Question about Kenwood KVT-717DVD Car DVD Player
Mecha error my player is saying mecha error and i can not eject any cd/dvd... it trys but gives up also when it was working it would take 2 or 3 times for it to actually read the cd this is my second unit and its happening again
  • 3 more comments
  • Anonymous Apr 01, 2008
    Yeah, Mecha Error and I can't eject the cd/dvd. It takes 4-5 tries to read it and it won't eject
  • Anonymous Apr 29, 2008
    The problem is that my Kenwood don't read any cd. I insert the cd and my kenwood reject it.
  • Desp-Lady Jul 20, 2008
    my sony mini hi-fi says mecha error and the CD Player sticks and won't play. however the radio and tape deck plays. PLEASE HELP ME!!!!!!
  • Anonymous Aug 23, 2008
    I am receiving the same error
  • preluderacer Dec 18, 2008
    yeah my deck would read the Cd but it would say Mecha Error how do i fix it?
  • 14 Answers
Mecha error is a Mechanical Error. This means that this is an actual physical malfunction of the unit. Sometimes pressing the reset button can realign some of the mechanics but most often this is a problem that requires to be serviced.
Posted on May 07, 2007
I was having the same problem and when it would try to eject the dvd I would just take another dvd and use it to push the dvd up, and it would come out. A few times of doing that made it stop doing that for some reason, and hasn't done it since. hope this helps!
Posted on Sep 30, 2009
This may sound stupid, but if you have a CD in the unit and when you try to eject it you get the MECHA error, what I do is...
Try...
1.With CD in unit, I press EJECT and then see if CD stays stuck, I then take another CD and us it to push the CD back into the unit. Then I press the eject button again until the CD in the unit pops out.
2. If #1 dosen't work, I then PUSH the eject BUTTON and then slightly add pressure to the opening where the CD comes out using my thumb.
I normally find this problem happening with certain CD. For some reason some CD seems THICKER than others. The CD's that seem thin pop out just fine.
Anyway, it not HIGH SCIENCE, but I hope it helps. It works for me. Good luck!
Posted on Feb 06, 2009
  • 20 Answers
My DCFC Narrow Stairs disc does this every time I put it in my DNX890HD. I also use anything similar width to push in and under the front edge of the stuck disc and lift up when pushing eject. I finally took it out of the truck but the Kenwood displayed the 'Mecha Error' every time. That disc is a bit thicker imo and mine had a rough edge, I wanted to shave the edge down but never really bothered with it, I just bought an iPod with more storage on eBay instead!
Posted on Jun 01, 2017
  • 3 Answers
Blow it up and get a new one!!!!!!!!!!!!!!
Posted on Aug 26, 2013
SOURCE:
Recently the CD player stopped working with a cd inside it says error 1/error 2 after it trys to load it also won't eject the cd at the same time this started the usb also stopped charging my devices
Try to put another cd in on top of the stuck one . don't force it , just push in a little ways then pull it out . Sometimes that will make player eject the stuck one. I would take it back to whoever installed the radio.
Dec 05, 2015 | Cars & Trucks
Mecha error
Otherwise known as a mechanical error. The CD will not eject/insert without assistance. I have found a workaround for this, but have yet to fix it. If you take another CD and hold it inside the CD slot just beneath the ejecting CD, it will help to guide the CD out of the track. I also have to use a similar method to push the disc into the track as well.
Aug 14, 2009 | Kenwood DDX-6019 Car DVD Player
My screen displays mecha error
This is an internal problem with the CD/DVD mechanism that can not be repaired without professional service. You can always try running a cleaning disc thru it, but that is unlikely to help.
This is a very exspensive system and should only be service by qualified service technicians.
There are no tricks to getting it to work.
Jul 01, 2008 | Kenwood KVT-617DVD Car DVD Player
Shelf cds is blocked SONY CMT-HP7
To get the cds to play, and 5 to eject, you can try taking off the sides of the consul and using compressed air. As for the shelf problem, I'm not really sure.
Nov 09, 2007 | Sony CMT-HP7 CD Shelf System
Mecha error
I had the same problem. My unit would not eject CDs. I was able to fix it by hitting the reset button. That restarted the whole unit and reset all the settings as well, but now I'm not having any issues with ejecting CDs.
Oct 22, 2007 | Kenwood Excelon DDX-7015 Car DVD Player
Kenwood 10 disc changer
i have a sony mini Hi-Fi Component System MHC-GX470. I comes on, the Radio and Tape deck plays well. the CD Player says "mecha Error" and hangs. CAN YOU PLEASE HELP ME???
Jun 23, 2007 | Kenwood KDC-CMP59FM 10-Disc CD Changer
Mecha Erro
The problem could be a belt if the unit uses one for the CD try, a bad motor or the motor drive servo circuit. There are no user replaceable parts inside this unit as it is solid state and unfortanatly, there is no quick fix for this, except, taking the unit out of the vehicle and bench testing it. Im afraid you will need to seek out the assistance of an authorized servicer. Good Luck PS please do not forget to rate this thread
Oct 17, 2006 | Kenwood DDX-6019 Car DVD Player
DV-C501 MECHA ERROR
I have actually had the same problem multiple number of times now and am going to suggest you a rather "crude sounding" solution!! First, atleast in my case the problem usually occurs when you turn the DVD player off while it still has DVD/CD inside and then turn it back on a little while later. This is how the "solution" works. I just disconnect the player and give it a good shake !! This somehow dislodges the "stuck" disc inside and voila, the player opens up after reconnecting and pressing the open/close button. Sometimes it takes more than one "good shake". Sounds rather severe but works everytime !!
Oct 04, 2006 | Onkyo DV-C501 DVD Player
Car Audio & Video Logo
9,428 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
