Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Problems with Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing...? How do I remove the front panel in order to get access to the icemaker parts?
  • Anonymous Dec 10, 2008
    LOUD NOISE FROM A MOTOR INSIDE FREEZER AREA ON BACK WALL
For models with an extending tray for large pots, extend the tray and there are 2 screws behind the tray. Remove the 2 screws and slide the front panel up and off.
Posted on Dec 31, 2008
Use a screw driver to pry up at the two notches at the bottom of the panel. I thought that might work, but had been afraid if I did I would break the panel.
Posted on Dec 04, 2008
Door disassembly
most indoor dispensers are just a pathway for the ice to slide down with a flapper the dispensing mechanism is inside the freezer itself.
If for some reason you need to access the inside of the door it usually means removing the door seal to do so.
Aug 28, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do i access the ice dispencer door in the door? The door is stuck open and freezes up the dispencer.
1. Disconnect the unit from the electrical
supply and wait for 3 to 4 hrs to get ice melted.
2. Pull out and unclip the drip tray on the ice
and water dispenser compartment.
3. Remove the screws from the ice and water
dispenser compartment front panel and
turn it over. The selector switch pack and
dispenser switches are now accessible for
testing.
Jan 29, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Cannot get ice out you can get a glass of water but when you push button to get ice it wont chanage
If you have a selction push button panel chances are the control board, or dispenser control board as they call it, has gone bad and needs to be repaced. Get your model number and call a parts distributor to order the board. You can gain access to it by first removing the door handle on the freezer side, then taking the trim piece off that goes around it. After that is done, take the screws out andthe control will come right out. Its a plug and play board so you won't have any problems getting the new one in.
Dec 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do you get the water filter out of refrigerator so you can replace it
Without knowing your particular model number, I checked and most 25 cu.ft. side by sides have the water filter in the grille. You just push a release button and it pops out. There is a cap on the filter, do not through it away as you will need it on a new filter. Also ensure the O-ring protective covers are removed on the new filter prior to installing. You can run the water dispenser without a filter as well. Here is a link to the PDF for one type of 25 cu. ft. Whirlpool side by side.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GS5VHAXWA_Use%20and%20Care_EN.pdf
Jul 17, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Small pool of water underneath Whirlpool fridge
There may be a water filter built in. Look for access lower front panel below door. recommend replace every year. They will leak when neglected.
Nov 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser has stopped dispensing water. I have a whirlpool 25.4 cu ft. Side by Side Refrigerator
there are a few things to check real quick
does your ice still work
does your ice make still work
when was the last time you changed the filter
when you do call for water can you hear the water solonoid
Nov 03, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Need to remove front panel of whirlpool side by side cause water
I ended up running a new line. Was very simple. Just disconnect the old and pull it out. Slide a new one in and connect. So simple.
Jul 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Heat strip is to hot on freezer door frame whirlpool frige sxs.....
Two things can cause this:
1. Dirty coils.
2. Bad condensor fan motor (this cools the coils). The fan motor can be accessed from the back by removing the lower panel.
Dec 03, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
402 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
