Question about Refrigerators
I have a 2004 whirpool side by side refrigerator and i was wondering if ther is a way to increase the water volume at the water despencer?
  • mwilliams367 Dec 03, 2008
    yes i have a coil of water line behind the crisper drawer.
  • Joe McG May 11, 2010
    Do you have a coil of plastic water line in the base of the refrigerator? It would be behind the drawers.
  • 525 Answers
The dispenser has a designed specification flow from the manufacturer. There are filters installed inside or outside of the unit. If the water flow appears to have decreased over the years, it may be 1 or all the filters that may nedd to be replaced. Check your user's manual to see what filters are installed as a servicable component, and replace them. An installer may have also placed an in-line filter on your water supply, so look for this also. The water supply line is only a 1/4 inch line, so anything larger than that in the line may be construed as a filter. All filters should be replace every 6 months at the least, unless their specifications say otherwise.
Posted on Dec 03, 2008
I have a whirpool ED2VHEXTB side by side: ice maker works fine but often the ice freezes while inside the automatic despencer and wont come out
Check to make sure that the dispenser flap is closing properly. Sometimes an eyelet will break off and cause it to see ackwardly. They make ita kit to fix that even thought they try to get you to purchase a new door.
Oct 28, 2010 | Whirlpool Refrigerators
Where is the CCW setting on Ice Maker
not reccomnended to do its set from the manufacture, if you are experiencing smaller icecubes look into replacing your water filter or making sure water supply has not become resrticted
Oct 30, 2008 | Whirlpool GS6NBEXR Side by Side...
Water Leak
my frig start giving noise but it was very little noise i had not check where from noise is coming then the noise was increasing more , since last week its stop working,let me know problem.
Sep 22, 2008 | Kenmore 53092 / 53094 Side by Side...
Water drips
try turning off water supply valve.if water stops, install new water control valve.
Sep 06, 2008 | Maytag MZD2766GES Side by Side...
WHIRPOOL ED2
Not enough model to get the wire diagram. It sounds like a diode is out in the water valve harness. If it is using the triple valve on that unit.
May 08, 2008 | Whirlpool ED2FHEXN Side by Side...
Side by side refrigerator ice despencer does not despence properly
You may need to manually defrost it if icy or the water filter may be partially plugged. I may need more information.
Apr 21, 2008 | Refrigerators
Ice despencer won't make ice any more
Is it the despencer or the icemaker which thing showing the problem makes a difference to giving you info on the repair.
Jan 31, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
