Question about IBM ThinkPad A22e 2655 Notebook
IBM A22e laptop Bios problem
My problem is when i start up my laptop IBM A22e it goes hung when BIOS appear so i cannot make setting for the error CRC1. what should i do for this?
Forgot username and password for IBM thinkpad x41
Back up your most important data to an external storage device in case anything goes wrong while changing the BIOS settings. Remove any disc that is currently inserted in the IBM Thinkpad X41's disc drive.
2-Shut off the Thinkpad X41 laptop. Turn the laptop back on and wait for the "To interrupt normal startup, press the blue Access IBM button" message to appear on the screen.
3-Tap the blue Access IBM button at the top of the keyboard. Click the "Access BIOS" button when the "Rescue and Recovery" menu appears.
4-Click "Yes" and wait for the BIOS to load. Type in the current BIOS password for the IBM X41 and press Enter.5-Navigate over to the IBM's "Security" heading by tapping the right arrow key twice. Scroll down to the "Supervisor Password" listing and press "F5."6-Type the IBM's current BIOS password and hit Enter. Leave the next field blank if you want to completely remove the BIOS password, or instead type in a new password to replace the old one. Press Enter.7-Press "Escape" and then highlight "Restart" and press F5. Navigate to "Save changes and Restart" and press Enter.
  • Nov 05, 2011 | IBM ThinkPad X41 Tablet PC
    Bios is password protected &i hav forgot the password ,what should be done
    You must take it to an IBM dealer, they are the only ones that can reset it on your laptop.
    Apr 30, 2011 | IBM ThinkPad A22e 2655 Notebook
    IBN Z60 M- ERROR 2010: Stuck key 01
    do you have a bios password set on your z60m? what type is your z60m (what number is under type on the bottom of the laptop)? feel free to e-mail me directly if you like and maybe i can help you out. lordraptor1@yahoo.com
    Jun 05, 2010 | IBM ThinkPad Z60m Notebook
    My IBM Thinkpad is not switching on?
    The error message relates to the date and time setting in the BIOS, it has a wrong due to a flat BIOS battery. The needs to be replaced and the date and time corrected,
    The padlock symbol indicates the laptop's BIOS has been set with a password and you cannot enter and change the BIOS settings without this password.
    Replace the BIOS battery with a new one, then boot up and enter your BIOS password, then change the time & date, then save and exit.
    Mar 15, 2009 | IBM ThinkPad T21 Notebook
    Thinkpad r50
    The Power On Password problem is near impossible to crack. It is designed to prevent unauthorized access to the Thinkpad and removing the BIOS battery will not remove the password because the password is stored on an EEPROM chip.
    There are no backdoor passwords available, the only option is to ask the person who set the password.
    OR
    There is a way to hack into the Thinkpad to see and remove the password but it requires electronic skills, a program and a working computer.
    For details on how to do this go to :-
    http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
    Feb 04, 2009 | IBM ThinkPad R51 Notebook
    I got a thinkpad 2635 yesterday from a friend and upon powerup it displays an error message with 00161 and 00163 printed under it with two options ok and cancel what do i do to get into this thing
    These error message relates to the BIOS and it appears the BIOS battery requires replacing because it is flat.
    error 161 usually BIOS has lost its configuration/ checksum error.
    error 163 usually BIOS clock not updating.
    Replace this battery and go into the BIOS setting and configure the date/time settings, and hardware settings (if you are not sure select the factory default settings) save and exit
    Dec 12, 2008 | IBM Thinkpad T20 Notebook
    IBM Laptop A22e Display an error 0175
    The CRC error (POST = power on startup test) on boot up refers to the BIOS settings. This could be cause by a near flat BIOS battery and it needs to be replaces. If it is not the battery you need go to the BIOS to correct any faulty settings.
    Nov 29, 2008 | IBM ThinkPad A22e 2655 Notebook
    IBM Thinkpad A22e Shutdown early on full battery
    First, you should clean the battery terminals. You can scratch the terminals with a metal and then charge. Secondly, you should change your battery, that is, buy a new battery.
    Aug 15, 2007 | IBM ThinkPad A22e 2655 Notebook
    Open Questions:
    See all IBM ThinkPad A22e 2655 Notebook Questions
    IBM ThinkPad A22e 2655 Notebook Logo
    141 people viewed this question
    Top IBM Computers & Internet Experts
    Alun Cox
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
