Question about Dryers
My dryer is not giving off any heat.
There is no glowing at any point in time. I replaced the ignitor but still doesnt heat up.
  • 525 Answers
You may have to replace the ignitor coils also. These are the most common failure item on a gas dryer. Also make sure you have a heat setting selected and not an air fluff setting.
Posted on Dec 03, 2008
Replaced coils & igniter but dryer won't heat. Tested all thermostats and they read good. Can't see if the igniter is glowing or not.
check psu to ignitor and the main burner valve sets and resets
you can do this manualy by removing the thermocouple and testing the burners does it try to strike??? and doesnt burn or does the burner try to come on then go out if it wont strike perhaps the door catch isnt right you dont give a make model etc details so its hard to even guess,,,?
Dec 20, 2014 | Dryers
Our dryer stopped heating up. We cleaned out all the vents and repleced the ignitor. Still no heat. Any suggestions?
If the ignitor is glowing then check the flame sensor for continuity if it is not glowing then check the thermal fuse. If the dryer heats up for a few minutes then doesnt after that replace the coils
Jul 15, 2011 | Dryers
Doesnt heat, or only works intermittently.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 11, 2010 | Frigidaire Electric Dryer
Its a gas dryer. Starts up but no heat. Ignitor doesnt glow therefore no flame. Checked with ohm meter , seems good . Also checked coils for gas valve,checked out good . When you start up there is no power...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Gas valves works off of amps pulled by the ignitor...ohms doesn't matter..
heatman101
Sep 06, 2010 | Dryers
Dryer doesnt blow hot air.
I find that quite often the ignitor is out of alignment or the glass window is covered with lint.
a gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes.
There are two common styles of ignitors, glow ignitors and spark ignitors. The ignitor ignites the gas either by heating up and glowing, or by sparking. If the ignitor fails, the dryer will not heat.
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working.
Aug 19, 2009 | Kenmore Dryers
No heat it starts but the igniter doesnt light the gas
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor does not glow then the thermostat is bad.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.   If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Jun 02, 2009 | Dryers
Dryer won't heat.
Check the glow ignitor and make sure it is glowing, if it is not glowing then replace it, if it is glowing then check the gas valve.. But sounds like the glow ignitor is bad and needs replaced, if it is cracked it wont work either so look really carefully, maye even pull it out.
Feb 09, 2009 | Kenmore 63942 Dryer
Maytag gas dryer model#NDG2330AWW heating problem
your gas coils are bad. they open up for the first cycle but fail to after. Replace your coils and this will solve your problem
Dec 13, 2008 | Maytag Dryers
Kenmore Elite Dyer Model # 11071082000
Hi. thanks for the question. the problem you have is with the coils ,on the gas valve. 2 little coils . replace them. thanks the appliance doc
Sep 30, 2008 | Kenmore 72802 Gas Dryer
Dryer lights, heats up some but wont relite
Replace the coil packs on the gas valve this fixes 90% of gas dryers lighting intermittently. The bracket comes off and they are sold seperately from any appliance parts retailer.
This worked for my dryer.
Feb 06, 2008 | Whirlpool LGR5634L Gas Dryer
Dryers Logo
71 people viewed this question
Top Dryers Experts
