Question about Ruud UBHC Air Conditioner
Ac heat not working
I have a Ruud UBHC 14J07NFD and the heat is not working. Worked a couple of days ago and last night was blowing cool air.
  • 2 more comments
  • dadtorad Jan 17, 2009
    Mine does the same. Where are the manual override switches located within the burner compartment?
  • Philip187 Jan 29, 2009
    I have a simialr problem.
    The two lights are GREEN in the main controller unit.
    UGLU, -f4892
    Checked the manuals flwo chart" noticed the heating element was not glowing bouight a new one and fitted still not working.
    - Blower starts
    - Does the presurge
    - Igniter does not glow
    Q.1 vents seem okay - how does one check that - no dead birds found)
    Q.2 how the heck does one check that the " air providing" switch is (closed) ?
    I am now going to check the wiring and 115VAC to the igniter and main board.
    Thanks RUUD
  • RDrennan May 11, 2010
    If it worked and is now only blowing cold air it may just be in a lock out situation. Check the outside unit for error codes and respond.. What you have is a "Heat Pump" the model number you gave is for the air handler unless thats all you have with heat strips. Check the outside unit and see if the breaker is tripped...
    Richard (Rick) Drennan
    Global HVAC Distributors
    RUUD Field Support Representative / Instructor
    rdrennan@globalhvac.com
    900 Spreckels Ave
    Manteca, Ca. 95336
    Office (877)448-7263
  • Anonymous May 11, 2010
    need more info.model and serial numbers is a good place to start.what type of stat do you have.is it programmable?if so, did you try to turn heat on manually using the programmable t'stats override/hold feature.
    it could be something as simple as a misprogrammed t'stat.
  • 22 Answers
Rheem/Ruud are the same equipment with different stickers; they come off the same assembly line. 1) check that you have full air flow: all the vents are open and clear, the return grill is clear and the filter is CLEAN. 2) On the older models there are 2 each 1/4" screws on the air handler that have to be removed and that allows the panel where the FACTORY FILTER is located. If you have a filter in your return air grill, remove the factory filter, if not, leave it in and remember to clean it. While the bottom cover is open, look at the fan to see if it is clogged. DO NOT put your hands in there unless the main power to the A/H is OFF! 3) Go outside to the condenser and you will see a small red or green button at the bottom of the control panel access. Press it. If it clicks and the unit comes on, either the air flow inside is too low (see above) or the unit is overcharged with refridgerant. If everything is clean and there it plaenty of air flow, you will need a technician with the proper gauges, tools and knowledge to set the charge correctly. Be smart: price shop and get references. Ron
Posted on May 07, 2009
  • Ronald Walden
    Ronald Walden May 10, 2009
    Future reference:
    1) Furnaces in general don't have "override" switches - this helps in not having a large explosion.........
    A furnace goes through more checks than the Shuttle before it lights!
    First, on the control board, are there any lights blinking, if it did
    light, there should be. Somewhere there is a placard showing what the
    number of blinks means; I need to know what is says on the placard. In
    the meantime, check the draft fan sensor - it looks like a small flying
    saucer towards the top. Blow and **** on the tubes and listen for a
    clicking sound and look for the presence of any water in that tube.
    That switch verifies that the draft fan is on and the mains will not
    fire if the control board doesn't get the proper sequence of
    signal......off, sensor open, fan on, sensor closed, verify pilot, fire
    mains, verify mains all it (sensor at opposite end from pilot). Hope
    this helps, if not, get back to me with that control board code. Ron
RUUD AC cycles warm & cold 24/7
Hello Anna Sounds like the compressor is overheating and stoping on overload internally.Then it cools down restarts and runs into overload again.I would like to see the freon pressures when running.Could have a clog/restriction in piping.I dont like that you went thru a compressor already, the original installition is suspect.The original (1st) failure cause must be corrected.Check the TXV valve replace, filter/dryer look for a kinked pipe are ideas for overheating.Make sure condenser coil is free (ari flow)& clean also.
Jul 30, 2010 | Ruud UBHC Air Conditioner
Ruud UBHC AC System - Provides no Aux Heat
Tried this on my unit today, and observed the same results, but got Aux Heat (with A setting), if the H (blue wire) connected to B terminal, as per instructions for my 6036 Ritetemp. However, in this case, when the set temp is reached, I hear the click, but HVAC still blows aux heat indefinitely.
I also have RUUD UBEA 17J10..., and replaced my old honeywell with 6036, and can't get heat pump working. Both of my units are 14 years old, so I'm thinking to replace them soon.
Jan 06, 2010 | Ruud UBHC Air Conditioner
I have a ruud heat pump ac works fine when switch to heet compressor will not turn on
Your reversing valve is out. Or you have a electrical problem sending signal to the reversing valve. The valve switch from puting cooling in you home to putting heating in. You may need to call a tech you need special tools like a amp prob to look at the power. www.fastacservice.com
Oct 12, 2009 | Ruud UBHC Air Conditioner
RUUD UBHC-17J14SFA HEATING PROBLEM
you may have airflow issues, verify the inlet and outlet temps with the unit running on start up, if the unit exceeds the "rise" allowable then the safety devices "overtemp" will take the firing circuit off line until it cools down. The acceptable mfg. rise is listed on the nameplate inside the burner chamber, (generally on the side wall)
Jul 17, 2009 | Ruud UBHC Air Conditioner
Has not ever run properly
is it a heat pump? I would be suspect of the line voltage transformer have 24v. if transformer is not matched to line voltage you can have erratic problems their is an under lying problem. that is being missed find a good contractor . Tom
Jun 17, 2009 | Ruud UBHC Air Conditioner
Ruud Heat Pump blows room temp on Heat and AC setting
A "Heat-Pump" is also known as a reverse cycle air conditioner, this means on heat the outdoor unit acts like the indoor section and vice versa. So in all probability you need to have it leak checked and recharged.
Apr 27, 2009 | Ruud UBHC Air Conditioner
My ac stopped putting out cool air on a hot day. I turned off the ac and replaced 2 dirty filters and waited 4 hours to turn back on but the air does not seem cool. Did I not wait long enough time for it...
check to see if the fan is working at the condensing unit. if it is, check that the fan is pulling heat off the unit as it should. make sure the cage is clean. no restrictions as far as air flow. clean . check duct work for leaks. inside, if you replaced the filter/s. the evaporator is dirty. call a prof,
Apr 25, 2009 | Ruud UBHC Air Conditioner
Ac will not cool off
There are only 2-choices for this problem,,, 1= low on freon or 2-low air flow across the indoor coils which can be caused by dirty filter--- dirty fan blades and last but not least , dirty or plugged inside coils. After the unit has been cleanned , then he's suppose to check the freon last..
Sep 01, 2008 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
217 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
