSRAm, while the replacement ballast, which he said is very common, is a Phillips. He is checking voltages on the exhaust fan, from what is seems. No luck.... Now, there is an orange light flashing after everything trys to boot up, whenbefore it was the steady red, showing LAMP. Also the error code was for lamp/bulb abnormality too, before the ballast was attempted to be replaced. Since this is visit # 2... I am hoping the next one is unsuccessful as well.. so I can get the value of whatever,a nd apply it towards an LCD TV. Since I use the WD-52525 52" TV as a monitor too, the LCD will not need these damn bulbs, and have a better contrast for reading text against a black backround.
Posted on Jul 24, 2007
    Novelist:
  • 192 Answers
Turn on the set and let it shut down. push in the Menu and Device (or input, I don't have a schematic in front of me) buttons on the front of the set at the same time and hold until the green light starts flashing. Then release. There will be two different sets of flashes, such as, 3 and 6. The code 12 means the set is opperating fine. The other codes will tell you what part of the set needs repaired. Also, remove the bulb and check the ballast connection to the bulb. I find the connection for the bulb bent over when a customer replaces the lamp sometimes. Let me know what you find and we can go from there.
Posted on Feb 18, 2007
  • Mike DeNiro Feb 18, 2007
    The code 34 means a lamp abnormality. The most common is of course the lamp.
    If the lamp is new and the ballast connections are not bent over, then the next probable part is the ballast.
    I check for voltages and signals going to the ballast and if they are there, the ballast is bad.
2 Suggested Answers
  • 9 Answers
SOURCE: WD-52525 Shuts off, shows red lamp light even after replacing lamp
maybe your problem is in the power supply circuit of your tv,but then try to replace the flyback first maybe there is no high voltage coming out on the cap.
Posted on Jul 24, 2008
WD-52525 will not turn on, Flashing Red light.
if that is a dlp tv . not shure just by model. but if it is then they do have a lot of problems with vented filtor capacitors on power supply and other boards. magor work unless you replace chassis. but the very first thing to try is lamp and make shure cooling fans and vents are clean. J.D.W.
Jun 25, 2010 | Mitsubishi WD-52525 52" Rear Projection...
After replacing lamp the red lamp light remains on. Lamp will come on for a second then go out. About a minute later the red lamp light comes on and unit shuts off.
Check the lamp door to make sure it is seated properly I believe the red light indicates door switch problem. It shows you lamp error data in the service manual.
Feb 10, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Have problems with mitsu wd-52327
check the current maybe high voltage occur or due to loose connection high amper occur.
Jun 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Keeps shutting down
yes lamp issue. get the replacement lamp from reputable service or resale shop. get the lamp with housing. its alot easier to replace. clean the inside before putting in lamp with vacum. DONT BLOW AIR IN! you could damage color wheel. vacum out the fan also. lamps are about 250 US
Jun 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi w52525 - replaced lamp and red light still on
could be the wrong lamp or not set right in housing or bad door switch.
May 03, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Jul 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525
check the 2 3300 mf/ 10 volt capacitors on power supply board.
visible examination of these caps will often show the top of the capacitor bubbled up.
Jun 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd 52525 dlp shuts down
mitsubish has issued a service bullietin about the problem. which means ussally they will pay for its repair. the reson it says airflow bock is that there is a temperture sensor that is at fault... it needs replaced.
Dec 13, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Replaced the lamp, 8 days later it`s out again.
You Have bad cap's on you power supply board causing the
5 volt line to go low. Call a service provider.
Oct 31, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
1,282 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
