Question about Brother MFC-465CN InkJet Printer
Trouble printing Clean Edge business cards
The printer seems to work all right on plain paper but when I load the business card stock paper, it typically jams. If it does pull the paper thru, some of the cards are not centered correctly and the ink on the lower part of the page runs.
  • vkuzemchak Apr 28, 2009
    printer set up does not have a setting for heavier paper
    Brother MFC 465-CN. I am trying to print postcards and they will not feed. Actually 4 fed and then no more. I often have this asme problem on plain paper also. I did clean the paper feed and I do not know what else to do other than throw it out the window.
    Champion:
  • 320 Answers
Not tru. you need to go to printer set up and chane the setting to heavy paper so that the fuser will fuse the toner in to the card stock
Posted on Jan 13, 2009
I have an HP Photosmart A646 printer that I bought in the hopes of printing to 5x7 card stock. We have pre-printed card stock that we use for gift certificates and we need to be able to feed the card stock...
Thanks for visiting FixYa!
Depending on the program you are using to print your gift certificates, try this-
1) Open the program and open the file you use for your gift certificate.
2) Click on 'Layout' then 'Page Set Up' (probably found in the top menu bar by the right side of, FILE.)
3) Select 'Landscape' and then select, 'Custom'.
4) Enter 5x7 for height and width.
5) Enter the information you need in the data field, (ie, name address, etc.)
6) Select, Print.
7) When the 'Print Manager' box opens, click on, 'Properties'.
8) Click on, 'Type' and choose, "Envelope'.
9) Click on, 'Size' and choose 5x7. - and click, OK.
Your printer should have a slide where the paper is inserted. Place one of the 5x7 cards in the slot just as you would an envelope and slide the slider until it is 'close' to the card but not directly against the card.
Click, 'Print'. The printer should recognize the card (due to its thickness) as an envelope and print it.
Mar 19, 2011 | Office Equipment & Supplies
HP Photosmart C4795. Can't get business cards to align correctly at top. Alignment is perfect on plain paper, but starts too high on card stock so every one is lined up wrong. What am I doing wrong? Using...
In printing properties and printing preferences be sure and tell the printer you're printing labels, it allows more time for the card stock to reach the starting point.
Jan 05, 2010 | Office Equipment & Supplies
Printer problem
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | Office Equipment & Supplies
HP C4280 incorrect paper feed
Check your printer's capability.
Buy the card stock they recommend.
If all else fails, print on plain and take card stock to a copy shop and have them do it for you.
Walking there beats going nuts over stupid software or hardware problems
Dec 16, 2008 | HP PhotoSmart C4280 Laser Printer
Blinking yellow light
I m not sure what the specification of the paper type you are using however if you are using card stock than you should use manual feed Tray and in the printer driver properties you should select paper type as Card-Stock to make sure there is no print quality issue.
Nov 30, 2008 | HP Color LaserJet 2550n printer + HP Color...
Problem printing business cards
I had this problem today and think I've figured it out. Take a sheet of plain paper and two little pieces ot clear 'scotch' tape. Tape the blank sheet behind the business cards at the top/feeder edge and try again. You may need to tweak it a bit more but it stops it from printing so far up.
Jul 19, 2008 | HP Deskjet 3845 InkJet Printer
Dell 924 All-In-One printer
Below are the various sizes and types of paper supported by your printer. Make sure you donnot load the tray beyond the maximum limit , otherwise the rollers may not pull the paper correctly
• Letter*
• Legal
• B5
• A4
• A5
• 3x6
• 4x6
• L
• 2L
• 5x7
• Hagaki
• 10x15 cm
• 13x18 cm
25 greeting cards,
index cards,
postcards, or photo
cards
• The print side of the cards faces up.
• The cards are centered on the paper support, in between the left and right
paper guides.
• The paper guide rests against the left edge of the cards.
• You select Normal or Photo print quality.
25 sheets of photo
or glossy paper
• The glossy side of the paper faces up.
• The paper is centered on the paper support, in between the left and right
paper guides.
• The paper is loaded vertically against the right side of the paper support.
10 iron-on transfers • You follow the loading instructions on the packaging.
• The blank side of the transfer faces up.
• The transfer is centered on the paper support, in between the left and right
paper guides.
NOTE: For best results, iron-on transfers should be fed one sheet at a time.
50 transparencies • The rough side of the transparencies faces up.
• The transparencies are centered on the paper support, in between the left and
right paper guides.
NOTE: You can load a single transparency into the paper support without
removing plain paper.
Apr 15, 2008 | Dell 924 All-in-One InkJet Printer
Repeated paper jam in fuser
Fuser's orange roller is not meant to be wrinkled, if this is then I would recommend you replace it (just slides out) pic below
b4eead5.jpg If printing on card, you need to feed via manual bypass and exit from the back, not on the top, aka the "face up tray." Tray pulls out from rear. Rear tray will only stack a few card sheets at once.
Setting on printer's control panel must be set to card/heavy paper type on manual bypass tray
Their may still be some card in fuser causing jams.
Please rate as FIxya or post back,
Cheers
S. :-)
Jan 01, 2008 | OKI C5200n Laser Printer
Only prints business cards correctly on plain paper, but not on the card stock.
I am the guy with the hp d'jet D2445. I ran out of card stock in failed attempts. Not wanting to give up I bought more (Avery, no serrations) and it worked fine. Don't ask why.
Oct 21, 2007 | HP PSC 1410v All-in-One Printer
Brother MFC-465CN InkJet Printer Logo
270 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
