Question about Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod 1000 watt car amp quit working.
Hi, I installed a Sony xplod 1000 watt amp, and two Pioneer TS-300R 600 watt 12" subs into my son's car a few months ago. it sounded great for about two months and then it started shutting off when he turned it up, and steadily got worse before totally quitting. we removed the amp and sent it back to Sony repair, and they sent us another amp. I installed it today, and it still does not work. the red LED light is on, and there is power from the battery to the amp. the sterio head unit has a seperate "on off" selection for the subs, and it is switched to "on". any ideas as to what could cause this? I think there is a seperate "hot" that powers up the amp when the head unit is turned on, but don't know if it's a full 12 volts, and was wondering if I can put a jumper wire to see if it works. one more thing, I bypassed the amp and checked the speakers. they do work.
    Novelist:
    Champion:
  • 219 Answers
Almost all after market amps use 12v at very very low amperage to trigger the amp on. A temporary jumper from the battery plus terminal on the amp AFTER the battery and ground wires are attached should cause the amp to turn on. I would check to see if you have attached your speaker load correctly ESPECIALLY if you are bridging. Most of the blown amps that come into my shop are due to incorrect bridging loads from the speakers. Note that a 4ohm load bridged across both outputs of an amp will deliver a 2ohm load to each of the channels. When you parallel wire two 4ohm speakers together and then attached them to a bridged amp you will be putting a 1 (one) ohm load to each channel of the amp. Please don't make this mistake. It will fry your amp in about a month. Hope this helps. Good luck.
Posted on Feb 04, 2007
I have a sony xplode 1000 w amp that shuts off after a few seconds with or w/o the factory radio being turned on any suggestions?
Posted on Oct 05, 2010
Are sony xplod 1100 watt 10'' subs 2 ohm stable
No keep on trying end blow everry thing up, Buy some real subs.
Nov 29, 2012 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
I have two sony xplod 12" speakers wich can hold
You only gave us the model of the amp so I will make an assumption that your 12" subs are the Sony XS-GTX120LW. First, they cannot hold 1200 watts a piece. They are meant to be powered with 350 watts RMS. They will hold 1200 watts peak. That means that 1200 watts for a few seconds will be ok. Past that and kiss them goodbye!
Next you indicated that bridged the amp. Since the subs are both 4 ohm single voice coils did you wire them in series or parallel?
It sounds to me like you wired them in parallel resulting in the amp seeing a 2 ohm load. The amp you referenced is only stable when bridged at 4 ohms.
Has the amp begun working again once it cooled down? If not you could have fried the outputs by having the resistance too low.
Dec 21, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
Amplifier For Powering Sony Xplod xs-l121p5
Pump the brakes!
You need to know the RMS power rating of the sub you are powering.
Dont exceed the RMS power rating of the sub by more than 25%.
If you see a peak power rating on either the sub or the amp, ignor it, means nothing. Always compare RMS ratings.
Example: a Sony 12" Xplod sub, boasting 1200 watts, will only handle, 350 watts RMS, so the amp you choose to power the sub should be 350 watts RMS as well, and should not exceed more than 25% of the RMS power handling (487.5 watts).
Bottom line, know your RMS numbers, not Peak.
Byron
www.distinctbeat.com
Dec 06, 2009 | Sony Car Audio & Video
Getting my son a sony xplod xm-1652 2 channel what subs would sound good and the things says 1000x2 and 500x2 what is the truth
165 watts x 2 @ 4ohms and 200-230 watts@ 2 ohms or 400-460 watts bridged into a 4 ohm mono load is what the amp will actually do. A single 12 inch sub or a pair of 10 inch subs or 12s would be great
Nov 22, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod
If your still getting a green light, it at least sounds like the amplifier portion may still be funcitonal. Perhaps your inputs are blown. If your comfortable with electronics, pop the cover, and try patching a signal directly to the amplifier stage. and of course check your source.
Jun 20, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Blown amp possibly?
i have the same amp with the same problem.....your best bet is to do what i did get a better amp(audio pipe,spx,kicker,punch,etc) do not get pioneer amp or sony anything
Jun 20, 2009 | Kenwood KAC-X501F Car Audio Amplifier
Will a SONY XPLOD XM1652Z 2 CH 1000 watts hold two 12in subs?
should do easily though you may need to employ the use of a cross over just incase something goes pop and burns you're car out when you park it after you've been hammering the subs.
May 13, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Is Sub Underrated for my Amp?
fuses wont restrict the current flow the amp is way too much for that sub. it may not have damaged that sub yet but it will. you might only need a 100 watts rms too run it.but you will need sowe where about 2000 watt sub too run off that amp
Dec 28, 2008 | Pioneer TS-SWX310 Car Subwoofer
1000 watt amp sony xplod
That's not a 1000w amp. It's a 400 watt amp when loaded to it's lowest rated load. If you have one speaker per channel (the only safe load if you have single 4 ohm coil speakers), you're only getting 165 watts/speaker. It's probably distorted because you're driving it to clipping.
Jan 01, 2008 | Car Audio & Video
Sony Xplod XM-1652Z Car Audio Amplifier Logo
1,366 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
